If you run into noise issues look at using one of these boards:
Overview | Adafruit 16-Channel PWM/Servo HAT & Bonnet for Raspberry Pi | Adafruit Learning System
I used it on my initial predator build. I will have to dig for the final code base piece.
* Example 6
* Nunchuck control for four servos and two button inputs
* Honus 2007
* This allows the use of a Wii nunchuck as an input device and is modified/extended from the original code
* by Tod E. Kurt and Windmeadow Labs
*2007 Tod E. Kurt, http://todbot.com/blog/
*The Wii Nunchuck reading code is taken from Windmeadow Labs, http://www.windmeadow.com/node/42
* ArduinoNunchuk.cpp - Improved Wii Nunchuk library for Arduino
* Copyright 2011-2013 Gabriel Bianconi, http://www.gabrielbianconi.com/
* Project URL: http://www.gabrielbianconi.com/projects/arduinonunchuk/
* Based on the following resources:
* http://www.windmeadow.com/node/42
* http://todbot.com/blog/2008/02/18/wiichuck-wii-nunchuck-adapter-available/
* http://wiibrew.org/wiki/Wiimote/Extension_Controllers
* http://www.gammon.com.au/blink
// www.facebook.com/ArduinoCenter
// https://blog.underc0de.org/arduino-wii-nunchuck-servo-motores/
// Original Code base credited to Undercode
// Code adapted from Sean Maio Crybabyfx setup
//https://github.com/outcry27/crybabyFX
// Updated by knoxvilles_joker 2017
// http://facebook.com/knoxvillesjoker
// more instructions documented at
// http://alienslegacy.com
#include <Wire.h>
#include "ArduinoNunchuk.h"
#include <Servo.h>
//Creates the objects to control the servos
ArduinoNunchuk nunchuk = ArduinoNunchuk();
const int ledPin1 = 13; // Control pin for LED 1
const byte ledPin2 = 12; // Control pin for LED 2
const unsigned long ledPin2interval = 500;
unsigned long ledPin2timer;
const int servoPin1 = 9; // Control pin for servo motor
const int servoPin2 = 11; // Control pin for servo motor
const int servoPin3 = 10; // Control pin for servo motor
const int servoPin4 = 6; // Control pin for servo motor
// sound pins for firing sounds
const int firePin1 = 4;
const int firePin2 = 5;
const int firePin3 = 16;
const int startSoundPin = 17;
int pulseWidth1 = 0; // Amount to pulse the servo 1
int pulseWidth2 = 0; // Amount to pulse the servo 2
int pulseWidth3 = 0; // Amount to pulse the servo 3
int pulseWidth4 = 0; // Amount to pulse the servo 4
int refreshTime = 20; // the time in millisecs needed in between pulses
//Initializes the variables
int xjoystick;
int yjoystick;
int xtilt;
int ytilt;
long lastPulse1;
long lastPulse2;
long lastPulse3;
long lastPulse4;
int minPulse = 700; // minimum pulse width
int loop_cnt=0;
// sound pins are setup before initialization of serial interfaces.
// initialize the audio pins
pinMode(startSoundPin, OUTPUT);
pinMode(firePin1, OUTPUT);
pinMode(firePin2, OUTPUT);
pinMode(firePin3, OUTPUT);
// set up the audio trigger pins to give a path to GND when set to OUTPUT
analogWrite(startSoundPin, LOW);
analogWrite(firePin1, LOW);
analogWrite(firePin2, LOW);
analogWrite(firePin3, LOW);
pinMode(servoPin1, OUTPUT); // Set servo pin as an output pin
pinMode(servoPin2, OUTPUT); // Set servo pin as an output pin
pinMode(servoPin3, OUTPUT); // Set servo pin as an output pin
pinMode(servoPin4, OUTPUT); // Set servo pin as an output pin
pulseWidth1 = minPulse; // Set the motor position to the minimum
pulseWidth2 = minPulse; // Set the motor position to the minimum
pulseWidth3 = minPulse; // Set the motor position to the minimum
pulseWidth4 = minPulse; // Set the motor position to the minimum
pinMode(ledPin1, OUTPUT); // sets the LED pin as output
pinMode(ledPin2, OUTPUT);
ledPin2timer = millis ();
digitalWrite(ledPin1, LOW); // sets the LED pin LOW (turns it off)
digitalWrite(ledPin2, LOW);
Serial.begin(19200);
Serial.print("loading sound card init\n");
Serial.print("card initialized");
//give the audio board time to power up.
// Otherwise bootup sound will be called before audio
// board is ready.
