Help! Lcd 2.8' touch screen
Hi everybody,
I have 2.8' LCD module, have SD card .On board have 1 IC: XPT2046 (Touch IC) and 2-row header(total 34 pin)
I'm using Adafruit_TFTLCD library.
and Adafruit_GFX library for Arduino
I open : graphictest examples program in Adafruit_TFTLCD library.
When i running program Serial print:
TFT LCD test
Using Adafruit 2.8" TFT Breakout Board Pinout
Unknown LCD driver chip: 3535
If using the Adafruit 2.8" TFT Arduino shield, the line:
  • #define USE_ADAFRUIT_SHIELD_PINOUT*
    should appear in the library header (Adafruit_TFT.h).
    If using the breakout board, it should NOT be #defined!
    Also if using the breakout, double-check that all wiring
    matches the tutorial.
" :confused: :confused: :confused: :confused:
Tft-t280bqa
