Attached is a PDF showing heat shrink application ideas I though some would be interested in.
If you have favorite uses for heat shrink, please share them.
I use a hot air rework station to heat shrink items, but on occasions use an alcohol lamp.
I do not like using a lighter as black soot gets onto the heat shrink.
Hot air rework station is the best for me. I don't like using a lighter, only in crisis but not above the flame. I'm heating it on the side of flame, near to blue part of flame to minimize smoking.
Soldering iron also works and its usually to hand - you can almost touch the tubing with the iron for
best effect - not as good as hot air, but the iron is usually there, hot, ready.
Years ago, I had a hundred or so 2/0 welding cable leads to heat shrink at each end. Took a while to do the job with a heat gun due to thermal inertia. Wish I knew about this 212,000 BTU heat gun ...
Notice the gas connection on the bottom. Just hook it up to any convenient LPG tank and it doubles as a weed burner, or if you want to de-ice your driveway, or pre-heat an engine block for welding....
But with an LDR instead of Photo-transistor, in an emergency when the real component was 6weeks back order and customer needed machine back in operation.
The opto was a linear one, rather than digital, there was another of these couplers in the machine, so I copied the basic characteristics.
I was surprised how well and stable it was in a feedback loop.
Tom....
Back in the dark ages, tiny light bulbs were used instead of LEDs.
Boardburner2:
Aye. and we had to scrape the laquer of OC72 ' s.
Until Phiips or Mullard probably realised their sales of OCP71 phototransistors were being compromised and started filling the OC71 etc with opaque rather than clear silicon grease. (The OC72 had a metal casing to assist with heat dissipation) Some interesting history here
jackrae:
