Haxapod arduini mega 2560
hello everyone
here I am on a hexapod project.
here is my code that I have to enter on my arduino mega board.
unfortunately when I want to put my code on my card its block at the level of the ps2 command.
I'm just a beginner and I can't solve the problem. I need help, thank you all
here is my error message
C:\Users\Janny\Downloads\Hexapod (3)\Hexapod (3).ino:20:10: fatal error: PS2X_lib.h: No such file or directory
 #include <PS2X_lib.h>   //reference: http://www.billporter.info/
compilation terminated.
exit status 1
Compilation error: PS2X_lib.h: No such file or directory
here is the link of my project
thank you all for your help
Redirecting...
Hello everyone, I found my problem.
the problem that has c is at the level of the library for the ps2 controller.
I have a link that offers me a library
but unfortunately when I want to put it in the library, he does not take it.
I have good to decompress the file nothing goes.
http://
www.billporter.com
info/
here is the link that was with my project
for the library
// Hexapod Program
// Code for Arduino Mega
// by Mark W
// IK and Hexapod gait references:
//  https://www.projectsofdan.com/?cat=4
//  http://www.gperco.com/2015/06/hex-inverse-kinematics.html
//  http://virtual-shed.blogspot.com/2012/12/hexapod-inverse-kinematics-part-1.html
//  http://virtual-shed.blogspot.com/2013/01/hexapod-inverse-kinematics-part-2.html
//  https://www.robotshop.com/community/forum/t/inverse-kinematic-equations-for-lynxmotion-3dof-legs/21336
//  http://arduin0.blogspot.com/2012/01/inverse-kinematics-ik-implementation.html?utm_source=rb-community&utm_medium=forum&utm_campaign=inverse-kinematic-equations-for-lynxmotion-3dof-legs
// Includes
#include <Servo.h>
#include <math.h>
// Constant Declarations
const int BATT_VOLTAGE = 0;           //12V Battery analog voltage input port
const int PS2_DAT = 2;                //gamepad port definitions
const int PS2_ATT = 3;
const int PS2_CMD = 4;
const int PS2_CLK = 5;
const int RUMBLE = true;
const int PRESSURES = false;
const int COXA1_SERVO  = 19;          //servo port definitions
const int FEMUR1_SERVO = 21;
const int TIBIA1_SERVO = 23;
const int COXA2_SERVO  = 25;
const int FEMUR2_SERVO = 27;
const int TIBIA2_SERVO = 29;
const int COXA3_SERVO  = 31;
const int FEMUR3_SERVO = 33;
const int TIBIA3_SERVO = 35;
const int COXA4_SERVO  = 37;
const int FEMUR4_SERVO = 39;
const int TIBIA4_SERVO = 41;
const int COXA5_SERVO  = 43;
const int FEMUR5_SERVO = 45;
const int TIBIA5_SERVO = 47;
const int COXA6_SERVO  = 49;
const int FEMUR6_SERVO = 51;
const int TIBIA6_SERVO = 53;
const int RED_LED1   = 22;            //LED port definitions
const int GREEN_LED1 = 24;
const int RED_LED2   = 26;
const int GREEN_LED2 = 28;
const int RED_LED3   = 30;
const int GREEN_LED3 = 32;
const int RED_LED4   = 34;
const int GREEN_LED4 = 36;
const int RED_LED5   = 38;
const int GREEN_LED5 = 40;
const int RED_LED6   = 42;
const int GREEN_LED6 = 44;
const int RED_LED7   = 46;
const int GREEN_LED7 = 48;
const int RED_LED8   = 50;
const int GREEN_LED8 = 52;
const int COXA_LENGTH = 51;           //leg part lengths
const int FEMUR_LENGTH = 65;
const int TIBIA_LENGTH = 121;
const int TRAVEL = 30;                //translate and rotate travel limit constant
const long A12DEG = 209440;           //12 degrees in radians x 1,000,000
const long A30DEG = 523599;           //30 degrees in radians x 1,000,000
const int FRAME_TIME_MS = 20;         //frame time (20msec = 50Hz)
const float HOME_X[6] = {  82.0,   0.0, -82.0,  -82.0,    0.0,  82.0};  //coxa-to-toe home positions
const float HOME_Y[6] = {  82.0, 116.0,  82.0,  -82.0, -116.0, -82.0};
const float HOME_Z[6] = { -80.0, -80.0, -80.0,  -80.0,  -80.0, -80.0};
const float BODY_X[6] = { 110.4,  0.0, -110.4, -110.4,    0.0, 110.4};  //body center-to-coxa servo distances
const float BODY_Y[6] = {  58.4, 90.8,   58.4,  -58.4,  -90.8, -58.4};
