Hello , I intend to make a pair of (arduino nano + uBlox Gps + nrf24L01 )
The first system will be stationary , while the second will be moving around ie on a drone transmitting coordinates to the station.
I would like to know a way to calculate the distance between to points, comparing the two different coordinates.
Usually I do not use any libraries on gps, just parse the serial data from Gps, however since you mentioned it I just checked tinygps library and found two functions
distance_to and distance_between
My interest is trying to find the bearing from one latitude and longitude from another. The using the posted formula and though it worked for the values provided, it failed when I used: 17.064202,61.794895 ;16.45, 62.09 or any such low latitudes.
