This is My first post and i ould use all the help i can get.
Im using GPS shield on arduino uno. This is the source for the code i used Internet of Things: GPS Location Sensing with the Arduino Mega
It is used on arduino Mega, so i replaced the Serial1 by Serial and it worked. However, after a few days the same code didnt work after multiple attemps i just started a new project and it worked.
Again it is not working, not showing results, just showing Starting. I tired everything.
#include "TinyGPS.h"
TinyGPS gps;
#define GPS_TX_DIGITAL_OUT_PIN 5
#define GPS_RX_DIGITAL_OUT_PIN 6
long startMillis;
long secondsToFirstLocation = 0;
#define DEBUG
float latitude = 0.0;
float longitude = 0.0;
#ifdef DEBUG
Serial.begin(19200);
#endif
// Serial1 is GPS
// prevent controller pins 5 and 6 from interfering with the comms from GPS
pinMode(GPS_TX_DIGITAL_OUT_PIN, INPUT);
pinMode(GPS_RX_DIGITAL_OUT_PIN, INPUT);
startMillis = millis();
Serial.println("Starting");
readLocation();
void readLocation(){
bool newData = false;
unsigned long chars = 0;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;)
while (Serial.available())
int c = Serial.read();
// Serial.print((char)c); // if you uncomment this you will see the raw data from the GPS
++chars;
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
// we have a location fix so output the lat / long and time to acquire
if(secondsToFirstLocation == 0){
secondsToFirstLocation = (millis() - startMillis) / 1000;
Serial.print("Acquired in:");
Serial.print(secondsToFirstLocation);
Serial.println("s");
unsigned long age;
gps.f_get_position(&latitude, &longitude, &age);
latitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : latitude;
longitude == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : longitude;
Serial.print("Location: ");
Serial.print(latitude, 6);
Serial.print(" , ");
Serial.print(longitude, 6);
Serial.println("");
if (chars == 0){
// if you haven't got any chars then likely a wiring issue
Serial.println("Check wiring");
else if(secondsToFirstLocation == 0){
// still working
