Hosting a web page on Giga R1
Hello all,
Has anyone been successful with hosting a web page using Giga R1 board. (Web/HTTP server)
The WiFiWebServer example is very basic and and it tries embed the HTTP response with in the program. I want to be able to have a HTML code as a separate file or contained within an array. ESP8266 based boards have such exampled but not for this Giga R1.
Any references or links are much appreciated
You can check this thread: How to create a web page without using a server with an arduino GIGA
Thank you, but I dont think that topic was solved, one of the suggestions there was to use a raspberry instead of arduino Giga.
I am looking for something like this for Giga.
But most of these methods are not supported by Giga wifi libraries.
I don't know much but I was able to beat my face through building a GUI for my giga with copilot:
again I'm an idiot here so before some jerk gets all wound up about host/server/ap/IP terminology and tells me to go learn fundamentals of IT I'll just make a picture:
What it does:
  • Graphs all the A0-5 inputs either all together or separate
  • Y axis scaling control or auto scale (must hit apply to switch to manual)
  • Toggles the RGB led's on/off
    • This actually kicked my butt because you can't use a variable to toggle the "external" leds that are built into the board... something about them also being used to indicate OS status and a Mosfet driver yada yada yada oh also the logic is inversed
  • Parameter control is more or less a what you would expect if you wanted to update a float from the operator console. Basically you can type it in or increment it up/down with the arrows. the step value determined how much you can increment up and down... oh then min max on our values to try to be a good person.
Overall it's a starting point and its the example i wish i would have come across years ago.
What you need to do:
  1. copy/paste this code into your arduino IDE
  2. Update the SSID and Password of the router you are using (I think there is a better way of doing this but I don't know it yet... be responsible with your info)
  3. The board will boot up then connect to the wifi. Keep an eye on the serial monitor and it will tell you what IP address it was assigned. Blue light = connecting to wifi blue light off = connected.
  4. type that IP address into a web browser and you should see the GUI. The nice thing about this is that it is device and OS agnostic. it doesn't matter if you are on Android or windows you can interface and control stuff
  5. Click buttons break stuff and share!
it's a lot i know... I'd really love to learn how to package this into a library so it's just something you can include in you sketch and pass like 10 Bool 10 Floats etc back and forth in a clean UI. I think there is also a lot of room for making it run smoother/faster. But it's really just meant to be a starting point and show that it can be done.
  GIGA R1 WiFi - 6‑channel Web Oscilloscope + External RGB LED Controls
  - External RGB LED header (LED_RED, LED_GREEN, LED_BLUE)
  - Reliable flip‑flop logic using explicit HIGH/LOW writes
  - Parameter control UI sends float to /set?value=X
  - Float stored in global variable and printed to Serial
  - Keysight-style channel tabs with active tab matching chart background (#222)
  - Y-axis manual scaling + auto-scale
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "YOUR_ROUTERS_SSID";
char pass[] = "YOUR_ROUTERS_PASSWORD";
int status = WL_IDLE_STATUS;
WiFiServer server(80);
// External RGB LED states (active‑LOW)
int RState = HIGH;
int GState = HIGH;
int BState = HIGH;
// Global float parameter
float controlValue = 0.0;
//  Print WiFi status
