GPS module GT-U& not connecting need help with code
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <Wire.h>
static const int gpsTXPin = 4, gpsRXPin = 3; // Define GPS module pins
static const int gsmTXPin = 8, gsmRXPin = 7; // Define GSM module pins
static const uint32_t GPSBaud = 9600; // Baud rate for GPS
static const uint32_t GSMBaud = 115200; // Baud rate for GSM
static const int buttonPin = 2; // Define button pin
TinyGPSPlus gps;
SoftwareSerial gpsSerial(gpsRXPin, gpsTXPin); // RX, TX for GPS
SoftwareSerial gsmSerial(gsmRXPin, gsmTXPin); // RX, TX for GSM
// Initialize the LCD with I2C address 0x27 (20x4)
LiquidCrystal_I2C lcd(0x27, 20, 4);
unsigned long gpsTimer = 0;
const unsigned long gpsInterval = 120000; // 2 minutes
unsigned long displayTimer = 0;
const unsigned long refreshInterval = 60000; // 1 minute
bool displayRequested = false;
Serial.begin(9600); // Start serial communication for debugging
gpsSerial.begin(GPSBaud); // Set GPS module baud rate
gsmSerial.begin(GSMBaud); // Set GSM module baud rate
// Initialize LCD
lcd.init();
lcd.backlight(); // Turn on the backlight
lcd.clear(); // Clear the LCD screen
lcd.setCursor(0, 0);
lcd.print("Initializing...");
pinMode(buttonPin, INPUT_PULLUP); // Set button pin as input with internal pull-up
Serial.println("Initializing GSM module...");
// Give time for GSM module to initialize
delay(10000);
// Check communication with the GSM module
Serial.println("Testing GSM communication...");
gsmSerial.println("AT");
if (gsmSerial.available()) {
Serial.println("GSM module communication established.");
while (gsmSerial.available()) {
Serial.write(gsmSerial.read());
Serial.println("No response from GSM module.");
// Initialize GPS module
Serial.println("Connecting to GPS module...");
lcd.setCursor(0, 1);
lcd.print("Connecting to GPS");
// Try to get initial GPS fix
unsigned long start = millis();
bool gpsFixAcquired = false;
while (millis() - start < 10000) { // Try for 10 seconds
while (gpsSerial.available() > 0) {
char c = gpsSerial.read();
gps.encode(c);
if (gps.location.isUpdated()) {
gpsFixAcquired = true;
if (gpsFixAcquired) {
Serial.println("GPS fix acquired.");
lcd.setCursor(0, 2);
lcd.print("GPS fix acquired");
Serial.println("GPS fix not acquired.");
lcd.print("GPS fix not acquired");
// Check if the button is pressed to request GPS data display
if (digitalRead(buttonPin) == LOW) { // Button pressed (LOW because of internal pull-up)
displayRequested = true;
// Collect GPS data before sending SMS
collectGPSData();
// Send SMS with GPS location to phone number 123456789
if (gps.location.isValid()) {
  String message = "https://maps.google.com/maps?q=";
  message += String(gps.location.lat(), 6);
  message += ",";
  message += String(gps.location.lng(), 6);
  sendSMS("3852411508", message);
  Serial.println("Button pressed. Sent location to 3852411508.");
  lcd.clear();
  lcd.print("Sent location to");
  lcd.print("123456789");
  sendSMS("3852411508", "GPS location not available.");
  Serial.println("Button pressed. GPS location not available.");
  lcd.clear();
  lcd.print("GPS location not");
  lcd.print("available.");
// Wait for the button to be released
while (digitalRead(buttonPin) == LOW) {
  delay(50);
// Debounce delay
delay(50);
// Check if it's time to collect GPS data
if (millis() - gpsTimer > gpsInterval) {
collectGPSData();
// Read GPS data from SoftwareSerial
Serial.print(c); // Print raw GPS data for debugging
gps.encode(c);
// Check if it's time to refresh the display
if (millis() - displayTimer > refreshInterval) {
refreshDisplay();
// Check if display is requested
if (displayRequested) {
refreshDisplay();
displayRequested = false; // Reset display request after displaying once
void collectGPSData() {
// Reset the GPS timer
gpsTimer = millis();
void refreshDisplay() {
lcd.print("Current Location:");
lcd.print("Lat: ");
lcd.print(gps.location.lat(), 6);
lcd.print("Lng: ");
lcd.print(gps.location.lng(), 6);
lcd.setCursor(0, 3);
lcd.print("Google Maps:");
lcd.setCursor(13, 3);
lcd.print("https://maps.google.com/maps?q=");
lcd.print(",");
lcd.print("Location data");
lcd.print("not available");
// Reset the display timer
displayTimer = millis();
