Hi i am new in this forum, and i try to run a glcd AG240128b with T6963C controller on Arduino UNO R3. I don't know how to wire this display. The pinout of this dispay is,
pin 1 VSS GND
pin 2 Vcc +5V
pin 3 Vo Contrast voltage
pin 4 C/D H : Data, L : Instruction Code
pin 5 /RD Read
pin 6 /WR Write
pin 7 /DB0~DB7 Data bus line
pin 8 /CE Enable signal
pin 9 /RST Reset
pin 10 Vout Power out voltage for LCD
pin 11~18 MD H : 32 / L : 40 Select Of Columns
pin 19 FS H : 68 , L : 88 Select Of Columns
pin 20 NC No connection
I can't understand for pin7 /data bus line/ i must use OneWire.lib ? Or something else ??
I have a T6963 library Google Code Archive - Long-term storage for Google Code Project Hosting. , but it has some errors on verify. Please help me in wiring and if you can give me working code because i am a beginner in programming. Thanks in advance.
Excuse me take my apologies, this is a datasheet of my display www.powertipusa.com/pdf/pg240128a.pdf I connect my display by the second link of your post... but my controller t6963c is very heat. But is no image on display. May be i do something wrong. :~ I also rename in U8glib pin 14, 15, 17, 18, 16 to A0, A1, A3, A4, A2.
For any further suggestions, you need to provide more information.
How are pins connected exactly? How did you connect the var pot? Exact U8glib constructor call? A picture of your setup might also be helpfull.
