Hi there,
I am quite new to Arduino and have made an attempt at the Hello World tutorial, and have used the sketch and followed all the steps as found here.
I have plugged in and the LCD will illuminate, no problem. I then uploaded my sketch to the board, only to find it has no effect on the LCD whatsoever. The LCD continues to show a blank screen with no text, and when adjusting the 10k pot I am getting no change in the LCD, despite taking a multimeter reading over pins 3 (V0-contrast) and 1 (VSS-Ground) and getting good, variable readings between ~4.95V and ~0V depending on the position of the pot, so I have ruled that out as an issue.
I have rechecked my wiring numerous times and have changed all wires out once.
I am starting to feel as though I have a faulty LCD screen, but as I am new to this I may also quite possibly be missing something that I am hoping someone here can pull me up on.
All these parts (board included) are part of this kit I recently purchased (if you were wondering about the hardware).
I have also included pictures of my set up below.
Thanks in advance,
Tim