void sendSMS(String phoneNumber, String message) {
// Set SMS text mode
gsmSerial.println("AT+CMGF=1");
// Send SMS command
gsmSerial.print("AT+CMGS="");
gsmSerial.print(phoneNumber);
gsmSerial.println(""");
// Send message content
gsmSerial.print(message);
// End message with CTRL+Z
gsmSerial.write(26);
// Print debug info
Serial.print("Sent SMS to ");
Serial.print(": ");
Serial.println(message);
I am trying to use the provided code to get a GPS location and then send it over sms to a desire number however when connecting the GPS module to the system it can not connect and find its location
pls format code as code
#include <Wire.h>
TinyGPSPlus gps;
  // Initialize LCD
  lcd.init();
  delay(10000);
      gps.encode(c);
    collectGPSData();
    // Send SMS with GPS location to phone number 3852411508
      message += ",";
      lcd.clear();
      lcd.print("3852411508");
      lcd.clear();
      delay(50);
    // Debounce delay
    delay(50);
    collectGPSData();
    gps.encode(c);
    refreshDisplay();
    refreshDisplay();
    lcd.print("Lat: ");
    lcd.print("Lng: ");
    lcd.print(",");
  // Send SMS command
  gsmSerial.print("AT+CMGS=\"");
  gsmSerial.println("\"");
  // Print debug info
  Serial.print(": ");
I am using an Arduino Uno for this project but i am not sure if i will have to change arduino in order to make these two modules work together
two softwareSerials will not work, if I not misstaken
I am using an GT-U7 gps module and a SIM7600G-H GSM shield module for this project
and SS dont work with such big baud
maybe you try to stop one connection while other working?
and then start first and stop other...
i can get the system to send the sms to the number with the 115200 baud rate but the GPS does not connect so i am unable to get the gps location for the system.
is it work without GSM?
Yes i can get the gps to work alone at the 9600 baud rate
do you know Serial.end() command?
i do not i am really new to this all
start connection
and
gpsSerial.end();
will stop it, same with other connections. so you can start one, do their work and then stop, in order to do this to other module now.
so i have gotten it now to pull the GPS location however it ends the GSM before allowing it time to actually send the sms out
show, maybe i will understand what you mean.
  // Initialize LCD
  lcd.init();
  // Attempt to collect GPS data
  collectGPSData();
  // Continuously read GPS data
    gps.encode(c);
  // Check if GPS data has been collected
  if (!gpsDataCollected && gps.location.isValid()) {
    gpsDataCollected = true;
    Serial.println("GPS data collected.");
    lcd.print("GPS Data Collected");
    // End GPS serial communication
    gpsSerial.end();
  if (digitalRead(buttonPin) == LOW && gpsDataCollected) {  // Button pressed and GPS data collected
    // Initialize GSM communication
    // Collect GPS data again before sending SMS
    String message;
      message += ",";
      lcd.clear();
      lcd.clear();
      delay(50);
    // Debounce delay
    delay(50);
    // End GSM communication and wait for response before restarting GPS
    gsmSerial.end();
    waitForGSMResponse();
    // Reset the GPS data collection status
    gpsDataCollected = false;
    // Restart GPS serial communication
    refreshDisplay();
    refreshDisplay();
  Serial.println("Collecting GPS data...");
      gps.encode(c);
        return;
  Serial.println("GPS data collection timeout.");
    lcd.print("Lat: ");
    lcd.print("Lng: ");
    lcd.print(",");
  // Send SMS command
what i am now struggling with is getting the AT commands in the right spot so they send before the gsmSerial.end happens
your sketch is not complete, so i took only necessary piece:
  collectGPSData();
    String message;
      message += ",";
      lcd.clear();
      lcd.clear();
      delay(50);
    // Debounce delay
    delay(50);
   // gsmSerial.end();
    //gpsSerial.begin(GPSBaud);
    refreshDisplay();
    refreshDisplay();
  gsmSerial.end();
  gpsSerial.begin(9600); // Set GPS module baud rate
      gps.encode(c);
        return;
  gpsSerial.end();
  gsmSerial.begin(9600);
Thank you for your help. I have it now working. Now it's onto the next thing for the project