void printWifiStatus() {
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
//  Setup
  delay(1500);
  // External RGB LED setup (active‑LOW)
  pinMode(LED_RED, OUTPUT);
  pinMode(LED_GREEN, OUTPUT);
  pinMode(LED_BLUE, OUTPUT);
  digitalWrite(LED_RED, HIGH);
  digitalWrite(LED_GREEN, HIGH);
  digitalWrite(LED_BLUE, LOW);
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    while (true);
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    delay(10000);
  server.begin();
  printWifiStatus();
  digitalWrite(LED_BLUE, HIGH);
//  Main loop
  WiFiClient client = server.available();
  if (!client) return;
  Serial.println("new client");
  String req = client.readStringUntil('\r');
  //Serial.println(req);
  client.readStringUntil('\n');
  //  /led?c=R|G|B  → toggle external RGB LED (flip‑flop)
  if (req.startsWith("GET /led")) {
    char channel = 'X';
    int idx = req.indexOf("c=");
    if (idx != -1 && idx + 2 < req.length()) {
      channel = req.charAt(idx + 2);
    if (channel == 'R') {
      RState = !RState;
      if (RState == LOW) digitalWrite(LED_RED, LOW);
      else digitalWrite(LED_RED, HIGH);
    if (channel == 'G') {
      GState = !GState;
      if (GState == LOW) digitalWrite(LED_GREEN, LOW);
      else digitalWrite(LED_GREEN, HIGH);
    if (channel == 'B') {
      BState = !BState;
      if (BState == LOW) digitalWrite(LED_BLUE, LOW);
      else digitalWrite(LED_BLUE, HIGH);
    client.println("Content-Type: text/plain");
    client.println("Connection: close");
    client.println();
    client.println("OK");
    delay(5);
    client.stop();
    Serial.println("LED toggled: " + String(channel));
    return;
  //  /set?value=X  → receive float from UI
  if (req.startsWith("GET /set")) {
    int idx = req.indexOf("value=");
    if (idx != -1) {
      controlValue = req.substring(idx + 6).toFloat();
      Serial.print("Received float: ");
      Serial.println(controlValue);
    client.println();
    delay(5);
    client.stop();
    return;
  //  /data  → JSON stream
  if (req.startsWith("GET /data")) {
    while (client.available()) {
      String line = client.readStringUntil('\n');
      if (line == "\r" || line.length() == 1) break;
    int values[6];
    for (int i = 0; i < 6; i++) values[i] = analogRead(i);
    client.println("Content-Type: application/json");
    client.println();
    client.print("[");
    for (int i = 0; i < 6; i++) {
      client.print(values[i]);
      if (i < 5) client.print(",");
    client.print("]");
    delay(5);
    client.stop();
    //Serial.println("client disconnected (data)");
    return;
  //  /  → HTML oscilloscope + LED controls + parameter control + tabs + Y-scale
  if (req.startsWith("GET / ")) {
    client.println("Content-Type: text/html");
    client.println();
    client.println("<!DOCTYPE HTML>");
    client.println("<html><head><meta charset='UTF-8'>");
    client.println("<title>GIGA Scope</title>");
    // Basic CSS for dark theme + Keysight-style tabs
    client.println("<style>");
    client.println("body { background:#111; color:#ccc; font-family:Bahnschrift, D-DIN, sans-serif; margin:20px; }");
    client.println("#scope { border:1px solid #444; background:#222; }");
    client.println(".tab-bar { margin-bottom:10px; border-bottom:1px solid #333; }");
    client.println(".tab-btn {");
    client.println("  background:#1a1a1a;");
    client.println("  color:#ccc;");
    client.println("  border:1px solid #333;");
    client.println("  border-bottom:none;");
    client.println("  padding:6px 12px;");
    client.println("  margin-right:4px;");
    client.println("  cursor:pointer;");
    client.println("  font-family:Bahnschrift, D-DIN, sans-serif;");
    client.println("  font-size:13px;");
