Hello friends!
I want to consult with you about a project I am doing.
At the center of my project is Arduino Nano v3. There are several components connected to the Arduino and they are:
ultrasonic HC-04
gps module neo6
mp3 module pro DFR0768 3.3v-5v
color sensor module Tcs3200
touch sensor module TTP223B 2 ~ 5.5V DC
2 vibration motors
2 speakers 5w
2 linear voltage stabilizers, one outputs a voltage of 5 volts and the other 3.3 volts.
In addition, I have a buzzer, LEDs and a push button.
The main idea is that there are 4 push buttons (without locking) and with each push I activate one of the sensors I mentioned above.
*Pressing button 1 will transfer the device to the state of knowing the time and date by the GPS module. Touching the touch sensor will give a voice indication of this data.
*Pressing button 2 will move the device to the position of and location by the gps module. Touching the touch sensor will give a voice indication of this data.
*Pressing the button 3 will move the device to a position where it checks the distance with the ultrasonic sensor, touching the touch sensor will give a sound indication of this.
*Pressing the number 4 button will give information about the color detected by the color sensor and voice indication as above.
Each time one of the buttons is pressed, another LED will light up to indicate the state the device is in.
The vibration motors will operate when a certain location/color/distance is detected by one of the sensors according to what I decide to set.
I know this is a very complicated project in terms of software, but right now I'm focusing on the hardware. When I finish building a correctly built circuit I will also need you for the software..
I would love to present my circuit and receive comments from you on whether the circuit is connected correctly and what needs to be fixed, Have I connected to correct arduino pins and is my power supply to arduino correct, And in general, do you think this thing will work?
I hope my sketch is not cumbersome and you can understand what you see.
In addition, I would appreciate your recommendation on a good power source that can fit the entire system. I thought about a 7.2 volt battery, but I'm not sure about that.
The power input is on the left side into the connector and next to that there are 2 voltage stabilizers, the upper one is of 5 volts and the lower one is of 3.3 volts. The rest of the buttons and modules are pretty clear I think and with an adjacent caption.
I still don't know how to create a scheme with labels so that the circuit still looks like a collection of snakes and noodles. Forgive me for that..
I am attaching some pictures, some of them focus on part of the circle for better resolution.If the photos are not good, I will send more
General photo:
Top photo:
Photo of the lower part:
