HELP! Loop will execute only the last move and then stop... if timers are inserted the "if" statement is ignored
just need gear to motor to move fwd and rev to specified positions... nothing super percise.. i can individually move each but when run all together is runs the last statment and stops...
int in_1=2; // defines in_1
int in_2=3; // defines in_2
int FBVAL; // FBVAL IS ACTUAL INT
int FBPIN; // defines loaction of feed back
pinMode(9,OUTPUT) ; //we have to set PWM pin as output
pinMode(in_1,OUTPUT) ; //Logic pins are also set as output
pinMode(in_2,OUTPUT) ;
int FBPIN = A0; // select the input pin for the potentiometer
int FBVAL = 0;
void loop(){
//CW in_1=HIGH in_2=LOW
//CCW in_1=LOW in_2=HIGH
//cw
int FBVAL = analogRead(A0);
Serial.println(FBVAL);
analogWrite(9,255);
digitalWrite(in_1,HIGH);
digitalWrite(in_2,LOW);
if ((FBVAL)>=140) {digitalWrite (in_1,LOW);};
// would also like a delay here
analogWrite(9,200);
digitalWrite(in_1,LOW);
digitalWrite(in_2,HIGH);
if ((FBVAL)<=1) {digitalWrite (in_2,LOW);};
analogWrite(9,100);
if ((FBVAL)>=160) {digitalWrite (in_1,LOW);};
What exactly are you trying to do?
All the statements in loop will run almost instantly... over and over.
just stops humm.
void loop(){
//cw
analogWrite(9,255);
analogWrite(9,200);
analogWrite(9,100);
Serial.print( " plucky " );
When you add the serial print does it only print one time or many times? If it prints many times it did not just stop.
Help us help you.