const float BODY_Z[6] = {   0.0,  0.0,    0.0,    0.0,    0.0,   0.0};
const int COXA_CAL[6]  = {2, -1, -1, -3, -2, -3};                       //servo calibration constants
const int FEMUR_CAL[6] = {4, -2,  0, -1,  0,  0};
const int TIBIA_CAL[6] = {0, -3, -3, -2, -3, -1};
// Variable Declarations
int gamepad_error;                    //gamepad variables
byte gamepad_type;
byte gamepad_vibrate;
unsigned long currentTime;            //frame timer variables
unsigned long previousTime;
int temp;                             //mode and control variables
int mode;
int gait;
int gait_speed;
int gait_LED_color;
int reset_position;
int capture_offsets;
int batt_LEDs;                        //battery monitor variables
int batt_voltage;
int batt_voltage_index;
int batt_voltage_array[50];
long batt_voltage_sum;
float L0, L3;                         //inverse kinematics variables
float gamma_femur;
float phi_tibia, phi_femur;
float theta_tibia, theta_femur, theta_coxa;
int leg1_IK_control, leg6_IK_control; //leg lift mode variables
float leg1_coxa, leg1_femur, leg1_tibia;
float leg6_coxa, leg6_femur, leg6_tibia;
int leg_num;                          //positioning and walking variables
int z_height_LED_color;
int totalX, totalY, totalZ;
int tick, duration, numTicks;
int z_height_left, z_height_right;
int commandedX, commandedY, commandedR;
int translateX, translateY, translateZ;
float step_height_multiplier;
float strideX, strideY, strideR;
float sinRotX, sinRotY, sinRotZ;
float cosRotX, cosRotY, cosRotZ;
float rotOffsetX, rotOffsetY, rotOffsetZ;
float amplitudeX, amplitudeY, amplitudeZ;
float offset_X[6], offset_Y[6], offset_Z[6];
float current_X[6], current_Y[6], current_Z[6];
int tripod_case[6]   = {1,2,1,2,1,2};     //for tripod gait walking
int ripple_case[6]   = {2,6,4,1,3,5};     //for ripple gait
int wave_case[6]     = {1,2,3,4,5,6};     //for wave gait
int tetrapod_case[6] = {1,3,2,1,2,3};     //for tetrapod gait
// Object Declarations
PS2X ps2x;              //PS2 gamepad controller
Servo coxa1_servo;      //18 servos
Servo femur1_servo;
Servo tibia1_servo;
Servo coxa2_servo;
Servo femur2_servo;
Servo tibia2_servo;
Servo coxa3_servo;
Servo femur3_servo;
Servo tibia3_servo;
Servo coxa4_servo;
Servo femur4_servo;
Servo tibia4_servo;
Servo coxa5_servo;
Servo femur5_servo;
Servo tibia5_servo;
Servo coxa6_servo;
Servo femur6_servo;
Servo tibia6_servo;
// Initialization Routine
  //start serial
  //attach servos
  coxa1_servo.attach(COXA1_SERVO,610,2400);
  femur1_servo.attach(FEMUR1_SERVO,610,2400);
  tibia1_servo.attach(TIBIA1_SERVO,610,2400);
  coxa2_servo.attach(COXA2_SERVO,610,2400);
  femur2_servo.attach(FEMUR2_SERVO,610,2400);
  tibia2_servo.attach(TIBIA2_SERVO,610,2400);
  coxa3_servo.attach(COXA3_SERVO,610,2400);
  femur3_servo.attach(FEMUR3_SERVO,610,2400);
  tibia3_servo.attach(TIBIA3_SERVO,610,2400);
  coxa4_servo.attach(COXA4_SERVO,610,2400);
  femur4_servo.attach(FEMUR4_SERVO,610,2400);
  tibia4_servo.attach(TIBIA4_SERVO,610,2400);
  coxa5_servo.attach(COXA5_SERVO,610,2400);
  femur5_servo.attach(FEMUR5_SERVO,610,2400);
  tibia5_servo.attach(TIBIA5_SERVO,610,2400);
  coxa6_servo.attach(COXA6_SERVO,610,2400);
  femur6_servo.attach(FEMUR6_SERVO,610,2400);
  tibia6_servo.attach(TIBIA6_SERVO,610,2400);
  //connect the gamepad
  gamepad_error = ps2x.config_gamepad(PS2_CLK, PS2_CMD, PS2_ATT, PS2_DAT, PRESSURES, RUMBLE);
  if(gamepad_error == 0)      Serial.println("Controller attached");
  else if(gamepad_error == 1) Serial.println("No controller found");
  else if(gamepad_error == 2) Serial.println("Controller found but not accepting commands");
  else if(gamepad_error == 3) Serial.println("Controller refusing to enter Pressures mode");
  //verify the gamepad type
  gamepad_type = ps2x.readType();
  if(gamepad_type == 0)      Serial.println("Unknown Controller type found");
  else if(gamepad_type == 1) Serial.println("DualShock Controller found");
