Help required for model railway project
Hi all, this is my 1st attempt at (I take no credit for the code/wiring) Arduino. This a Model railway project to move a Turnout by a servo & light a LED at the press of a push button switch. I have made a Frizing image from a Jpeg picture image.
The help I need is;
The Wiring
1 is the push button wiring correct
2 is the breadboard wiring correct
3 can the breadboard wiring be tidied up (I eventually want to increase it to10 LEDs and 5 Servo's and transfer it all to PCB).
The Code ( I am a complete newbie when it comes to code)
4 I need the code to be altered to move only 1 servo between 90derees to 110degrees and to turn 1 LED on and a 2nd LED off and vise versa when the servo go's in opposite direction.
Hopefully then I can compare the 2 codes and work out how include the other 2 servo's and LED's (and eventually add 2 more making 5)
I hope I have explained myself properly and any help or advise would very appreciated. Many thanks Terry
Added Images
Operating 3 Servos & 6 LEDs by push buttons_bb.pdf (1.23 MB)
Please do not use word documents. You can post your code (it was small enough, definitely when using a second post :wink: ) using code tags.
type
** **[code]** **
paste the code
type
** **[/code]** **
So the result looks like below (your code)
#include <Servo.h> // include the Servo library
// Definitions
// Basic parameters; adjust for your actual setup
#define NUMBER_OF_TURNOUTS 5
#define NUMBER_OF_SHIFT_REGISTERS 3
#define STEP_DELAY 70  // servo movement step delay, in milliseconds
// Data Structures
// TURNOUT_DEF holds all configuration
// information about turnouts and panel LEDS
typedef struct TURNOUT_DEF {
  uint8_t button_pin; // Digital or analog pin for the button associated with this turnout
  uint8_t servo_pin; // Digital pin for the servo associated with this turnout
  int pos_main; // servo position for the MAIN leg, in degrees
  int pos_div; // servo position for the DIVERGENT leg, in degrees
  int panel_LED_main_green; // The position(s)of panel LEDS in the shift register chain
  int panel_LED_main_red; // Example assumes a bi-color (red/green) LED for each turnout leg
  int panel_LED_div_green; // modify these elements to reflect the actual LEDS you are using
  int panel_LED_div_red;
// TURNOUT_DATA is wrapper structure holding
// both configuration and runtime data for turnout operation
typedef struct TURNOUT_DATA {
  TURNOUT_DEF data; // configuration
  bool is_moving;
  byte alignment;
  int pos_now;
  int target_pos;
  unsigned long last_move;
// Alignment state values
#define ALIGN_NONE 0
#define ALIGN_MAIN  1
#define ALIGN_DIVERGENT 2
// pin ids for shift register chain controlling panel LEDS
#define LATCH_PIN 7
#define CLOCK_PIN 8
#define DATA_PIN 9
// Global variables
// TURNOUT_DATA Array
// * A0, A1, etc refer to analog pins which are used for buttons in this example
// * Replace pos_main (93) and pos_div (117) with real values for each turnout
// * LEDS are identified by their output position in the shift register chain;
// the identifier is a number between 0 and (NUMBER_OF_SHIFT_REGISTERS * 8) - 1.
// Example assumes LEDS are connected to shift register outputs sequentially
// from the first output of first register. You can connect LEDS to any output in
// any order; just set the identifiers accordingly.
// Only the TURNOUT_DEF part of the TURNOUT_DATA structure has to be initialized here;
// The remaining elements are managed internally and are initialized automatically
TURNOUT_DATA turnouts[NUMBER_OF_TURNOUTS] = {
  {{A0, 2, 93, 117, 0, 1, 2, 3}},
  {{A1, 3, 93, 117, 4, 5, 6, 7}},
  {{A2, 4, 93, 117, 8, 9, 10, 11}},
  {{A3, 5, 93, 117, 12, 13, 14, 15}},
  {{A4, 6, 93, 117, 16, 17, 18, 19}}
// servo objects
Servo servos[NUMBER_OF_TURNOUTS];
// array to hold shift register state bytes
byte panel_LEDS[NUMBER_OF_SHIFT_REGISTERS];
  // Setup pins for shift register chain
  pinMode(LATCH_PIN, OUTPUT);
  pinMode(CLOCK_PIN, OUTPUT);
  pinMode(DATA_PIN, OUTPUT);
  // initialize each turnout
  for(int i = 0; i < NUMBER_OF_TURNOUTS; i++){
    // attach the servo
    servos[i].attach(turnouts[i].data.servo_pin);
    // set the pin mode for the button pin
    pinMode(turnouts[i].data.button_pin, INPUT);
    // test and position the turnout by moving
    // to divergent then to main positions
    servos[i].write(turnouts[i].data.pos_div);
    turnouts[i].pos_now = turnouts[i].data.pos_div;
    setTurnout(i, ALIGN_MAIN);
} // end of setup
  // get elapsed milliseconds at loop start
  // loop through the turnouts array
