Help me to find out the coding of this project
Can you guys help me to find out the coding of this project?
Please don't hijack threads @dimas130926 . I have split your post out to its own topic.
Hijacking is against the Arduino forum rules. The reason is that it may sidetrack the discussion, even preventing the creator of the topic from getting the assistance they need. It also reduces your own chances of getting assistance.
This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Where did you get the circuit you posted?
A very quick search and I found this in this.https://www.viralsciencecreativity.com/post/arduino-rfid-door-lock-system-with-lcd-display
ok, Thank You
I have tried it but RFID Reade can't read RFID cards (:slight_smile:
In the Arduino IDE, click on Edit, then Copy for Forum, that will copy your code.
Then come here and just do a paste. Then we can analyse your code.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
int relayPin = 7; // Pin yang terhubung ke relay
// Daftar ID kartu yang diizinkan
String allowedIDs[] = {
"YOUR_RFID_ID_1", // Ganti dengan ID kartu RFID yang valid
"YOUR_RFID_ID_2" // Ganti dengan ID kartu RFID yang valid
Serial.begin(9600); // Initialize serial communications
SPI.begin(); // Initialize SPI bus
rfid.PCD_Init(); // Initialize RFID reader
pinMode(relayPin, OUTPUT); // Set pin relay sebagai output
digitalWrite(relayPin, LOW); // Pastikan relay mati
Serial.println("Scan your RFID card...");
// Jika ada kartu yang terdeteksi
if (rfid.PICC_IsNewCardPresent() && rfid.PICC_ReadCardSerial()) {
String id = "";
for (byte i = 0; i < rfid.uid.size; i++) {
id += String(rfid.uid.uidByte[i], HEX);
id.toUpperCase(); // Ubah ID menjadi huruf besar
Serial.print("ID Kartu: ");
Serial.println(id); // Tampilkan ID di Serial Monitor
// Cek apakah ID ada dalam daftar yang diizinkan
bool accessGranted = false;
for (int i = 0; i < sizeof(allowedIDs) / sizeof(allowedIDs[0]); i++) {
  if (id == allowedIDs[i]) {
    accessGranted = true;
if (accessGranted) {
  Serial.println("Access Granted");
  digitalWrite(relayPin, HIGH); // Nyalakan relay
  delay(5000); // Biarkan solenoid aktif selama 5 detik
  digitalWrite(relayPin, LOW); // Matikan relay
  Serial.println("Access Denied");
delay(2000); // Tunggu 2 detik sebelum membaca kartu lagi
rfid.PICC_HaltA(); // Hentikan kartu
2nd coding
#include <Wire.h>
#include <SPI.h>
LiquidCrystal_I2C lcd(0x3F, 16, 2);
#define SS_PIN 10
#define RST_PIN 9
#define LED_G 4 //define green LED pin
#define LED_R 5 //define red LED
#define BUZZER 2 //buzzer pin
#define lock 3
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
int Btn = 6;
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
pinMode(LED_G, OUTPUT);
pinMode(LED_R, OUTPUT);
pinMode(BUZZER, OUTPUT);
noTone(BUZZER);
pinMode(Btn,INPUT);
pinMode(lock,OUTPUT);
Serial.println("Place your card on reader...");
lcd.backlight();
lcd.clear();
lcd.setCursor(0,0); // column, row
lcd.print(" Scan Your RFID ");
lcd.setCursor(0,1); // column, row
lcd.print(" Door Locked ");
if(digitalRead(Btn) == HIGH){
digitalWrite(LED_G, HIGH);
lcd.print(" Door Un-Locked ");
tone(BUZZER, 2000);
delay(100);
noTone(BUZZER);
delay(50);
tone(BUZZER, 2000);
delay(100);
noTone(BUZZER);
digitalWrite(lock,HIGH);
delay(3000);
digitalWrite(lock,LOW);
delay(100);
digitalWrite(LED_G, LOW);
tone(BUZZER, 2000);
delay(100);
noTone(BUZZER);
delay(50);
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "83 23 38 BB") //change here the UID of card/cards or tag/tags that you want to give access
tone(BUZZER, 2000);
delay(100);
noTone(BUZZER);
delay(50);
tone(BUZZER, 2000);
delay(100);
noTone(BUZZER);
delay(3000);
delay(100);
tone(BUZZER, 2000);
delay(100);
noTone(BUZZER);
delay(50);
lcd.print("Invalid RFID Tag");
Serial.println(" Access denied");
digitalWrite(LED_R, HIGH);
tone(BUZZER, 1500);
digitalWrite(LED_R, LOW);
noTone(BUZZER);
delay(100);
tone(BUZZER, 1500);
noTone(BUZZER);
delay(100);
tone(BUZZER, 1500);
noTone(BUZZER);
You did not follow my instructions.
I'm sorry, wait
#include <Wire.h>
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
#define lock 3
int Btn = 6;
  noTone(BUZZER);
  pinMode(Btn,INPUT);
  lcd.backlight();
  lcd.clear();
    tone(BUZZER, 2000);
    delay(100);
    noTone(BUZZER);
    delay(50);
    tone(BUZZER, 2000);
    delay(100);
    noTone(BUZZER);
    delay(3000);
    delay(100);
    tone(BUZZER, 2000);
    delay(100);
    noTone(BUZZER);
  delay(50);
    return;
    return;
  String content= "";
  byte letter;
    tone(BUZZER, 2000);
    delay(100);
    noTone(BUZZER);
    delay(50);
    tone(BUZZER, 2000);
    delay(100);
    noTone(BUZZER);
    delay(3000);
    delay(100);
    tone(BUZZER, 2000);
    delay(100);
    noTone(BUZZER);
    delay(50);
    tone(BUZZER, 1500);
    noTone(BUZZER);
    delay(100);
    tone(BUZZER, 1500);
    noTone(BUZZER);
    delay(100);
    tone(BUZZER, 1500);
    noTone(BUZZER);
Much bettor
I don't see an LCD, LEDs, a buzzer or a button in your photo?
So how do you know it is not reading the RFID
Initially I used an LCD but it wasn't detected, so I simplified without an LCD and looked at it on the serial monitor
This is coding without LCD and LED
#include <SPI.h>
#define SS_PIN 10
#define RST_PIN 9
    String id = "";
I need to see the code you are actually using, not something from a website.
I also need to see a wiring diagram of your actual connections, not something from a website
Wait. I'll show you a more detailed photo of my diagram
Do you understand how difficult it is to help if you ask questions about one combination of hardware and code but your posts contain completely different hardware and code? I would think most people would find that quite obvious.
Sorry, sorry, I just realized that the GND pin of the RFID reader is on the wrong pin
now it is accessible,
Just fix the door lock selenoid code. can you help me from the start?
It's no good. I can't see if you have things connected right from those photos.