  else if(gamepad_type == 2) Serial.println("GuitarHero Controller found");
  else if(gamepad_type == 3) Serial.println("Wireless Sony DualShock Controller found");
  //turn off gamepad vibration
  gamepad_vibrate = 0;
  //set up LED pins as outputs
  for(int i=0; i<8; i++)
    pinMode((RED_LED1+(4*i)),OUTPUT);
    pinMode((GREEN_LED1+(4*i)),OUTPUT);
  //set up battery monitor average array
  for(batt_voltage_index=0; batt_voltage_index<50; batt_voltage_index++)
    batt_voltage_array[batt_voltage_index] = 0;
  batt_voltage_sum = 0;
  batt_voltage_index = 0;
  //clear offsets
  for(leg_num=0; leg_num<6; leg_num++)
    offset_X[leg_num] = 0.0;
    offset_Y[leg_num] = 0.0;
    offset_Z[leg_num] = 0.0;
  capture_offsets = false;
  step_height_multiplier = 1.0;
  //initialize mode and gait variables
  mode = 0;
  gait = 0;
  gait_speed = 0;
  reset_position = true;
  leg1_IK_control = true;
  leg6_IK_control = true;
// Main Program
  //exit if no controller found or GuitarHero controller
  if((gamepad_error == 1) || (gamepad_type == 2))
    Serial.println("Invalid Controller!");
    return;
  //set up frame time
  currentTime = millis();
  if((currentTime - previousTime) > FRAME_TIME_MS)
    previousTime = currentTime;
    //read controller and process inputs
    ps2x.read_gamepad(false, gamepad_vibrate);
    process_gamepad();
    //reset legs to home position when commanded
    if(reset_position == true)
        current_X[leg_num] = HOME_X[leg_num];
        current_Y[leg_num] = HOME_Y[leg_num];
        current_Z[leg_num] = HOME_Z[leg_num];
      reset_position = false;
    //position legs using IK calculations - unless set all to 90 degrees mode
    if(mode < 99)
        leg_IK(leg_num,current_X[leg_num]+offset_X[leg_num],current_Y[leg_num]+offset_Y[leg_num],current_Z[leg_num]+offset_Z[leg_num]);
    //reset leg lift first pass flags if needed
    if(mode != 4)
    battery_monitor();                        //battery monitor and output to LEDs
    print_debug();                            //print debug data
    //process modes (mode 0 is default 'home idle' do-nothing mode)
    if(mode == 1)                             //walking mode
      if(gait == 0) tripod_gait();            //walk using gait 0
      if(gait == 1) wave_gait();              //walk using gait 1
      if(gait == 2) ripple_gait();            //walk using gait 2
      if(gait == 3) tetrapod_gait();          //walk using gait 3
    if(mode == 2) translate_control();        //joystick control x-y-z mode
    if(mode == 3) rotate_control();           //joystick control y-p-r mode
    if(mode == 4) one_leg_lift();             //one leg lift mode
    if(mode == 99) set_all_90();              //set all servos to 90 degrees mode
// Process gamepad controller inputs
void process_gamepad()
  if(ps2x.ButtonPressed(PSB_PAD_DOWN))    //stop & select gait 0
    mode = 0;
    gait = 0;
  if(ps2x.ButtonPressed(PSB_PAD_LEFT))    //stop & select gait 1
    mode = 0;
    gait = 1;
  if(ps2x.ButtonPressed(PSB_PAD_UP))      //stop & select gait 2
    mode = 0;
    gait = 2;
  if(ps2x.ButtonPressed(PSB_PAD_RIGHT))   //stop & select gait 3
    mode = 0;
    gait = 3;
  if(mode == 0)                           //display selected gait on LEDs if button held
    if(batt_LEDs > 3) gait_LED_color=0;   //display gait using red LEDs if battery strong
    else gait_LED_color=1;                //display gait using green LEDs if battery weak
    if(ps2x.Button(PSB_PAD_DOWN))  LED_Bar(gait_LED_color,1);    //display gait 0
    if(ps2x.Button(PSB_PAD_LEFT))  LED_Bar(gait_LED_color,2);    //display gait 1
    if(ps2x.Button(PSB_PAD_UP))    LED_Bar(gait_LED_color,3);    //display gait 2
    if(ps2x.Button(PSB_PAD_RIGHT)) LED_Bar(gait_LED_color,4);    //display gait 3
  if(ps2x.ButtonPressed(PSB_TRIANGLE))    //select walk mode
    mode = 1;
  if(ps2x.Button(PSB_TRIANGLE))           //vibrate controller if walk button held
