I am at a loss to understand why this device in my motor driver circuit works for 10 or 20 seconds and then burns up? I am using this H-Bridge motor driver to drive a small 12V gear motor. The motor draws approx. 80 to 100ma at 12V. Everything seems to work from an Arduino programming standpoint, but when I upload a simple forward reverse sketch to test it, it will work for a bit then smokes. I've gone thru 4 of these devices and each eventually fries. Below is my circuit but there is nothing unconventional about it.
https://drive.google.com/file/d/1e6pQRPDU4fmN1NlNHlU43J6FggrgOCpg/view?usp=sharing
My first thought is that the Gearmotor at some point when stopped and reversed is causing EMF current (and potentially shorting the MOSFETs in the bridge) but looking at the schematic of the MP6513 device, flyback diodes are built into each MOSFET. My next thought is that the datasheet warns that you need to put a capacitor on the VCC to avoid voltage spikes to the device. I currently have a 47ufd on its VCC but perhaps this is not adequate and I need to increase it to 100 or 220ufd?
I've double and triple checked my PCB (had one made up for this circuit) for shorts in traces and there are none. This is definitely related to just the H-Bridge motor driver. The rest of my circuit works perfectly. the other crazy thing is that the breadboard I built with another device DRV8871 works just fine, but for some reason, this device in my final PCBA doesn't.
Any notions or advice would be appreciated.
thanks
Mark
