Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled
I am trying to run a simple wifiClient example from ESP32 Thing Plus Hookup Guide - SparkFun Learn, I have tried even the inbuilt examples but still, I get the same output on the serial monitor. I am using a ESP32 Devkit module This is the code I used
#include <WiFi.h>
// WiFi network name and password:
const char * networkName = "YOUR_NETWORK_HERE";
const char * networkPswd = "YOUR_PASSWORD_HERE";
// Internet domain to request from:
const char * hostDomain = "example.com";
const int hostPort = 80;
const int BUTTON_PIN = 0;
const int LED_PIN = 13;
  // Initilize hardware:
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  pinMode(LED_PIN, OUTPUT);
  // Connect to the WiFi network (see function below loop)
  connectToWiFi(networkName, networkPswd);
  digitalWrite(LED_PIN, LOW); // LED off
  Serial.print("Press button 0 to connect to ");
  Serial.println(hostDomain);
  if (digitalRead(BUTTON_PIN) == LOW)
  { // Check if button has been pressed
    while (digitalRead(BUTTON_PIN) == LOW)
      ; // Wait for button to be released
    digitalWrite(LED_PIN, HIGH); // Turn on LED
    requestURL(hostDomain, hostPort); // Connect to server
    digitalWrite(LED_PIN, LOW); // Turn off LED
void connectToWiFi(const char * ssid, const char * pwd)
  int ledState = 0;
  printLine();
  Serial.println("Connecting to WiFi network: " + String(ssid));
  WiFi.begin(ssid, pwd);
  while (WiFi.status() != WL_CONNECTED)
    // Blink LED while we're connecting:
    digitalWrite(LED_PIN, ledState);
    ledState = (ledState + 1) % 2; // Flip ledState
    Serial.print(".");
  Serial.println("WiFi connected!");
  Serial.print("IP address: ");
void requestURL(const char * host, uint8_t port)
  printLine();
  Serial.println("Connecting to domain: " + String(host));
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  if (!client.connect(host, port))
    Serial.println("connection failed");
    return;
  Serial.println("Connected!");
  printLine();
  // This will send the request to the server
  client.print((String)"GET / HTTP/1.1\r\n" +
               "Host: " + String(host) + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timeout = millis();
  while (client.available() == 0)
    if (millis() - timeout > 5000)
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while (client.available())
    String line = client.readStringUntil('\r');
    Serial.print(line);
  Serial.println("closing connection");
  client.stop();
void printLine()
  for (int i=0; i<30; i++)
    Serial.print("-");
This is the Serial output
Connecting to domain: example.com
Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x401130e8: ea6825e4 f01d062d 82004136
Core 1 register dump:
PC      : 0x401130ee  PS      : 0x00060e30  A0      : 0x00000000  A1      : 0x3ffb1d20
A2      : 0x00000000  A3      : 0x00000000  A4      : 0x3ffb1dbc  A5      : 0x3ffb1db4
A6      : 0x00000000  A7      : 0x00000000  A8      : 0x00000000  A9      : 0x3ffb1d00
A10     : 0x00000001  A11     : 0x00000000  A12     : 0x3ffb99c8  A13     : 0x00000000
A14     : 0x00000000  A15     : 0x00000003  SAR     : 0x0000000a  EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000  LBEG    : 0x4000c46c  LEND    : 0x4000c477  LCOUNT  : 0x00000000
Backtrace: 0x401130ee:0x3ffb1d20 0x7ffffffd:0x3ffb1d80 0x400fc0b7:0x3ffb1e00 0x4012908d:0x3ffb1e50 0x400d1f35:0x3ffb1e70 0x400d15ca:0x3ffb1ed0 0x4013c7e5:0x3ffb1f00 0x400d133d:0x3ffb1f20 0x400d14e2:0x3ffb1f90 0x400d3e69:0x3ffb1fb0 0x40088b7d:0x3ffb1fd0
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
Connecting to WiFi network: iBall-Baton-1
[D][WiFiGeneric.cpp:337] _eventCallback(): Event: 0 - WIFI_READY
[D][WiFiGeneric.cpp:337] _eventCallback(): Event: 2 - STA_START
Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x400e94bc: 5bc60060 10646300 f03df03d
Core 0 register dump:
PC      : 0x400e94c1  PS      : 0x00060830  A0      : 0x800f59f3  A1      : 0x3ffb54b0
A2      : 0x3ffba470  A3      : 0x3ffcb34c  A4      : 0x3ffb5510  A5      : 0x0000003d
A6      : 0x3ffcb409  A7      : 0x3ffcb3ca  A8      : 0x0000002d  A9      : 0x0000002d
A10     : 0x0000000d  A11     : 0x00000001  A12     : 0x0000001a  A13     : 0x3ffcb576
A14     : 0x00004824  A15     : 0x00000007  SAR     : 0x00000018  EXCCAUSE: 0x00000000
Backtrace: 0x400e94c1:0x3ffb54b0 0x400f59f0:0x3ffb5500
Rebooting...
Update:
Problem solved, i had the wrong board selected, they both have similar names
First thing I would do is eliminate any empty wait loops, like this one:
The ESPs have watchdogs, and if you tie up the processor for more than a few mSec without releasing control back to the "OS", it WILL throw a watchdog error. Adding ANY delay to that loop (even delayMicroseconds(1) will allow the watchdog to be reset.
Regards,
Ray L.
I am sorry, that was not the problem, I had the wrong board selected, both the boards had similar names