    gamepad_vibrate = 64;
  if(ps2x.ButtonPressed(PSB_SQUARE))      //control x-y-z with joysticks mode
    mode = 2;
  if(ps2x.ButtonPressed(PSB_CIRCLE))      //control y-p-r with joysticks mode
    mode = 3;
  if(ps2x.ButtonPressed(PSB_CROSS))       //one leg lift mode
    mode = 4;
  if(ps2x.ButtonPressed(PSB_START))       //change gait speed
    if(gait_speed == 0)
      gait_speed = 1;
      gait_speed = 0;
  if(ps2x.Button(PSB_START))              //display gait speed on LEDs if button held
    if(gait_speed == 0) LED_Bar(1,8);     //use green LEDs for fast
    else LED_Bar(0,8);                    //use red LEDs for slow
  if(ps2x.ButtonPressed(PSB_SELECT))      //set all servos to 90 degrees for calibration
    mode = 99;
  if((ps2x.ButtonPressed(PSB_L1)) || (ps2x.ButtonPressed(PSB_R1)))
    //capture offsets in translate, rotate, and translate/rotate modes
    capture_offsets = true;
  if((ps2x.ButtonPressed(PSB_L2)) || (ps2x.ButtonPressed(PSB_R2)))
    for(leg_num=0; leg_num<6; leg_num++)  //clear offsets
      offset_X[leg_num] = 0;
      offset_Y[leg_num] = 0;
      offset_Z[leg_num] = 0;
    leg1_IK_control = true;               //reset leg lift first pass flags
    step_height_multiplier = 1.0;         //reset step height multiplier
// Leg IK Routine
void leg_IK(int leg_number,float X,float Y,float Z)
  //compute target femur-to-toe (L3) length
  L0 = sqrt(sq(X) + sq(Y)) - COXA_LENGTH;
  L3 = sqrt(sq(L0) + sq(Z));
  //process only if reach is within possible range (not too long or too short!)
  if((L3 < (TIBIA_LENGTH+FEMUR_LENGTH)) && (L3 > (TIBIA_LENGTH-FEMUR_LENGTH)))
    //compute tibia angle
    phi_tibia = acos((sq(FEMUR_LENGTH) + sq(TIBIA_LENGTH) - sq(L3))/(2*FEMUR_LENGTH*TIBIA_LENGTH));
    theta_tibia = phi_tibia*RAD_TO_DEG - 23.0 + TIBIA_CAL[leg_number];
    theta_tibia = constrain(theta_tibia,0.0,180.0);
    //compute femur angle
    gamma_femur = atan2(Z,L0);
    phi_femur = acos((sq(FEMUR_LENGTH) + sq(L3) - sq(TIBIA_LENGTH))/(2*FEMUR_LENGTH*L3));
    theta_femur = (phi_femur + gamma_femur)*RAD_TO_DEG + 14.0 + 90.0 + FEMUR_CAL[leg_number];
    theta_femur = constrain(theta_femur,0.0,180.0);
    //compute coxa angle
    theta_coxa = atan2(X,Y)*RAD_TO_DEG + COXA_CAL[leg_number];
    //output to the appropriate leg
    switch(leg_number)
      case 0:
        if(leg1_IK_control == true)                       //flag for IK or manual control of leg
          theta_coxa = theta_coxa + 45.0;                 //compensate for leg mounting
          theta_coxa = constrain(theta_coxa,0.0,180.0);
          coxa1_servo.write(int(theta_coxa));
          femur1_servo.write(int(theta_femur));
          tibia1_servo.write(int(theta_tibia));
      case 1:
        theta_coxa = theta_coxa + 90.0;                 //compensate for leg mounting
        coxa2_servo.write(int(theta_coxa));
        femur2_servo.write(int(theta_femur));
        tibia2_servo.write(int(theta_tibia));
      case 2:
        theta_coxa = theta_coxa + 135.0;                 //compensate for leg mounting
        coxa3_servo.write(int(theta_coxa));
        femur3_servo.write(int(theta_femur));
        tibia3_servo.write(int(theta_tibia));
      case 3:
        if(theta_coxa < 0)                                //compensate for leg mounting
          theta_coxa = theta_coxa + 225.0;                // (need to use different
        else                                              //  positive and negative offsets
          theta_coxa = theta_coxa - 135.0;                //  due to atan2 results above!)
        coxa4_servo.write(int(theta_coxa));
        femur4_servo.write(int(theta_femur));
        tibia4_servo.write(int(theta_tibia));
      case 4:
          theta_coxa = theta_coxa + 270.0;                // (need to use different
          theta_coxa = theta_coxa - 90.0;                 //  due to atan2 results above!)