    if (turnouts[i].is_moving) {
      // if sufficient time has elapsed since the last move
      if ( (currentMillis - turnouts[i].last_move) >= STEP_DELAY ) {
        // move the turnout one degree
        turnouts[i].last_move = currentMillis;
        if (turnouts[i].pos_now < turnouts[i].target_pos) { // if the new angle is higher
          servos[i].write(++turnouts[i].pos_now);
        } else {  // otherwise the new angle is equal or lower
          if (turnouts[i].pos_now != turnouts[i].target_pos) { // not already at destination
            servos[i].write(--turnouts[i].pos_now);
      // if target position reached, stop turnout motion
      if (turnouts[i].pos_now == turnouts[i].target_pos) {
        turnouts[i].is_moving = false;
        turnouts[i].last_move = 0;
        setIndicators(i);
      // if a turnout is NOT in motion, check to see if its button is pressed
      int button_state = digitalRead(turnouts[i].data.button_pin);
      if(button_state == HIGH){
        // toggle position
        if(turnouts[i].alignment == ALIGN_MAIN){
          setTurnout(i, ALIGN_DIVERGENT);
}// end of main loop
// Supporting Functions
void setTurnout(int id, int align){
    // Set indicators to show turnout in motion
    turnouts[id].alignment = ALIGN_NONE;
    setIndicators(id);
    // Set values to trigger motion on next loop iteration
    switch(align){
        case ALIGN_MAIN:
          turnouts[id].is_moving = true;
          turnouts[id].last_move = 0;
          turnouts[id].target_pos = turnouts[id].data.pos_main;
          turnouts[id].alignment = ALIGN_MAIN;
        case ALIGN_DIVERGENT:
          turnouts[id].target_pos = turnouts[id].data.pos_div;
          turnouts[id].alignment = ALIGN_DIVERGENT;
void setIndicators(int id){
  switch(turnouts[id].alignment){
    case ALIGN_NONE: // means the turnout is in motion and not aligned
      panelWrite(turnouts[id].data.panel_LED_main_red, HIGH);
      panelWrite(turnouts[id].data.panel_LED_main_green, LOW);
      panelWrite(turnouts[id].data.panel_LED_div_red, HIGH);
      panelWrite(turnouts[id].data.panel_LED_div_green, LOW);
    case ALIGN_MAIN:
      panelWrite(turnouts[id].data.panel_LED_main_green, HIGH);
      panelWrite(turnouts[id].data.panel_LED_main_red, LOW);
      panelWrite(turnouts[id].data.panel_LED_div_green, HIGH);
      panelWrite(turnouts[id].data.panel_LED_div_red, LOW);
// Shift Register Functions
void panelWrite(int id, byte state) {
  int reg = floor(id / 8);
  int pos = id % 8;
  bitWrite(panel_LEDS[reg], pos, state);
  panelRefresh();
void panelRefresh(){
  // Prepare to shift by turning off the output
  digitalWrite(LATCH_PIN, LOW);
  // shift all bits out in MSB (most significant bit first) order
  for(int i = (NUMBER_OF_SHIFT_REGISTERS - 1); i>=0; i--) {
    // shift out the bits
    shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, panel_LEDS[i]);
  // turn on the output to activate
  digitalWrite(LATCH_PIN, HIGH);
Your buttons are wired incorrectly.
You need to wire the resistors from Arduino pin to ground and wire the buttons from Arduino pin to VCC (for the given design).
I have no idea if you can drive servos directly from an Arduino.
Hi sterretje,Thanks for your promt reply, I have modified my board in the first post, would mind having another look please. Terry
Your one button is OK now; I guess the others will be wired in a similar way.
Please do not go back and change files and diagrams in previous posts as the thread proceeds.
Add a new file or diagram, so that the flow of the thread if read by someone using this to solve there own problem is not confused.
You can control 3 servos from the arduino, but you must have a separate supply as you have fitted to power them, the key is to keep the arduino gnd and the servo supply gnds connected together.
Tom... :slight_smile:
Hi sterretje, thank you
Hi Tom, point taken,thank you, the battery pack on the right hand side is for external power. Terry
OP's diagram
Fritzing diagrams can be very confusing. A photo of a simple pencil drawing of the circuit is usually much easier to understand.
There is no need for external pull-up resistors if you use pinMode(pin, INPUT_PULLUP);
An Uno can control up to 12 servos IIRC.
Servos are a good idea for controlling turnouts and semaphore signals.
...R
Robin2:
OP is using pull-downs :wink:
sterretje:
From the diagram in Reply #8 I thought that they were connected to +5v. I now realize I mixed up his switches and his resistors.
It would still be simpler to use internal pull-ups.
...R
