GUI-O series: Building Android GUI with ASCII commands (IoT with ESP32)
EPISODE 20: GUI-O and ESP32 with MicroPython (MQTT with SSL/TLS support)
This example shows how to connect GUI-O with ESP32 via MQTT using MicroPython.
1. Setup MicroPython environment
The examples are based on ESP32-WROOM-32 board and PyCharm Community Edition IDE (Integrated Development Environment) with MicroPython plugin.
Note that any other ESP32 board can also be used. Also note that any other IDE that supports ESP32 & MicroPython can be used.
Step 1: Install MicroPython on ESP32
  1. Download the ESP32 firmware (for more information and support for other boards, see the firmware download page)
  2. Download the esptool for Linux or Windows (for more information, see esptool Git repository)
  3. Extract the downloaded archive and move the downloaded firmware into the extracted esptool folder
  4. Open the Terminal (Linux) or Command Prompt (Windows) and navigate to the extracted esptool folder
  5. Connect ESP32 to the PC and erase the flash:
    ./esptool --chip esp32 --port erase_flash
    NOTE #1: Replace in the command with the actual port where the ESP32 is connected. On Windows, this might be something like COM4 (or something like /dev/ttyUSB0 on Linux).
    NOTE #2: If the command is not recognized on Linux, make the tool executable (for all users):
    chmod a+x esptool
  6. Finally, program the ESP32 firmware:
    ./esptool --chip esp32 --port --baud 460800 write_flash -z 0x1000 <.bin_file>
Step 2: Setup PyCharm IDE
  1. Download and install PyCharm Community Edition for Windows or Linux
  2. Run PyCharm and select Plugins (from welcome screen) or navigate to "File -> Settings -> Plugins"
  3. Search for MicroPython plugin and install it
  4. Create a New Project and specify desired project location
  5. Navigate to "File -> Settings -> Languages & Frameworks -> MicroPython" and enable MicroPython
    support
  6. Select ESP8266 under "Device type"
  7. Under "Device path" enter the actual port where the ESP32 is connected - on Windows, this might be something like COM4 (or something like /dev/ttyUSB0 on Linux)
  8. Your project is now ready to run MicroPython code
2. Connect GUI-O and ESP32 via MQTT
Step 1: Create tokens for MQTT communication
  1. Open GUI-O application and select "Add" from the top-right corner of the home screen
  2. Select "IoT (Create device)" and add a new device (specifying arbitrary name and optional user name)
  3. After adding a device, note the In and Out tokens which are required in the following step (tokens can be shared via email by pressing the "Share" icon)
Step 2: Modify and run the Python script
  1. Connect ESP32 to the PC via USB cable
  2. Download the main.zip package to your PC and extract the package
  3. Copy main.py into the root of your PyCharm project and double-click on it within the PyCharm IDE
  4. Set your router name and password
  5. Set the In and Out tokens generated in Step 1
  6. You can optionally disable SSL/TLS (this will make the connection insecure and is not recommended)
  7. Right click on main.py, select Run 'Flash main.py' and confirm
    NOTE: In case of any missing libraries, just click on "Fix" button and PyCharm will automatically install them.
  8. After the upload, ESP32 should issue a soft-reboot and begin program execution
    NOTE: All debug messages during program execution can be observed using any serial console terminal (baud rate 115200 bps).
Step 3: Using GUI-O application to interact with ESP32
  1. Open GUI-O application and select "Connect" from the top-left corner of the home screen
  2. Tap on the device created in Step 1
  3. Wait for successful connection and try the example
If you have any questions or run into any problems, please let me know!
Best regards,
kl3m3n
EPISODE 21: GUI-O and ESP32 with MicroPython (Bluetooth Low Energy)
This example shows how to connect GUI-O with ESP32 via Bluetooth Low Energy (BLE) using MicroPython.
    chmod a+x esptool
    support
2. Connect GUI-O and ESP32 via BLE
Step 1: Run the Python script
  2. Download the main.zip and ble_advertising.zip packages to your PC and extract the packages
  3. Copy main.py and ble_advertising.py into the root of your PyCharm project and double-click on it within the PyCharm IDE
  4. Right click on main.py, select Run 'Flash main.py' and confirm
  5. Right click on ble_advertising.py, select Run 'Flash ble_advertising.py' and confirm
  6. After the upload, ESP32 should issue a soft-reboot and begin program execution
Step 2: Using GUI-O application to interact with ESP32
  1. Open GUI-O application and navigate to "Settings -> Connections -> Bluetooth LE"
  2. Tap "Available devices" to search for ESP32 Bluetooth device
  3. Tap "BasicBLE" device and wait for successful connection
  4. Close "Settings" and tap GUI-O initialize button from the home screen to try the example
Best regards,
kl3m3n
EPISODE 22: GUI-O and ESP32 with MicroPython (Ethernet)
This example shows how to connect GUI-O with ESP32 via Ethernet using MicroPython.
    chmod a+x esptool
    support
2. Connect GUI-O and ESP32 via Ethernet
  5. After the upload, ESP32 should issue a soft-reboot and begin program execution
  1. Open GUI-O application and navigate to "Settings -> Connections -> Ethernet"
  2. Tap "Add device" icon and set the device name, IP (e.g., 192.168.1.123) and port (e.g., 34567) based on your configuration
  3. Tap the created device and wait for successful connection
    NOTE: Make sure that your Android device is connected to the same WiFi network as ESP32 device.