        coxa5_servo.write(int(theta_coxa));
        femur5_servo.write(int(theta_femur));
        tibia5_servo.write(int(theta_tibia));
      case 5:
        if(leg6_IK_control == true)                       //flag for IK or manual control of leg
            theta_coxa = theta_coxa + 315.0;              // (need to use different
            theta_coxa = theta_coxa - 45.0;               //  due to atan2 results above!)
          coxa6_servo.write(int(theta_coxa));
          femur6_servo.write(int(theta_femur));
          tibia6_servo.write(int(theta_tibia));
// Tripod Gait
// Group of 3 legs move forward while the other 3 legs provide support
void tripod_gait()
  //read commanded values from controller
  commandedX = map(ps2x.Analog(PSS_RY),0,255,127,-127);
  commandedY = map(ps2x.Analog(PSS_RX),0,255,-127,127);
  commandedR = map(ps2x.Analog(PSS_LX),0,255,127,-127);
  //if commands more than deadband then process
  if((abs(commandedX) > 15) || (abs(commandedY) > 15) || (abs(commandedR) > 15) || (tick>0))
    compute_strides();
    numTicks = round(duration / FRAME_TIME_MS / 2.0); //total ticks divided into the two cases
      compute_amplitudes();
      switch(tripod_case[leg_num])
        case 1:                               //move foot forward (raise and lower)
          current_X[leg_num] = HOME_X[leg_num] - amplitudeX*cos(M_PI*tick/numTicks);
          current_Y[leg_num] = HOME_Y[leg_num] - amplitudeY*cos(M_PI*tick/numTicks);
          current_Z[leg_num] = HOME_Z[leg_num] + abs(amplitudeZ)*sin(M_PI*tick/numTicks);
          if(tick >= numTicks-1) tripod_case[leg_num] = 2;
        case 2:                               //move foot back (on the ground)
          current_X[leg_num] = HOME_X[leg_num] + amplitudeX*cos(M_PI*tick/numTicks);
          current_Y[leg_num] = HOME_Y[leg_num] + amplitudeY*cos(M_PI*tick/numTicks);
          if(tick >= numTicks-1) tripod_case[leg_num] = 1;
    //increment tick
    if(tick < numTicks-1) tick++;
    else tick = 0;
// Wave Gait
// Legs move forward one at a time while the other 5 legs provide support
void wave_gait()
    compute_strides();
    numTicks = round(duration / FRAME_TIME_MS / 6.0); //total ticks divided into the six cases
      switch(wave_case[leg_num])
          if(tick >= numTicks-1) wave_case[leg_num] = 6;
        case 2:                               //move foot back one-fifth (on the ground)
          current_X[leg_num] = current_X[leg_num] - amplitudeX/numTicks/2.5;
          current_Y[leg_num] = current_Y[leg_num] - amplitudeY/numTicks/2.5;
          if(tick >= numTicks-1) wave_case[leg_num] = 1;
        case 3:                               //move foot back one-fifth (on the ground)
          if(tick >= numTicks-1) wave_case[leg_num] = 2;
        case 4:                               //move foot back one-fifth (on the ground)
            wave_case[leg_num] = 3;
        case 5:                               //move foot back one-fifth (on the ground)
          if(tick >= numTicks-1) wave_case[leg_num] = 4;
        case 6:                               //move foot back one-fifth (on the ground)
          if(tick >= numTicks-1) wave_case[leg_num] = 5;
    //increment tick
    else tick = 0;
// Ripple Gait
// Left legs move forward rear-to-front while right also do the same,
// but right side is offset so RR starts midway through the LM stroke
void ripple_gait()
    compute_strides();
      switch(ripple_case[leg_num])
        case 1:                               //move foot forward (raise)
          current_X[leg_num] = HOME_X[leg_num] - amplitudeX*cos(M_PI*tick/(numTicks*2));
          current_Y[leg_num] = HOME_Y[leg_num] - amplitudeY*cos(M_PI*tick/(numTicks*2));
          current_Z[leg_num] = HOME_Z[leg_num] + abs(amplitudeZ)*sin(M_PI*tick/(numTicks*2));
          if(tick >= numTicks-1) ripple_case[leg_num] = 2;
        case 2:                               //move foot forward (lower)
          current_X[leg_num] = HOME_X[leg_num] - amplitudeX*cos(M_PI*(numTicks+tick)/(numTicks*2));
          current_Y[leg_num] = HOME_Y[leg_num] - amplitudeY*cos(M_PI*(numTicks+tick)/(numTicks*2));
          current_Z[leg_num] = HOME_Z[leg_num] + abs(amplitudeZ)*sin(M_PI*(numTicks+tick)/(numTicks*2));
          if(tick >= numTicks-1) ripple_case[leg_num] = 3;
        case 3:                               //move foot back one-quarter (on the ground)
          current_X[leg_num] = current_X[leg_num] - amplitudeX/numTicks/2.0;
          current_Y[leg_num] = current_Y[leg_num] - amplitudeY/numTicks/2.0;
          if(tick >= numTicks-1) ripple_case[leg_num] = 4;
        case 4:                               //move foot back one-quarter (on the ground)
          if(tick >= numTicks-1) ripple_case[leg_num] = 5;
        case 5:                               //move foot back one-quarter (on the ground)
          if(tick >= numTicks-1) ripple_case[leg_num] = 6;
        case 6:                               //move foot back one-quarter (on the ground)
          if(tick >= numTicks-1) ripple_case[leg_num] = 1;
    //increment tick
    else tick = 0;
// Tetrapod Gait
// Right front and left rear legs move forward together, then right
// rear and left middle, and finally right middle and left front.
