When I first found the software and drivers, etc, I downloaded everything to my ipad for later and forgot it about. Later I just used the computer. well today I was cleaning my downloads and ran across a torobot file I clicked it and then clicked it again and guess what came across?
Turns out there are example files. Here are the kewords......
Syntax Coloring Map SoftwareServo
Datatypes (KEYWORD1)
SoftwareServo KEYWORD1
Methods and Functions (KEYWORD2)
attach KEYWORD2
detach KEYWORD2
write KEYWORD2
read KEYWORD2
attached KEYWORD2
setMinimumPulse KEYWORD2
setMaximumPulse KEYWORD2
refresh KEYWORD2
Constants (LITERAL1)
----------------------Serial servo.pde------------------
#include <SoftwareServo.h>
SoftwareServo servo1;
SoftwareServo servo2;
pinMode(13,OUTPUT);
servo1.attach(2);
servo1.setMaximumPulse(2200);
servo2.attach(4);
servo2.setMaximumPulse(2200);
Serial.print("Ready");
static int value = 0;
static char CurrentServo = 0;
if ( Serial.available()) {
char ch = Serial.read();
switch(ch) {
case 'A':
servo1.attach(2);
CurrentServo='A';
digitalWrite(13,LOW);
case 'B':
servo2.attach(4);
CurrentServo='B';
digitalWrite(13,HIGH);
case '0' ... '9':
value=(ch-'0')*20;
if (CurrentServo=='A')
servo1.write(value);
else if (CurrentServo=='B')
servo2.write(value);
SoftwareServo::refresh();
----------------------------Servo software.cpp-------------------
SoftwareServo *SoftwareServo::first;
#define NO_ANGLE (0xff)
SoftwareServo::SoftwareServo() : pin(0),angle(NO_ANGLE),pulse0(0),min16(34),max16(150),next(0)
void SoftwareServo::setMinimumPulse(uint16_t t)
min16 = t/16;
void SoftwareServo::setMaximumPulse(uint16_t t)
max16 = t/16;
uint8_t SoftwareServo::attach(int pinArg)
pin = pinArg;
angle = NO_ANGLE;
pulse0 = 0;
next = first;
first = this;
digitalWrite(pin,0);
pinMode(pin,OUTPUT);
return 1;
void SoftwareServo::detach()
for ( SoftwareServo **p = &first; *p != 0; p = &((*p)->next) ) {
if ( *p == this) {
*p = this->next;
this->next = 0;
return;
void SoftwareServo::write(int angleArg)
if ( angleArg < 0) angleArg = 0;
if ( angleArg > 180) angleArg = 180;
angle = angleArg;
// bleh, have to use longs to prevent overflow, could be tricky if always a 16MHz clock, but not true
// That 64L on the end is the TCNT0 prescaler, it will need to change if the clock's prescaler changes,
// but then there will likely be an overflow problem, so it will have to be handled by a human.
pulse0 = (min1616LclockCyclesPerMicrosecond() + (max16-min16)(16LclockCyclesPerMicrosecond())*angle/180L)/64L;
uint8_t SoftwareServo::read()
return angle;
uint8_t SoftwareServo::attached()
for ( SoftwareServo *p = first; p != 0; p = p->next ) {
if ( p == this) return 1;
return 0;
void SoftwareServo::refresh()
uint8_t count = 0, i = 0;
uint16_t base = 0;
SoftwareServo *p;
static unsigned long lastRefresh = 0;
unsigned long m = millis();
// if we haven't wrapped millis, and 20ms have not passed, then don't do anything
if ( m >= lastRefresh && m < lastRefresh + 20) return;
lastRefresh = m;
for ( p = first; p != 0; p = p->next ) if ( p->pulse0) count++;
if ( count == 0) return;
// gather all the SoftwareServos in an array
SoftwareServo *s[count];
for ( p = first; p != 0; p = p->next ) if ( p->pulse0) s[i++] = p;
// bubblesort the SoftwareServos by pulse time, ascending order
for(;
uint8_t moved = 0;
for ( i = 1; i < count; i++) {
if ( s*->pulse0 < s[i-1]->pulse0) {*
_ SoftwareServo t = s;_
_ s = s[i-1];
s[i-1] = t;
moved = 1;
if ( !moved) break;
// turn on all the pins*
* // Note the timing error here... when you have many SoftwareServos going, the*
* // ones at the front will get a pulse that is a few microseconds too long.
// Figure about 4uS/SoftwareServo after them. This could be compensated, but I feel*
* // it is within the margin of error of software SoftwareServos that could catch*
* // an extra interrupt handler at any time.
for ( i = 0; i < count; i++) digitalWrite( s->pin, 1);_
uint8_t start = TCNT0;
uint8_t now = start;
uint8_t last = now;
_ // Now wait for each pin's time in turn..
for ( i = 0; i < count; i++) {_
uint16_t go = start + s->pulse0;
_ // loop until we reach or pass 'go' time*
* for (;
now = TCNT0;
if ( now < last) base += 256;
last = now;
if ( base+now > go) {
digitalWrite( s->pin,0);
------------------------------servo software.h---------------------_
#ifndef SoftwareServo_h*
#define SoftwareServo_h
#include <WProgram.h>
#include <inttypes.h>
class SoftwareServo
* private:*
* uint8_t pin;
uint8_t angle; // in degrees*
* uint16_t pulse0; // pulse width in TCNT0 counts*
* uint8_t min16; // minimum pulse, 16uS units (default is 34)
uint8_t max16; // maximum pulse, 16uS units, 0-4ms range (default is 150)
_ class SoftwareServo next;
static SoftwareServo first;
public:
SoftwareServo();_
uint8_t attach(int); // attach to a pin, sets pinMode, returns 0 on failure, won't*
* // position the servo until a subsequent write() happens*
* void detach();*
* void write(int); // specify the angle in degrees, 0 to 180*
* uint8_t read();
uint8_t attached();
void setMinimumPulse(uint16_t); // pulse length for 0 degrees in microseconds, 540uS default*
* void setMaximumPulse(uint16_t); // pulse length for 180 degrees in microseconds, 2400uS default*
* static void refresh(); // must be called at least every 50ms or so to keep servo alive*
* // you can call more often, it won't happen more than once every 20ms*
#endif
Now I just have to decipher it for myself.
Reminder: All code must be in .txt format for the torobot program to read it.
Can someone please think about the "symmetry servo" or "symmetry relations" or "symmetry required relationship" box and help me solve that problem?