Best regards,
kl3m3n
EPISODE 23: GUI-O push notification from any device
This example shows how to create custom push notification on any Internet enabled device (WiFi, Ethernet) and send it to a targeted Android device.
NOTE: Push notifications are available in GUI-O PRO version only.
The code from this example can be combined with other GUI-O examples using MQTT, Classic Bluetooth or Low Energy Bluetooth. See GUI-O application: Create high-end GUI for any device - GUI-O and BOARDS.
Software prerequisites:
 * GUI-O Basic Push notification example
 * Copyright (C) 2024, GUI-O Team
 * SPDX-License-Identifier: BSD-3-Clause
#include <WiFiClientSecure.h>
#include <HTTPClient.h>
#include <ArduinoJson.h>
static const char* ssid = "<ssid>"; // router name
static const char* pass = "<pass>"; // router password
static const char* appUuid = "<appUuid>"; // application uuid (retrieve from GUI-O app)
static const char* resource = "https://apis.gui-o.com:9501/gui-o/resources/api/sendPushNotification"; // request resource / endpoint
static const char* letsencrypt_ca = \
"-----BEGIN CERTIFICATE-----\n" \
"MIIFazCCA1OgAwIBAgIRAIIQz7DSQONZRGPgu2OCiwAwDQYJKoZIhvcNAQELBQAw\n" \
"TzELMAkGA1UEBhMCVVMxKTAnBgNVBAoTIEludGVybmV0IFNlY3VyaXR5IFJlc2Vh\n" \
"cmNoIEdyb3VwMRUwEwYDVQQDEwxJU1JHIFJvb3QgWDEwHhcNMTUwNjA0MTEwNDM4\n" \
"WhcNMzUwNjA0MTEwNDM4WjBPMQswCQYDVQQGEwJVUzEpMCcGA1UEChMgSW50ZXJu\n" \
"ZXQgU2VjdXJpdHkgUmVzZWFyY2ggR3JvdXAxFTATBgNVBAMTDElTUkcgUm9vdCBY\n" \
"MTCCAiIwDQYJKoZIhvcNAQEBBQADggIPADCCAgoCggIBAK3oJHP0FDfzm54rVygc\n" \
"h77ct984kIxuPOZXoHj3dcKi/vVqbvYATyjb3miGbESTtrFj/RQSa78f0uoxmyF+\n" \
"0TM8ukj13Xnfs7j/EvEhmkvBioZxaUpmZmyPfjxwv60pIgbz5MDmgK7iS4+3mX6U\n" \
"A5/TR5d8mUgjU+g4rk8Kb4Mu0UlXjIB0ttov0DiNewNwIRt18jA8+o+u3dpjq+sW\n" \
"T8KOEUt+zwvo/7V3LvSye0rgTBIlDHCNAymg4VMk7BPZ7hm/ELNKjD+Jo2FR3qyH\n" \
"B5T0Y3HsLuJvW5iB4YlcNHlsdu87kGJ55tukmi8mxdAQ4Q7e2RCOFvu396j3x+UC\n" \
"B5iPNgiV5+I3lg02dZ77DnKxHZu8A/lJBdiB3QW0KtZB6awBdpUKD9jf1b0SHzUv\n" \
"KBds0pjBqAlkd25HN7rOrFleaJ1/ctaJxQZBKT5ZPt0m9STJEadao0xAH0ahmbWn\n" \
"OlFuhjuefXKnEgV4We0+UXgVCwOPjdAvBbI+e0ocS3MFEvzG6uBQE3xDk3SzynTn\n" \
"jh8BCNAw1FtxNrQHusEwMFxIt4I7mKZ9YIqioymCzLq9gwQbooMDQaHWBfEbwrbw\n" \
"qHyGO0aoSCqI3Haadr8faqU9GY/rOPNk3sgrDQoo//fb4hVC1CLQJ13hef4Y53CI\n" \
"rU7m2Ys6xt0nUW7/vGT1M0NPAgMBAAGjQjBAMA4GA1UdDwEB/wQEAwIBBjAPBgNV\n" \
"HRMBAf8EBTADAQH/MB0GA1UdDgQWBBR5tFnme7bl5AFzgAiIyBpY9umbbjANBgkq\n" \
"hkiG9w0BAQsFAAOCAgEAVR9YqbyyqFDQDLHYGmkgJykIrGF1XIpu+ILlaS/V9lZL\n" \
"ubhzEFnTIZd+50xx+7LSYK05qAvqFyFWhfFQDlnrzuBZ6brJFe+GnY+EgPbk6ZGQ\n" \
"3BebYhtF8GaV0nxvwuo77x/Py9auJ/GpsMiu/X1+mvoiBOv/2X/qkSsisRcOj/KK\n" \
"NFtY2PwByVS5uCbMiogziUwthDyC3+6WVwW6LLv3xLfHTjuCvjHIInNzktHCgKQ5\n" \
"ORAzI4JMPJ+GslWYHb4phowim57iaztXOoJwTdwJx4nLCgdNbOhdjsnvzqvHu7Ur\n" \
"TkXWStAmzOVyyghqpZXjFaH3pO3JLF+l+/+sKAIuvtd7u+Nxe5AW0wdeRlN8NwdC\n" \
"jNPElpzVmbUq4JUagEiuTDkHzsxHpFKVK7q4+63SM1N95R1NbdWhscdCb+ZAJzVc\n" \
"oyi3B43njTOQ5yOf+1CceWxG1bQVs5ZufpsMljq4Ui0/1lvh+wjChP4kqKOJ2qxq\n" \
"4RgqsahDYVvTH9w7jXbyLeiNdd8XM2w9U/t7y0Ff/9yi0GE44Za4rF2LN9d11TPA\n" \
"mRGunUHBcnWEvgJBQl9nJEiU0Zsnvgc/ubhPgXRR4Xq37Z0j4r7g1SgEEzwxA57d\n" \
"emyPxgcYxn/eR44/KJ4EBs+lVDR3veyJm+kXQ99b21/+jh5Xos1AnX5iItreGCc=\n" \
"-----END CERTIFICATE-----\n";
// Connection and requests handling
WiFiClientSecure client;
HTTPClient http;
// Icoming data buffer
String in;
  // Debug output
  // Connect WiFi (keep trying...)
  Serial.print("Connecting to ");
  Serial.println(ssid);
  // Start WiFi
  WiFi.begin(ssid, pass);
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  // Set root CA
  client.setCACert(letsencrypt_ca);
  Serial.println("WiFi connected!");
  while(Serial.available()) {
    const char c = Serial.read();
    in += c;
    if(c == '\n') {
      // Send push notification
      sendPushNotification("GUI-O push notification example", in.c_str(), appUuid);
      // clear buffer
      in = "";
void sendPushNotification(const char* title, const char* message, const char* appUuid) {
  DynamicJsonDocument jsonPayload(512);
  jsonPayload["appUuid"] = String(appUuid);
  jsonPayload["messageTitle"] = String(title);
  jsonPayload["messageText"] = String(message);
  String payload;
  serializeJson(jsonPayload, payload);
  if (http.begin(client, resource)) {
      http.addHeader("Content-Type", "application/json");
      const int httpCode = http.POST(payload);
      if (httpCode == HTTP_CODE_OK) {
        String response = http.getString();
        Serial.print("Response: ");
        Serial.println(response);
      else {
        Serial.print("Request failed. Status code: ");
        Serial.println(httpCode);
      http.end();
Hardware prerequisites:
  • Any Internet enabled board (WiFi, Ethernet) that is compatible with Arduino IDE
1. Retrieve application's universally unique identifier (UUID)
  • Open GUI-O application, navigate to settings and select "Info"
  • Verify that the text "Available" is displayed under "Push notifications" entry
  • Make a note of "Application UUID" (you can share the "Application UUID" by tapping on it)
2. Modify and upload the code
  • Open Arduino IDE
  • Select "File -> Open"
  • Navigate to location where BasicPushNotification.zip archive was extracted (if downloaded)
  • Select BasicPushNotification.ino and confirm
  • Set your router name and password
  • Set your "Application UUID" (retrieved in form the GUI-O app)
  • Make sure that your board is connected to your PC
  • Ensure that the correct port and baud rate are selected
  • Press upload button to start code upload
3. Send a push notification
  • Open any serial terminal and connect to your board (baud rate 115200)
  • Enter your push notification message on the serial terminal - the text must be terminated with the \n (new line) character.
  • Observe the response on the serial terminal - if successful, message "Push notification sent" will be displayed
  • Check the push notification on your Android device
NOTE: Customize the sound, vibration, LED light, and priority of GUI-O app notifications by navigating to "Android settings -> Apps -> Manage apps".
Best regards,
kl3m3n