void tetrapod_gait()
    compute_strides();
    numTicks = round(duration / FRAME_TIME_MS / 3.0); //total ticks divided into the three cases
      switch(tetrapod_case[leg_num])
          if(tick >= numTicks-1) tetrapod_case[leg_num] = 2;
        case 2:                               //move foot back one-half (on the ground)
          current_X[leg_num] = current_X[leg_num] - amplitudeX/numTicks;
          current_Y[leg_num] = current_Y[leg_num] - amplitudeY/numTicks;
          if(tick >= numTicks-1) tetrapod_case[leg_num] = 3;
        case 3:                               //move foot back one-half (on the ground)
          if(tick >= numTicks-1) tetrapod_case[leg_num] = 1;
    //increment tick
    else tick = 0;
// Compute walking stride lengths
void compute_strides()
  //compute stride lengths
  strideX = 90*commandedX/127;
  strideY = 90*commandedY/127;
  strideR = 35*commandedR/127;
  //compute rotation trig
  sinRotZ = sin(radians(strideR));
  cosRotZ = cos(radians(strideR));
  //set duration for normal and slow speed modes
  if(gait_speed == 0) duration = 1080;
  else duration = 3240;
// Compute walking amplitudes
void compute_amplitudes()
  //compute total distance from center of body to toe
  totalX = HOME_X[leg_num] + BODY_X[leg_num];
  totalY = HOME_Y[leg_num] + BODY_Y[leg_num];
  //compute rotational offset
  rotOffsetX = totalY*sinRotZ + totalX*cosRotZ - totalX;
  rotOffsetY = totalY*cosRotZ - totalX*sinRotZ - totalY;
  //compute X and Y amplitude and constrain to prevent legs from crashing into each other
  amplitudeX = ((strideX + rotOffsetX)/2.0);
  amplitudeY = ((strideY + rotOffsetY)/2.0);
  amplitudeX = constrain(amplitudeX,-50,50);
  amplitudeY = constrain(amplitudeY,-50,50);
  //compute Z amplitude
  if(abs(strideX + rotOffsetX) > abs(strideY + rotOffsetY))
    amplitudeZ = step_height_multiplier * (strideX + rotOffsetX) /4.0;
    amplitudeZ = step_height_multiplier * (strideY + rotOffsetY) / 4.0;
// Body translate with controller (xyz axes)
void translate_control()
  //compute X direction move
  translateX = map(ps2x.Analog(PSS_RY),0,255,-2*TRAVEL,2*TRAVEL);
    current_X[leg_num] = HOME_X[leg_num] + translateX;
  //compute Y direction move
  translateY = map(ps2x.Analog(PSS_RX),0,255,2*TRAVEL,-2*TRAVEL);
    current_Y[leg_num] = HOME_Y[leg_num] + translateY;
  //compute Z direction move
  translateZ = ps2x.Analog(PSS_LY);
  if(translateZ > 127)
    translateZ = map(translateZ,128,255,0,TRAVEL);
    translateZ = map(translateZ,0,127,-3*TRAVEL,0);
    current_Z[leg_num] = HOME_Z[leg_num] + translateZ;
  //lock in offsets if commanded
  if(capture_offsets == true)
      offset_X[leg_num] = offset_X[leg_num] + translateX;
      offset_Y[leg_num] = offset_Y[leg_num] + translateY;
      offset_Z[leg_num] = offset_Z[leg_num] + translateZ;
  //if offsets were commanded, exit current mode
    mode = 0;
// Body rotate with controller (xyz axes)
void rotate_control()
  //compute rotation sin/cos values using controller inputs
  sinRotX = sin((map(ps2x.Analog(PSS_RX),0,255,A12DEG,-A12DEG))/1000000.0);
  cosRotX = cos((map(ps2x.Analog(PSS_RX),0,255,A12DEG,-A12DEG))/1000000.0);
  sinRotY = sin((map(ps2x.Analog(PSS_RY),0,255,A12DEG,-A12DEG))/1000000.0);
  cosRotY = cos((map(ps2x.Analog(PSS_RY),0,255,A12DEG,-A12DEG))/1000000.0);
  sinRotZ = sin((map(ps2x.Analog(PSS_LX),0,255,-A30DEG,A30DEG))/1000000.0);
  cosRotZ = cos((map(ps2x.Analog(PSS_LX),0,255,-A30DEG,A30DEG))/1000000.0);
  for(int leg_num=0; leg_num<6; leg_num++)
    totalZ = HOME_Z[leg_num] + BODY_Z[leg_num];
    //perform 3 axis rotations
    rotOffsetX =  totalX*cosRotY*cosRotZ + totalY*sinRotX*sinRotY*cosRotZ + totalY*cosRotX*sinRotZ - totalZ*cosRotX*sinRotY*cosRotZ + totalZ*sinRotX*sinRotZ - totalX;
