Help regarding project
Hi am using blynk cloud I have created multiple events on my device for temp,gas,c02
But after receiving only one notification alert it’s showing event limit reached after 24 hours it’s showing the same after receiving one notification alert for any of the sensor
pls help me out !!
If I told you that I had a problem with some code that I did not post would you be able to help me ?
Can you see what I am getting at ?
Post your full sketch and use code tags when you do
Help us help you.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Please post a schematic.
Please post an image of your project.
Please describe the problem better then you just did.