    client.println("}");
    client.println(".tab-btn:hover { background:#2a2a2a; }");
    client.println(".tab-btn.active {");
    client.println("  background:#222;"); // same as chart background
    client.println("  color:#fff;");
    client.println("  font-weight:bold;");
    client.println("  border-color:#555;");
    client.println("</style>");
    client.println("</head><body>");
    client.println("<h2>GIGA R1 WiFi - 6 Channel Scope</h2>");
    // Tab bar
    client.println("<div class='tab-bar'>");
    client.println("<button class='tab-btn active' data-ch='-1' onclick='setChannel(-1, this)'>ALL</button>");
    client.println("<button class='tab-btn' data-ch='0' onclick='setChannel(0, this)'>A0</button>");
    client.println("<button class='tab-btn' data-ch='1' onclick='setChannel(1, this)'>A1</button>");
    client.println("<button class='tab-btn' data-ch='2' onclick='setChannel(2, this)'>A2</button>");
    client.println("<button class='tab-btn' data-ch='3' onclick='setChannel(3, this)'>A3</button>");
    client.println("<button class='tab-btn' data-ch='4' onclick='setChannel(4, this)'>A4</button>");
    client.println("<button class='tab-btn' data-ch='5' onclick='setChannel(5, this)'>A5</button>");
    client.println("</div>");
    client.println("<canvas id='scope' width='900' height='450'></canvas>");
    client.println("<div id='legend' style='margin-top:10px;'></div>");
    // Y-axis scale controls
    client.println(R"rawliteral(
<div style="margin-top:15px; color:#ccc; font-family:Bahnschrift, D-DIN, sans-serif;">
  <h3>Y-Axis Scale</h3>
  <div style="display:flex; align-items:center; gap:10px;">
    <span>Min:</span>
    <input id="yMin" type="number" step="1" value="0" style="width:80px; padding:4px;">
    <span>Max:</span>
    <input id="yMax" type="number" step="1" value="1023" style="width:80px; padding:4px;">
    <button onclick="applyYScale()" style="margin-left:10px;">Apply</button>
    <button onclick="enableAutoScale()" style="margin-left:10px;">Auto-Scale</button>
  </div>
</div>
)rawliteral");
    // LED buttons
    client.println("<div style='margin-top:15px;'>");
    client.println("<button onclick=\"toggleLED('R')\" style='margin-right:10px;'>Red LED</button>");
    client.println("<button onclick=\"toggleLED('G')\" style='margin-right:10px;'>Green LED</button>");
    client.println("<button onclick=\"toggleLED('B')\">Blue LED</button>");
    // Parameter control UI
<div style="margin-top:20px; color:#ccc; font-family:Bahnschrift, D-DIN, sans-serif;">
  <h3>
    Parameter Control
    <span id="paramEcho" style="margin-left:15px; font-weight:normal;">
      Param: 0.000
    </span>
  </h3>
    <!-- Main value -->
    <input id="paramValue" type="number" step="0.01" value="0.00"
    <!-- Up/Down arrows -->
    <div style="display:flex; flex-direction:column;">
      <button onclick="adjustValue(1)" style="width:30px;">▲</button>
      <button onclick="adjustValue(-1)" style="width:30px;">▼</button>
    </div>
    <!-- Step size -->
    <span>Step:</span>
    <input id="paramStep" type="number" step="0.01" value="0.10"
           style="width:60px; padding:4px;">
    <!-- Min -->
    <span>Min:</span>
    <input id="paramMin" type="number" step="0.01" value="-10.00"
    <!-- Max -->
    <span>Max:</span>
    <input id="paramMax" type="number" step="0.01" value="10.00"
    <!-- Manual send button -->
    <button onclick="sendValue()" style="margin-left:10px;">Send</button>
  </div>
</div>
)rawliteral");
    // JavaScript
    client.println("<script>");
const NUM_CHANNELS = 6;
const BUFFER_SIZE = 500;
const MAX_ADC = 1023;
const data = Array.from({length: NUM_CHANNELS}, () => Array(BUFFER_SIZE).fill(0));
