Help! Compiling error
for some reason the IDE now freaks out when I try to compile any sketches, it worked fine a few days ago. I've even tried reinstalling the whole IDE (im using vers 18)
here's what I get when I hit the compile button:
java.lang.NullPointerException
      at processing.app.debug.Compiler.compile(Compiler.java:75)
      at processing.app.Sketch.build(Sketch.java:1412)
      at processing.app.Sketch.compile(Sketch.java:1203)
      at processing.app.Editor$44.run(Editor.java:1807)
      at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
      at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
      at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
      at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
      at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
      at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
      at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
      at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
any help would be greatly appreciated, I just want to know what's going on so I can get my arduino back up and running!
it COULD be something mysterious but first look for mismatched "s or something similar.
if you can't find it, post your sketch.
Unfortunately I think this is a problem with my computer itself, considering I get the exact same error with ALL sketches including examples, etc. So the problem cant be in the code. Anyone ever encountered this before?
Your system (like most) probably has several copies of java installed. they should not interact but...
Try deleting/renaming the java folder inside arduino then restart the ide.
Its possible your machine got a newer java version installed recently, one that doesn't work with the Arduino IDE - check the release notes about version requirements.
I haven't seen that happen and there's nothing in the release notes. I HAVE seen ide issues cured by dropping the version of java packaged with it in favour of a newer one.
Hmm, still no idea what went wrong, but I deleted 18 and reinstalled version 17 of the ide and everything's A OK, guess there must have been some compatibility problem? Thanks for the help everyone, it was all much appreciated, I'm just happy I can use my duino again! :slight_smile:
So, you can have multiple versions of the IDE installed. If you now install 18 again, does it work?