    rotOffsetY = -totalX*cosRotY*sinRotZ - totalY*sinRotX*sinRotY*sinRotZ + totalY*cosRotX*cosRotZ + totalZ*cosRotX*sinRotY*sinRotZ + totalZ*sinRotX*cosRotZ - totalY;
    rotOffsetZ =  totalX*sinRotY         - totalY*sinRotX*cosRotY                                  + totalZ*cosRotX*cosRotY                                  - totalZ;
    // Calculate foot positions to achieve desired rotation
    current_X[leg_num] = HOME_X[leg_num] + rotOffsetX;
    current_Y[leg_num] = HOME_Y[leg_num] + rotOffsetY;
    current_Z[leg_num] = HOME_Z[leg_num] + rotOffsetZ + translateZ;
      offset_X[leg_num] = offset_X[leg_num] + rotOffsetX;
      offset_Y[leg_num] = offset_Y[leg_num] + rotOffsetY;
      offset_Z[leg_num] = offset_Z[leg_num] + rotOffsetZ + translateZ;
    mode = 0;
// One leg lift mode
// also can set z step height using capture offsets
void one_leg_lift()
  //read current leg servo 1 positions the first time
    leg1_coxa  = coxa1_servo.read();
    leg1_femur = femur1_servo.read();
    leg1_tibia = tibia1_servo.read();
    leg1_IK_control = false;
  //read current leg servo 6 positions the first time
    leg6_coxa  = coxa6_servo.read();
    leg6_femur = femur6_servo.read();
    leg6_tibia = tibia6_servo.read();
    leg6_IK_control = false;
  //process right joystick left/right axis
  temp = ps2x.Analog(PSS_RX);
  temp = map(temp,0,255,45,-45);
  coxa1_servo.write(constrain(int(leg1_coxa+temp),45,135));
  //process right joystick up/down axis
  temp = ps2x.Analog(PSS_RY);
  if(temp < 117)                                //if joystick moved up
    temp = map(temp,116,0,0,24);                //move leg 1
    femur1_servo.write(constrain(int(leg1_femur+temp),0,170));
    tibia1_servo.write(constrain(int(leg1_tibia+4*temp),0,170));
  else                                          //if joystick moved down
    z_height_right = constrain(temp,140,255);   //set Z step height
    z_height_right = map(z_height_right,140,255,1,8);
  //process left joystick left/right axis
  temp = ps2x.Analog(PSS_LX);
  coxa6_servo.write(constrain(int(leg6_coxa+temp),45,135));
  //process left joystick up/down axis
  temp = ps2x.Analog(PSS_LY);
    temp = map(temp,116,0,0,24);                //move leg 6
    femur6_servo.write(constrain(int(leg6_femur+temp),0,170));
    tibia6_servo.write(constrain(int(leg6_tibia+4*temp),0,170));
    z_height_left = constrain(temp,140,255);    //set Z step height
    z_height_left = map(z_height_left,140,255,1,8);
  //process z height adjustment
  if(z_height_left>z_height_right)
    z_height_right = z_height_left;             //use max left or right value
  if(batt_LEDs > 3) z_height_LED_color=0;       //use red LEDs if battery strong
  else z_height_LED_color=1;                    //use green LEDs if battery weak
  LED_Bar(z_height_LED_color,z_height_right);   //display Z height
  if(capture_offsets == true)                   //lock in Z height if commanded
    step_height_multiplier = 1.0 + ((z_height_right - 1.0) / 3.0);
// Set all servos to 90 degrees
// Note: this is useful for calibration/alignment of the servos
// i.e: set COXA_CAL[6], FEMUR_CAL[6], and TIBIA_CAL[6] values in
//      constants section above so all angles appear as 90 degrees
void set_all_90()
  coxa1_servo.write(90+COXA_CAL[0]);
  femur1_servo.write(90+FEMUR_CAL[0]);
  tibia1_servo.write(90+TIBIA_CAL[0]);
  coxa2_servo.write(90+COXA_CAL[1]);
  femur2_servo.write(90+FEMUR_CAL[1]);
  tibia2_servo.write(90+TIBIA_CAL[1]);
  coxa3_servo.write(90+COXA_CAL[2]);
  femur3_servo.write(90+FEMUR_CAL[2]);
  tibia3_servo.write(90+TIBIA_CAL[2]);
  coxa4_servo.write(90+COXA_CAL[3]);
  femur4_servo.write(90+FEMUR_CAL[3]);
  tibia4_servo.write(90+TIBIA_CAL[3]);
  coxa5_servo.write(90+COXA_CAL[4]);
  femur5_servo.write(90+FEMUR_CAL[4]);
  tibia5_servo.write(90+TIBIA_CAL[4]);
  coxa6_servo.write(90+COXA_CAL[5]);
  femur6_servo.write(90+FEMUR_CAL[5]);
  tibia6_servo.write(90+TIBIA_CAL[5]);
// Battery monitor routine
// Note: my hexapod uses a 3S LiPo battery
// (fully charged = 12.6V, nominal = 11.4V, discharged = 10.2V)
void battery_monitor()
  //update voltage sum (remove oldest value and insert new value into array)
  batt_voltage_sum = batt_voltage_sum - batt_voltage_array[batt_voltage_index];
  //scale voltage reading to 0 to 14.97V (slight recalibration due to resistor tolerances)
  batt_voltage_array[batt_voltage_index] = map(analogRead(BATT_VOLTAGE),0,1023,0,1497);
  batt_voltage_sum = batt_voltage_sum + batt_voltage_array[batt_voltage_index];
  batt_voltage_index = batt_voltage_index + 1;
  if(batt_voltage_index > 49) batt_voltage_index = 0;
  //compute average battery voltage over the 50 samples
  batt_voltage = batt_voltage_sum / 50;
  //remap battery voltage for display on the LEDs
  //minimum = 10.2V, maximum (full) = 12.3V
  batt_LEDs = map(constrain(batt_voltage,1020,1230),1020,1230,1,8);
  if(batt_LEDs > 3) LED_Bar(1,batt_LEDs); //display green if voltage >= 11.40V
  else LED_Bar(0,batt_LEDs);              //display red if voltage < 11.40V
// LED Bar Graph Routine
// Note: 8 dual-color red/green LEDs in a row
// LED_color: 0=Red, 1=Green
// LED_count: 0 to 8
void LED_Bar(int LED_color,int LED_count)
  //display a red bar
  if(LED_color == 0)
    for(int i=0; i<LED_count; i++)
      digitalWrite((RED_LED1+(4*i)),HIGH);
      digitalWrite((GREEN_LED1+(4*i)),LOW);
    for(int i=LED_count; i<8; i++)
      digitalWrite((RED_LED1+(4*i)),LOW);
  //display a green bar
      digitalWrite((GREEN_LED1+(4*i)),HIGH);
// Print Debug Data
void print_debug()
  //output IK data
//  Serial.print(int(theta_coxa));
//  Serial.print(",");
//  Serial.print(int(theta_femur));
//  Serial.print(int(theta_tibia));
  //output XYZ coordinates for all legs
//  for(leg_num=0; leg_num<6; leg_num++)
//    Serial.print(int(current_X[leg_num]));
//    if(leg_num<5) Serial.print(",");
//  Serial.print("  ");
//    Serial.print(int(current_Y[leg_num]));
//    Serial.print(int(current_Z[leg_num]));
  //display elapsed frame time (ms) and battery voltage (V)
  Serial.print(currentTime-previousTime);
  Serial.print(",");
  Serial.print(float(batt_voltage)/100.0);
  Serial.print("\n");
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Have you got this library installed on your PC and if so exactly where is this file located ?
The links are required to find the missing library location. But I seem to be too dumb to find the download button in those pages. It may be required to register and login? Certainly not a masterpiece of useful web content :frowning:
Hello, are you sure that the PS2X_lib.h library is properly installed in your computer? The error message that you're getting usually occurs due to a missing library.
RE-edit your first posting to present your code as a code-section
follow this tutorial that describes how yuo can do this
best regards Stefan
Looks like the current version is:
hello sorry this is new for me
I added the link of my project
in my ad
thank you
https://markwtech.com/robots/hexapod/
I reviewed the "suspect links" and found them to be benign so I have reverted the inappropriate edit. I apologize for the inconvenience @fersininx
@fersininx It will not be possible for us to help you with that problem based on such a vague description. Please provide a detailed explanation of what you mean by this, including:
  • What did you do?
  • What were the results you expected from doing that?
  • What were the results you observed that did not match your expectations?
    • Make sure to include the full and exact text of any error or warning message you might have encountered.
