on the ESP32C3 Super mini GPIO9 is a strapping pin so should be avoided
also GPIO8 is connected to the Onboard LED which may cause problems with the I2C interface
Sketch uses 330606 bytes (25%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13872 bytes (4%) of dynamic memory, leaving 313808 bytes for local variables. Maximum is 327680 bytes.
esptool v5.1.0
Serial port COM5:
Connecting....
A serial exception error occurred: Write timeout
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
Failed uploading: uploading error: exit status 1
We can use @banjopc's existing topic for further discussion of the display problem:
Since the upload failure that was the primary subject matter of this topic has been resolved, I'll close this topic to avoid the possibility of ending up with parallel discussions about the display/I2C problems in two separate topics.
