Help me debug ina333 load cell wiring (videos included)
Hi everyone, I'm doing a sim pedal project with hall sensors and load cell.
Before putting all components on perf board, the load cell + ina333 was working fine. (connected with wires). Now after connecting them on a perfboard (with jst-xh connectors), analogRead on A0 is always around 520.
The hall sensors work fine.
The wiring diagram I followed is included. I also took pictures of both sides of the perfboard and marked my connections. I'm willing to provide more if needed. Here is a list of what I tried doing:
  • recrimping jst-xh connector and testing I have same signal on ina333 pin an load cell side (good)
  • bought NEW ina333 board because on the old one I shorted the trim pot.
  • tried cleaning flux around ina333 pins (resulted in more stable readings, but still not reacting to load cell pressure)
  • twisting the trim pot screw (no difference)
  • changing from A0 to A3 (same readings)
  • tested with multimeter all connections (no shorts)
  • disconnecting VREF - GND connection on the ina333 board
Then I went to clean the flux more and record these videos of testing continuity of pins around the load cell (linked bellow).
At this point it was around 16h since I last plugged it in, and after plugging it in serial monitor was displaying 0 constantly and it was responsive to the load cell. This lasted around 30 seconds, then it had some noise where it jumped to ~300, back to 0 and then back to ~560 and now it stays around there.
Any ideas what could be causing this?
Videos:
ProMicro pins look unsoldered (but for a couple). Post oblique image of ProMicro soldering.
Yes correct, I soldered only the ones used, plus some extra ones to make it more sturdy.
Common practice is to make all connections, so transient voltage or non-terminated wires have no effect.
Okay, I will now do that. In the meanwhile I recorded my serial output after letting the board disconnected about 45mins.
You can see that at the start value is 0 and values are responsive to the load cell pressure, after a while it starts spazzing out with values increasing eventually stopping around 350-600.
  • In the future, solder Dupont type female headers on the protoboard, plug the micro (with male headers) onto the PCB.
    Solder all header connections.
    If you have the option of using machine pin headers, do so.
  • Also, clean your protoboard solder connections using a tooth bush and IPA.
FYI
Thanks for linking the docs, useful stuff.
Now I soldered all of the arduino pins @xfpd , and cleaned the whole board again, but the outcome is still the same - like in my last video of the arduino IDE, works for 20sec when left disconnected for a longer period of time. If I reconnect too soon, it starts with the random values spazzing from the start.
  • If the above is correct, you might have damaged components in the interim, you may have a soldering connection problem or you have not wired all connections.
  • You can use an ohmmeter to confirm connections, check for opens, check for adjacent pin shorts.
  • Use a voltmeter to confirm voltages going to pins, connectors and off board components.
  • This does not look good:
