Help on 1284p bootloader :(
Hi every one :slight_smile:
plz i need help to connect my ATmega1284p with FT232R
i make a board, and i cant connect it to the PC :frowning:
it was my job, i got this old board, and my job was make a new one,
so i got an old schematic and redesign it, like the original board, new processor mega1284p with the same pins like the original ...
but i cant not connect it to the pc
i have connection to the board, com4 , but i cant install any program , i tried Arduino - Atmel Studio 7.0 - BASCOM-AVR ( like the original code on the old board was written by BASCOM) .. but no connection , the pc can not define the micrcontroller so i cant not send code to it !
what is missing ? and this con7 on the schematic , i have no idea why is it here .
i am an electrical , i have not much info about microcontrollers .
the man who made it back on 2007 is dead, and i got this work to redesign it, but i need help .
thanks alot
Reset circuit is missing. It should be DTR from FT232RL. See original Arduino UNO R3 schematics.
But you can see its COM port, can you? So, it is connected.
And if its a 'new processor mega1284p' you will need to burn the bootloader to load programs from the FT232.
And its often not helpful to only show part of a schemtic, there could be other parts of the circuit causing problems.
Budvar10:
ok i will take a look ... thanks
yes after installing FT232R-USB_Driver i got a connection on com4, but i dont know if that is enough to say the chip is right connected, i dont know this man how he did it like this ...
i will try, thanks
srnet:
yes, i made a new board, but the old chip atmegaXX i forget what it was, i could not find it, it is too old, i got a replacement with same pins mega1284p .
i thought it is just connect & run.
any way, thanks , i will try to do more research
FT232 is ATmega's interconnect to PC.
ATmega needs:
  1. power
  2. clock/crystal
  3. reset circuit - missing
  4. a bootloader uploaded via ISP - ? (pointed by @srnet).
Budvar10:
ATmega needs:
  1. power
  2. clock/crystal
1 - it is ok, runnig 5V
2- i have 16000Hz
3 - i fixed now, DTR to Rest with R 10k and 100nF this like this scheamtic
4- hmmm, so i have to look for a way to uploaded a bootloader on it ... still to be done
FT232R?
Maybe COM4 is for something else?
You'll need to check which uart IC you're using and install drivers for it.
Ok
i made like this
https://www.instructables.com/id/How-to-use-Arduino-Mega-2560-as-Arduino-isp/
because i have an Arduino-Mega-2560
i made the connection direct to my atmega1284p to the right contacts
mosi - miso - sick - rest
+ 5v power + 16000Hz crystal
but i keep gotting this error
Device signature = 0xffff00
Expected signature for ATmega1284P is 1E 97 05
what is missing here ? wrong connection some where ? i cheeked 100 times i correct it
before that i got other error , now this one
i dont know what is missing in my connection or i have to modfi the programmer Arduion as ISP
**thanks **
Some FF in response could be caused by shortage on wires.
Anyhow, post whole log include command at the top and check pins on 2560 according the sketch you've used.
