Good morning, I'm doing a project, but I'm new to programming and I'm having trouble getting Espalexa's callback to go back to the off state
do not notice the programming because I believe that they are not very correct
#include <HX711_ADC.h> // need to install
#include <Wire.h>
#include <LiquidCrystal_I2C.h> // need to install
#define pinCem_gramas 18
#define pinCinquenta_gramas 19
#define pinLed 13
#define pin_motor 5
#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
#endif
#include <Espalexa.h>
HX711_ADC LoadCell(26,25); // parameters: dt pin 6, sck pin 7;
LiquidCrystal_I2C lcd(0x27, 16,2); // 0x27 is the i2c address might different;you can check with Scanner
float peso ;
float LIG ;
* This is a basic example on how to use Espalexa and its device declaration methods.
#include <WiFi.h>
#else
#endif
// prototypes
boolean connectWifi();
//callback functions
void firstLightChanged(uint8_t brightness);
void secondLightChanged(uint8_t brightness);
void thirdLightChanged(uint8_t brightness);
// Change this!!
const char* ssid = "";
const char* password = "";
boolean wifiConnected = false;
Espalexa espalexa;
//EspalexaDevice* device3; //this is optional
String Device_1_Name = "Cem";
String Device_2_Name = "Cinquenta_gramas";
LoadCell.begin(); // start connection to HX711
LoadCell.start(2000); // load cells gets 2000ms of time to stabilize
LoadCell.setCalFactor(5285.46); // calibration factor for load cell => dependent on your individual setup
lcd.init();
lcd.backlight();
pinMode( pinCem_gramas, OUTPUT);
pinMode( pinCinquenta_gramas, OUTPUT);
pinMode( pinLed, OUTPUT);
pinMode( pin_motor, OUTPUT);
// Initialise wifi connection
while (! connectWifi () ) {
digitalWrite (pinLed, HIGH) ;
// Define your devices here.
espalexa.addDevice("Cem_gramas", firstLightChanged,0); //simplest definition, default state off
espalexa.addDevice("Cinquenta_gramas", secondLightChanged, 0); //third parameter is beginning state (here fully on)
device3 = new EspalexaDevice("Light_3", thirdLightChanged); //you can also create the Device objects yourself like here
espalexa.addDevice(device3); //and then add them
device3->setValue(128);
//LIG =device3->setValue(0); //this allows you to e.g. update their state value at any time!
espalexa.begin();
} //else
//while (1) {
//Serial.println("Cannot connect to WiFi. Please check data and reset the ESP.");
//delay(2500);
espalexa.loop();
Serial.print ("Peso ");
Serial.print (LoadCell.getData(), 3);
peso = LoadCell.getData();
LoadCell.update(); // retrieves data from the load cell
float peso = LoadCell.getData(); // get output value
lcd.setCursor(0, 0); // set cursor to first row
lcd.print("Weight[g]:"); // print out to LCD
lcd.setCursor(0, 1); // set cursor to second row
lcd.print(peso); // print out the retrieved value to the second row
if(peso > 100)
digitalWrite(pin_motor,LOW);
Serial.println("OFF");
delay(1);
//our callback functions
void firstLightChanged(uint8_t brightness) {
Serial.print("Device 1 changed to ");
//do what you need to do here
//EXAMPLE
if (brightness) {
Serial.print("ON, brightness ");
Serial.println(brightness);
digitalWrite (pinCem_gramas, 255) ;
digitalWrite (pin_motor, 255) ;
else {
digitalWrite (pinCem_gramas, LOW) ;
digitalWrite (pin_motor, LOW) ;
void secondLightChanged(uint8_t brightness) {
if (brightness) {
digitalWrite (pinCinquenta_gramas, HIGH) ;
else {
Serial.print("OFF, brightness ");
digitalWrite (pinCinquenta_gramas, LOW) ;
void thirdLightChanged(uint8_t brightness) {
// connect to wifi – returns true if successful or false if not
boolean connectWifi(){
boolean state = true;
int i = 0;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connecting to WiFi");
// Wait for connection
Serial.print("Connecting...");
Serial.print(".");
if (i > 20){
state = false; break;
i++;
Serial.println("");
if (state){
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
else {
Serial.println("Connection failed.");
return state;
here my problem
if(weight > 100)
on line 121 to 124 I need that after I have the weight information, turn off the calback firstLightChanged