// this plays an initialization sound.
digitalWrite(startSoundPin, HIGH);
//Serial.print("#00\n");
delay(300);
digitalWrite(startSoundPin, LOW);
delay(300);
//Initializes nunchuck and servos
nunchuk.init();
void ledPin2toggle ()
if (digitalRead (ledPin2) == LOW)
digitalWrite (ledPin2, HIGH);
digitalWrite (ledPin2, LOW);
// remember when we toggled it
} // end of toggleGreenLED
checkNunchuck1();
updateServo1(); // update servo 1 position
checkNunchuck2();
updateServo2(); // update servo 2 position
checkNunchuck3();
updateServo3(); // update servo 3 position
checkNunchuck4();
updateServo4(); // update servo 4 position
if(nunchuk.zButton == 1) { // light the LED if z button is pressed
digitalWrite(ledPin1, HIGH);
digitalWrite(firePin1, HIGH);
// Serial.print("#3\n");
// 3 = 1
delay(300);
digitalWrite(ledPin1,LOW);
digitalWrite(firePin1, LOW);
delay(300);
if (nunchuk.cButton == 1) {
if ( (millis () - ledPin2timer) >= ledPin2interval) {
ledPin2toggle ();
digitalWrite(firePin2, HIGH);
// Serial.print("#4\n");
// 4 = 4
// delay(300);
digitalWrite(firePin2, LOW);
// delay(300);
delay(1); // this is here to give a known time per loop
//Guardamos los valores que nos manda el Nunchuk en las variables
xjoystick = nunchuk.analogX;
xjoystick = constrain(xjoystick, 26, 226);
xjoystick = map(xjoystick, 26, 226, 0, 180);
yjoystick = nunchuk.analogY;
yjoystick = constrain(yjoystick, 26, 226);
yjoystick = map(yjoystick, 26, 226, 180, 0);
xtilt = nunchuk.accelX;
xtilt = constrain(xtilt, 320, 720);
xtilt = map(xtilt, 320, 720, 180, 0);
ytilt = nunchuk.accelY;
ytilt = constrain(ytilt, 320, 720);
ytilt = map(ytilt, 320, 720, 0, 180);
// This prints the serial status of the nunchuck.
Serial.print ("Joystick X: ");
Serial.print (xjoystick, DEC);
Serial.print ("\t");
Serial.print ("Joystick Y: ");
Serial.print (yjoystick, DEC);
Serial.print ("X: ");
Serial.print (xtilt, DEC);
Serial.print ("Y: ");
Serial.print (ytilt, DEC);
nunchuk.update();
Serial.print("--C-- ");
if (nunchuk.zButton == 1) {
Serial.print("--Z-- ");
if (nunchuk.cButton == 1 && nunchuk.zButton == 1) {
Serial.print("--Z-C--");
Serial.print ("\r\n");
void checkNunchuck1()
if( loop_cnt > 100 ) { // loop()s is every 1msec, this is every 100msec
float tilt = xjoystick; // x-axis, in this case ranges from ~70 - ~185
tilt = (tilt - 70) * 1.5; // convert to angle in degrees, roughly
pulseWidth1 = (tilt * 9) + minPulse; // convert angle to microseconds
// servoPin1.write(xjoystick);
loop_cnt = 0; // reset for
loop_cnt++;
// called every loop().
// uses global variables servoPin, pulsewidth, lastPulse, & refreshTime
void updateServo1()
// pulse the servo again if rhe refresh time (20 ms) have passed:
if (millis() - lastPulse1 >= refreshTime) {
digitalWrite(servoPin1, HIGH); // Turn the motor on
delayMicroseconds(pulseWidth1); // Length of the pulse sets the motor position
analogWrite(servoPin1, LOW); // Turn the motor off
lastPulse1 = millis(); // save the time of the last pulse
void checkNunchuck2()
// nunchuck_get_data();
// nunchuck_print_data();
float tilt = yjoystick; // y-axis, in this case ranges from ~70 - ~185
pulseWidth2 = (tilt * 9) + minPulse; // convert angle to microseconds
loop_cnt++;
void updateServo2()
if (millis() - lastPulse2 >= refreshTime) {
digitalWrite(servoPin2, HIGH); // Turn the motor on
delayMicroseconds(pulseWidth2); // Length of the pulse sets the motor position
analogWrite(servoPin2, LOW); // Turn the motor off
lastPulse2 = millis(); // save the time of the last pulse
void checkNunchuck3()
float tilt = xtilt; // x-axis, in this case ranges from ~70 - ~185
pulseWidth3 = (tilt * 9) + minPulse; // convert angle to microseconds
loop_cnt++;
void updateServo3()
if (millis() - lastPulse3 >= refreshTime) {
digitalWrite(servoPin3, HIGH); // Turn the motor on
delayMicroseconds(pulseWidth3); // Length of the pulse sets the motor position
analogWrite(servoPin3, LOW); // Turn the motor off
lastPulse3 = millis(); // save the time of the last pulse
void checkNunchuck4()
float tilt = ytilt; // y-axis, in this case ranges from ~70 - ~185
pulseWidth4 = (tilt * 9) + minPulse; // convert angle to microseconds
loop_cnt++;
void updateServo4()
if (millis() - lastPulse4 >= refreshTime) {
digitalWrite(servoPin4, HIGH); // Turn the motor on
delayMicroseconds(pulseWidth4); // Length of the pulse sets the motor position
analogWrite(servoPin4, LOW); // Turn the motor off
lastPulse4 = millis(); // save the time of the last pulse
