Giga Displaying camera video inverted when running example code
I purchased the Arduino GIGA Display Bundlehttps://store-usa.arduino.cc/collections/giga/products/giga-display-bundle and the Arducam GC2145 2MP Color DVP Camerahttps://www.arducam.com/2mp-gc2145-color-dvp-camera-module-for-arduino-giga-r1-wifi-board.html
I loaded the example code
Examples > Camera > GigaCameraDisplay
#include "arducam_dvp.h"
#include "Arduino_H7_Video.h"
#include "dsi.h"
#include "SDRAM.h"
// This example only works with Greyscale cameras (due to the palette + resize&rotate algo)
#define ARDUCAM_CAMERA_HM01B0
#ifdef ARDUCAM_CAMERA_HM01B0
#include "Himax_HM01B0/himax.h"
HM01B0 himax;
Camera cam(himax);
#define IMAGE_MODE CAMERA_GRAYSCALE
#elif defined(ARDUCAM_CAMERA_HM0360)
#include "Himax_HM0360/hm0360.h"
HM0360 himax;
Camera cam(himax);
#elif defined(ARDUCAM_CAMERA_OV767X)
#include "OV7670/ov767x.h"
// OV7670 ov767x;
OV7675 ov767x;
Camera cam(ov767x);
#define IMAGE_MODE CAMERA_RGB565
#elif defined(ARDUCAM_CAMERA_GC2145)
#include "GC2145/gc2145.h"
GC2145 galaxyCore;
Camera cam(galaxyCore);
#endif
// The buffer used to capture the frame
FrameBuffer fb;
// The buffer used to rotate and resize the frame
FrameBuffer outfb;
Arduino_H7_Video Display(800, 480, GigaDisplayShield);
void blinkLED(uint32_t count = 0xFFFFFFFF)
  pinMode(LED_BUILTIN, OUTPUT);
  while (count--) {
    digitalWrite(LED_BUILTIN, LOW);  // turn the LED on (HIGH is the voltage level)
    delay(50);                       // wait for a second
    digitalWrite(LED_BUILTIN, HIGH); // turn the LED off by making the voltage LOW
uint32_t palette[256];
  // Init the cam QVGA, 30FPS
  if (!cam.begin(CAMERA_R320x240, IMAGE_MODE, 30)) {
    blinkLED();
  // Setup the palette to convert 8 bit greyscale to 32bit greyscale
  for (int i = 0; i < 256; i++) {
    palette[i] = 0xFF000000 | (i << 16) | (i << 8) | i;
  Display.begin();
  if (IMAGE_MODE == CAMERA_GRAYSCALE) {
    dsi_configueCLUT((uint32_t*)palette);
  outfb.setBuffer((uint8_t*)SDRAM.malloc(1024 * 1024));
  // clear the display (gives a nice black background)
  dsi_lcdClear(0);
  dsi_drawCurrentFrameBuffer();
  dsi_lcdClear(0);
#define HTONS(x)    (((x >> 8) & 0x00FF) | ((x << 8) & 0xFF00))
  // Grab frame and write to another framebuffer
  if (cam.grabFrame(fb, 3000) == 0) {
    // double the resolution and transpose (rotate by 90 degrees) in the same step
    // this only works if the camera feed is 320x240 and the area where we want to display is 640x480
    for (int i = 0; i < 320; i++) {
      for (int j = 0; j < 240; j++) {
          ((uint8_t*)outfb.getBuffer())[j * 2 + (i * 2) * 480] = ((uint8_t*)fb.getBuffer())[i + j * 320];
          ((uint8_t*)outfb.getBuffer())[j * 2 + (i * 2) * 480 + 1] = ((uint8_t*)fb.getBuffer())[i + j * 320];
          ((uint8_t*)outfb.getBuffer())[j * 2 + (i * 2 + 1) * 480] = ((uint8_t*)fb.getBuffer())[i + j * 320];
          ((uint8_t*)outfb.getBuffer())[j * 2 + (i * 2 + 1) * 480 + 1] = ((uint8_t*)fb.getBuffer())[i + j * 320];
          ((uint16_t*)outfb.getBuffer())[j * 2 + (i * 2) * 480] = HTONS(((uint16_t*)fb.getBuffer())[i + j * 320]);
          ((uint16_t*)outfb.getBuffer())[j * 2 + (i * 2) * 480 + 1] = HTONS(((uint16_t*)fb.getBuffer())[i + j * 320]);
          ((uint16_t*)outfb.getBuffer())[j * 2 + (i * 2 + 1) * 480] = HTONS(((uint16_t*)fb.getBuffer())[i + j * 320]);
          ((uint16_t*)outfb.getBuffer())[j * 2 + (i * 2 + 1) * 480 + 1] = HTONS(((uint16_t*)fb.getBuffer())[i + j * 320]);
    dsi_lcdDrawImage((void*)outfb.getBuffer(), (void*)dsi_getCurrentFrameBuffer(), 480, 640, IMAGE_MODE == CAMERA_GRAYSCALE ? DMA2D_INPUT_L8 : DMA2D_INPUT_RGB565);
    blinkLED(20);
While the Sketch compiles, loads, and runs the resulting video is inverted on the display.
I have only just in the last few months started working with microcontrollers and have little knowledge of coding.
I know there must be an error in the example code, I am just unable to spot it.
Any guidance would be appreciated
Larry C.
Define "inverted".
Is it upside down?
Mirrored left-right?
Rotated wrong direction?
Combination?
up is down, left is right
mirrored and upside down
Is the display correct if you display text, or an image from a file?
Sounds like it is rotated 180 degrees.
Yes the display works great on all other example sketch's and the video is good quality it's just upside down and backwards!
I suspect the the code near the bottom of the sketch that does all the math with the variable's i & j but I'm not very good with code so I'm not sure
If hw flip is supported, use that.
But I'm not sure if I navigate correctly the libraries.
Add these lines after cam.begin
galaxyCore.setVerticalFlip(true);
galaxyCore.setHorizontalMirror(true);
    blinkLED();
Hooray!!! that fixed it!!! Thank you
You're welcome.
