Help in interfacing Arduino Mega and Arduino Mini with 12VDC solenoid valve
I am planning to use these 2 solenoid valves. Each has different function, and I will design separate circuit for each solenoid. I will be using Arduino MEGA for the first solenoid valve, and planning to use Arduino mini for the second one as it just needs button to function.
  1. This solenoid I will use it as a gate valve to close and open the passage of air depending on the time I set (e.g. When I push the start button the solenoid valve will operate 1 cycle = open for 5 seconds, close for 10 mins. this cycle should be done for 6 times continuously).
    Important Specs: N.C, 12VDC, 4.5W
    Link: https://docs.rs-online.com/b218/0900766b815dd865.pdf
  2. This solenoid valve will control a pneumatic cylinder. It will function to close when the button_A is pushed and will open when button_B is pushed.
    Important Specs: N.O, 12VDC, 3W
    Link: https://docs.rs-online.com/4e8c/0900766b813dc1c6.pdf
Now, I only have this MOSFET available, and I am not sure on how to proceed with designing the connection of my components. Here is the list of my components that I can choose from:
a. 2SK3565 – N channel MOSFET (https://www.mouser.com/datasheet/2/408/2SK3565_datasheet_en_20131101-1760763.pdf)
b. AQY212S - Solid state relay
c. AQY412EHAX - Solid state relay
I know I got to use a freewheeling diode across the solenoid valve to handle the back EMF from the solenoid when it turns off. But for the first solenoid valve, I will be using this indicating that it has surge voltage suppression. Does it mean I don’t have to place a diode anymore?
I also want to consider using relay, but I don’t want to be dependent on the relay as based on the articles I read relay is mostly used when dealing with AC and MOSFET can be used instead as these solenoid valves are DC operated.
I want to get insights on how I can do my design connections, given the components I must choose from.
Also, my power supply is a switching adapter labels 12V, 1A and wanted to have to power both the solenoid valve and the Arduino board. It’s possible right? Or is it not recommended as I have seen other are recommending to use optocoupler etc.
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Hi I'm sorry I can't delete this post as I came to realize that this question is more suitable to be posted on hardware category.
As you are sure that this topic belongs in the hardware category, although I am not sure that I agree, I have moved it there
