hi !
I am having A LOT of trouble with this buzzer who doesnt like to buzz apparently. It is connected to a 555 timer. It is supposed to buzz when there is water on the rain detector. The LED lights up, but the speaker doesn't buzz. I must have re-connected the circuit at least 20 times and I can't seem to find anyone to help me.
Please posts your images here on the forum when you can, so we can see them.
What does the wave form generated by the 555 look like?
Do you have the technical specifications on the buzzer? Like voltage required and current being used?
Paul
i posted links to the images, can you see them ? How do i know what the wave look like? THe buzzer is a 0.2 W 8 ohm buzzer, there is no voltage or current specifications.
you should use a buzzer instead of that speaker. but you can still test if your circuit is good. replace the c4 capacitor with a 1k resistor and use an LED instead of that speaker. if the LED light up after adding water, then the circuit is good.
