HELP NEEDED please help code problem
Im doing a project on making a robot dog where i control it using 8 servo motors but for some reason the app wont make servo the move.im using mit app inventor for the app and for the comands i have tested it without anything so im pretty sure that it would work but the problem is that when i press the button on the app nothing works.
This is the code for my project
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#include <SoftwareSerial.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN 90
#define SERVOMAX 650
uint8_t servonum = 0;
 int bluetoothTx = 7;
 int bluetoothRx = 8;
 SoftwareSerial Bluetooth(bluetoothTx, bluetoothRx);
 char Received;
 int sit_state = 0;
 int shake_state = 0;
 int wag_state = 0;
 int walk_state = 0;
  pinMode
  Bluetooth.begin(9600);
  Serial.println("16 channel Servo test!");
  pwm.begin();
  pwm.setPWMFreq(60);
  if (Serial.available() > 0) {
    Received = Serial.read();
  ////////// sit //////////
  if (sit_state == 0 && Received == '1') {
    sit_state = 1;}
  if (sit_state == 1){
    for (int legle = 45; legle < 135; legle += 10) {
      delay(50);
      pwm.setPWM(5, 0, angleToPulse(45));
      pwm.setPWM(3, 0, angleToPulse(125));
      pwm.setPWM(2, 0, angleToPulse(40));
    Serial.println("sit");
    sit_state = 0;
  ////////// shake //////////
  if (shake_state == 0 && Received == '3') {
    shake_state = 3;
    for (int i = 0; i < 16; i++) {
      for (int shak = 45; shak < 450; shak += 10) {
        delay(50);
        pwm.setPWM(6, 0, shak);
        pwm.setPWM(7, 0, shak);
    shake_state = 0;
  ////////// wag //////////
  if (wag_state == 0 && Received == '5') {
    wag_state = 5;
        delay(50);
      for (int shake = 450; shake > 90; shake -= 10) {
        delay(50);
        pwm.setPWM(7, 0, shake);
    wag_state = 0;
  ////////// walk //////////
  if (walk_state == 0 && Received == '7') {
    walk_state = 7;
       for (int legle = 90,  leglee = 530; legle < 530,leglee > 90; legle += 30, leglee -= 30) {
        delay(50);
        pwm.setPWM(0, 0, legle);
        pwm.setPWM(2, 0, legle);
        pwm.setPWM(1, 0, leglee);
        pwm.setPWM(3, 0, leglee);
      // see YouTube video for details (robojax)
    // robojax PCA9865 16 channel Servo control
    delay(300);  // wait for 1 second
    walk_state = 0;
int angleToPulse(int ang) {
  int pulse = map(ang, 0, 180, SERVOMIN, SERVOMAX);
  Serial.print("Angle: ");
  Serial.print(ang);
  Serial.print(" pulse: ");
  Serial.println(pulse);
  return pulse;
And this is the building blocks i use for the app
The bluetooth connects fine but nothing works and it even gives me a broken wire error message in the app
Hi, and welcome!
When is the deadline?
Make a test sketch to operate only one servo. Do that for each servo.
... because you have some copy/paste errors.
Welcome to the forum. You'll find we're focused on helping you get your project working. To do that, we need some information, as outlined here:
Primarily, your first post gives us no information about how your project is built - how it is wired. A photo might be good, but a schematic would be much better. Without any of that, how are we to know if you've got anything wired at all?
The library you are using says you are using this device...
But you say this...
And your code says this...
You are heading in two directions. Describe the equipment you have and your goal. "A robot dog" is not a valid answer, describe how this project will function.
Do i test the motor using the servo driver??
Im sorry this is my first time making something like this so im unsure about which website i should use to make the schematic.the one i found didnt have a bluetooth or server driver
A photo of a hand drawn circuit is good enough as long as it shows all of the components, the pin numbers being used, all of the interconnections between the components and how they are all powered
Hii,the deadline is 5 may
See post #8. Draw what you have, if we need more we can ask, but if we don't have anywhere to start from it's about impossible to help you.
Its for a school project the robot is made of plastic pvc board for the outer part and for the inside im gonna use 8 motors,an arduino uno and a server drive to control it (i also have a bread board incase thats needed but so far we havent found a use for it) and my team is using the motors to control the dog like this
download (1)
The motors do not control the robot. The motors are controlled by something... you say "app inventor."
You wrote the app wrong. Define nothing, because your shaky video shows servos moving.
Is this good enough? Im sorry if the motor part is a bit messy
  1. Remove all Servos from the multiplexer.
  2. Add one servo to the multiplexer.
  3. Run a sketch for only one servo.
  4. Move the one servo to the next multiplexer port.
  5. Repeat step 3.
  6. Add servos to the mux and add servo ports to the sketch until you get a failure.
Your power supply says "3.7v"... what is the voltage of each servo? Are they all the same? Assuming the voltage is adequate, each servo starts up by going to home/90 degrees and sinks 1.5A... each... and I count nine servos (your text says eight), so the total current just for the servos is 13A. Maybe your power supply is not adequate? Show the specifications of the servo.
Mit app inventor is a website and im sorry if the video is bad because the parts are at school so i cant make another recording and the battery ran out so im trying to buy another one . The robot can move because of the motors, the one in the video is for the legs 4 motors are for the legs 1 motor is for the tail and 2 are for the head (1 for the face and the other is for the neck)
Sorry i did that drawing really late the servo is 8 and my friend did test out the code already and it does work fine but the only problem is that it cant connect to the app and im not sure whats the problem cause i use this vid as a refrence
The specifications for the motor is this
My friend said that were using 8 motors byt im not sure what the extra motor is going to be use for
Solve this first.
You need to read the answers from the helpers.