const canvas = document.getElementById('scope');
const ctx = canvas.getContext('2d');
canvas.style.background = "#222";
const colors = ["#ff5555","#55ff55","#5599ff","#ffaa33","#cc66ff","#66ffff"];
const marginLeft = 40;
const marginRight = 10;
const marginTop = 10;
const marginBottom = 20;
// Y-axis scaling
let yMin = 0;
let yMax = 1023;
let autoScale = false;
function applyYScale() {
  autoScale = false;
  let minVal = parseFloat(document.getElementById("yMin").value);
  let maxVal = parseFloat(document.getElementById("yMax").value);
  if (isNaN(minVal)) minVal = 0;
  if (isNaN(maxVal)) maxVal = 1023;
  if (maxVal <= minVal) {
    minVal = 0;
    maxVal = 1023;
  yMin = minVal;
  yMax = maxVal;
  drawGrid();
  drawTraces();
  drawTickLabels();
  drawAxisLabels();
function enableAutoScale() {
  autoScale = true;
// Channel Tabs
let activeChannel = -1;  // -1 = ALL
function setChannel(ch, btn) {
  activeChannel = ch;
  // Update tab button active state
  const tabs = document.querySelectorAll('.tab-btn');
  tabs.forEach(t => t.classList.remove('active'));
  if (btn) btn.classList.add('active');
  else {
    // Fallback: match by data-ch if btn not passed
    tabs.forEach(t => {
      if (t.getAttribute('data-ch') == String(ch)) t.classList.add('active');
  drawGrid();
  drawTraces();
  drawTickLabels();
  drawAxisLabels();
// LED toggle
async function toggleLED(channel) {
  try {
    await fetch(`/led?c=${channel}`);
  } catch (e) {
    console.log("LED toggle error:", e);
// Parameter Control
function updateParamEcho(value) {
  const echo = document.getElementById("paramEcho");
  if (echo) echo.textContent = `Param: ${value.toFixed(3)}`;
async function adjustValue(direction) {
  let value = parseFloat(document.getElementById("paramValue").value);
  let step  = parseFloat(document.getElementById("paramStep").value);
  let min   = parseFloat(document.getElementById("paramMin").value);
  let max   = parseFloat(document.getElementById("paramMax").value);
  if (isNaN(value)) value = 0;
  if (isNaN(step)) step = 1;
  if (isNaN(min)) min = -Infinity;
  if (isNaN(max)) max = Infinity;
  value += direction * step;
  if (value < min) value = min;
  if (value > max) value = max;
  document.getElementById("paramValue").value = value.toFixed(3);
  updateParamEcho(value);
  try {
    await fetch(`/set?value=${value}`);
    console.log("Sent value (adjust):", value);
  } catch (e) {
    console.log("Send error (adjust):", e);
async function sendValue() {
  try {
    console.log("Sent value (manual):", value);
  } catch (e) {
    console.log("Send error (manual):", e);
// Drawing Functions
function drawGrid() {
  ctx.clearRect(0, 0, canvas.width, canvas.height);
  const w = canvas.width - marginLeft - marginRight;
  const h = canvas.height - marginTop - marginBottom;
  ctx.strokeStyle = "#555";
  ctx.lineWidth = 1;
  const rows = 8;
  for (let i = 0; i <= rows; i++) {
    const y = marginTop + (h * i / rows);
    ctx.beginPath();
    ctx.moveTo(marginLeft, y);
    ctx.lineTo(marginLeft + w, y);
    ctx.stroke();
  const cols = 12;
  for (let i = 0; i <= cols; i++) {
    const x = marginLeft + (w * i / cols);
    ctx.beginPath();
    ctx.moveTo(x, marginTop);
    ctx.lineTo(x, marginTop + h);
    ctx.stroke();
  ctx.strokeStyle = "#888";
  ctx.beginPath();
  ctx.moveTo(marginLeft, marginTop);
  ctx.lineTo(marginLeft, marginTop + h);
  ctx.lineTo(marginLeft + w, marginTop + h);
  ctx.stroke();
function drawTickLabels() {
  ctx.fillStyle = "#ccc";
  ctx.font = "12px Bahnschrift, 'D-DIN', sans-serif";
  ctx.textAlign = "right";
  const steps = 5;
  for (let i = 0; i <= steps; i++) {
    const v = yMin + (i * (yMax - yMin) / steps);
    const y = marginTop + h - ((v - yMin) / (yMax - yMin)) * h;
    const label = Math.round(v);
    ctx.fillText(label.toString(), marginLeft - 8, y + 4);
  ctx.textAlign = "center";
  const xTicks = 5;
  for (let i = 0; i <= xTicks; i++) {
    const x = marginLeft + (w * i / xTicks);
    const label = Math.round((BUFFER_SIZE * i) / xTicks);
    ctx.fillText(label.toString(), x, marginTop + h + 30);
function drawAxisLabels() {
  ctx.font = "14px Bahnschrift, 'D-DIN', sans-serif";
  ctx.save();
  ctx.translate(15, marginTop + h / 2);
  ctx.rotate(-Math.PI / 2);
  ctx.fillText("ADC Value", 0, 0);
  ctx.restore();
  ctx.fillText("Time (samples)", marginLeft + w / 2, marginTop + h + 45);
function drawTraces() {
  ctx.lineWidth = 1.5;
  const range = (yMax - yMin) || 1;
  for (let ch = 0; ch < NUM_CHANNELS; ch++) {
    // Only draw selected channel
    if (activeChannel !== -1 && activeChannel !== ch) continue;
    ctx.strokeStyle = colors[ch];
    ctx.beginPath();
    for (let i = 0; i < BUFFER_SIZE; i++) {
      const x = marginLeft + (i * (w / (BUFFER_SIZE - 1)));
      const v = data[ch][i];
      const clamped = Math.min(Math.max(v, yMin), yMax);
      const y = marginTop + h - ((clamped - yMin) / range) * h;
      if (i === 0) ctx.moveTo(x, y);
      else ctx.lineTo(x, y);
    ctx.stroke();
function updateLegend(latestValues) {
  const legend = document.getElementById("legend");
  let html = "";
    html += `
      <span style="
        display:inline-flex;
        align-items:center;
        margin-right:30px;
        font-family:Bahnschrift, 'D-DIN', sans-serif;
        color:#ccc;
        <span style="
          width:14px;
          height:14px;
          background:${colors[ch]};
          display:inline-block;
          margin-right:6px;
          border-radius:2px;
        "></span>
        <span style="width:50px; display:inline-block;">
          A${ch}: ${latestValues[ch]}
        </span>
      </span>
  legend.innerHTML = html;
async function poll() {
  try {
    const res = await fetch('/data');
    const vals = await res.json();
    if (!Array.isArray(vals) || vals.length < NUM_CHANNELS) return;
      data[ch].push(vals[ch]);
      if (data[ch].length > BUFFER_SIZE) data[ch].shift();
    // Auto-scale if enabled
    if (autoScale) {
      let minV = Infinity;
      let maxV = -Infinity;
          if (v < minV) minV = v;
          if (v > maxV) maxV = v;
      if (!isFinite(minV) || !isFinite(maxV)) {
        minV = 0;
        maxV = 1023;
      // Add padding
      minV -= 10;
      maxV += 10;
      if (minV < 0) minV = 0;
      if (maxV > MAX_ADC) maxV = MAX_ADC;
      if (maxV <= minV) {
        minV = 0;
        maxV = MAX_ADC;
      yMin = minV;
      yMax = maxV;
      // Reflect in UI
      const yMinInput = document.getElementById("yMin");
      const yMaxInput = document.getElementById("yMax");
      if (yMinInput) yMinInput.value = Math.round(yMin);
      if (yMaxInput) yMaxInput.value = Math.round(yMax);
    drawGrid();
    drawTraces();
    drawTickLabels();
    drawAxisLabels();
    updateLegend(vals);
  } catch (e) {
    console.log("poll error:", e);
drawGrid();
drawTraces();
drawTickLabels();
drawAxisLabels();
setInterval(poll, 250); //!!!UPDATE THIS TO CHANGE THE BROWSER POLL RATE!!!
)rawliteral");
    client.println("</script>");
    client.println("</body></html>");
    delay(5);
    client.stop();
    //Serial.println("client disconnected (page)");
    return;
  //  Fallback 404
  client.println("HTTP/1.1 404 Not Found");
  client.println();
  client.println("Not found");
  delay(5);
  client.stop();
  Serial.println("client disconnected (404)");
*edit removed a hilariously stupid bug where it wouldn't run unless it had a serial connection
