[Help] Modbus + Shield RS485 + Regulator
Hello to all,
I am currently working on a project to recover analog information (temperature in particular...) from an Ascon controller, the X5 to be precise, in order to be able to do monitoring.
To communicate, the controller uses the Modbus protocol in RS485, I have at my disposal the specific Modbus table for my controller (see Modbus ascon from page 59 to page 75).
On the hardware side, I have an Arduino Mega and a RS485 TTL Shield (https://www.fiabiparkp.com/index.php?main_page=product_info∏ucts_id=529549).
I have pretty much understood how the Modbus protocol works:
you enter the address of the slave, the function you want it to perform, the address from which it starts to perform this function and then the number of registers to which it is applied.
For example, in my case if I want to read a value: Ox02 (address of my controller)
Ox03 or 04 ( to read) Ox40 ( 64 in decimal to read a status ) Ox 01 ( we read a register)
In my case, my arduino board works as a master while my controller works as a slave.
I come to my problem(s):
*The first one is the pure wiring (see wiring diagram), I don't know where to connect the RxD & TxD pins of my shield, for the moment they are at the level of pins 10 & 11 because I use the "software serial" library as well as if I have to wire my controller in Slave mode.
*The second one is on the software level, I'm a bit overwhelmed with the information and I don't know which libraries to use. For the moment, I use the serial software libraries and ModbusRtu.
Here is my current code:
#include <ModbusRtu.h>
#include <SoftwareSerial.h>
// data array for modbus network sharing
uint16_t au16data[16];
uint8_t u8state;
 *  Modbus object declaration
 *  u8id : node id = 0 for master, = 1..247 for slave
 *  u8serno : serial port (use 0 for Serial)
 *  u8txenpin : 0 for RS-232 and USB-FTDI
 *               or any pin number > 1 for RS-485
Modbus master(0); // this is master and RS-232 or USB-FTDI via software serial
 * This is an structe which contains a query to an slave device
modbus_t telegram;
unsigned long u32wait;
SoftwareSerial mySerial(10, 11);//Create a SoftwareSerial object so that we can use software serial. Search "software serial" on Arduino.cc to find out more details.
  Serial.begin(9600);//use the hardware serial if you want to connect to your computer via usb cable, etc.
  master.begin( &mySerial, 9600 ); // begin the ModBus object. The first parameter is the address of your SoftwareSerial address. Do not forget the "&". 9600 means baud-rate at 9600
  master.setTimeOut( 2000 ); // if there is no answer in 2000 ms, roll over
  u32wait = millis() + 1000;
  u8state = 0;
  switch( u8state ) {
  case 0:
    if (millis() > u32wait) u8state++; // wait state
  case 1:
    telegram.u8id = 0x02; // slave address
    telegram.u8fct = 0x03; // function code (this one is registers read)
    telegram.u16RegAdd = 0x40; // start address in slave
    telegram.u16CoilsNo = 0x03; // number of elements (coils or registers) to read
    telegram.au16reg = au16data; // pointer to a memory array in the Arduino
    master.query( telegram ); // send query (only once)
    u8state++;
  case 2:
    master.poll(); // check incoming messages
    if (master.getState() == COM_IDLE) {
      u8state = 0;
      u32wait = millis() + 2000;
        Serial.println(au16data[0]);//Or do something else!
        Serial.println(au16data[1]);//Or do something else!
        Serial.println(au16data[2]);//Or do something else!
        Serial.println(au16data[3]);//Or do something else!
        Serial.println(au16data[4]);//Or do something else!
        Serial.println(au16data[5]);//Or do something else!
        Serial.println(au16data[6]);//Or do something else!
        Serial.println(au16data[7]);//Or do something else!
        Serial.println(au16data[8]);//Or do something else!
        Serial.println(au16data[9]);//Or do something else!
        Serial.println(au16data[10]);//Or do something else!
        Serial.println(au16data[11]);//Or do something else!
        Serial.println(au16data[12]);//Or do something else!
        Serial.println(au16data[13]);//Or do something else!
        Serial.println(au16data[14]);//Or do something else!
        Serial.println(au16data[15]);//Or do something else!
thank you in advance
Regards
Schéma cablage.pdf (168 KB)
your keyboard is defect, too :slight_smile:
Hello,
The link to your RS485 module does not open on my pc.
Hence my question: how is direction control organized in your module:
If you want to send, the module goes to low impedance state on A and B and defines the state of the RS485bus,
in high impedance, the module listens to the bus.
Some modules require some kind of "enable" signal to define whether you want to send or to receive data.
Other question: how is your bus terminated, normally RS485 buses must be terminated with the approriate resistor value, is this the fact?
Last but not least: the first thing you can do is measure the voltage between A en B, if you do not see any difference (with a good multimeter that is fast enough), then you know at least one thing. (or use LED's to signal live data on the bus)
Best Regards,
johi.
