Help with Adafruit Feather M0 and DM542T
Hey guys I feel like I am just missing something and seems to easy. So just trying to run a stepper motor with my Adafruit Feather M0 wifi attached to a DM542T driver running a 24V stepper motor. Testing with a basic stepper motor driver off amazon it works just fine but trying to run it off the driver with my feather is just not working no matter what I have tried and really lost count with all I have tried.
Here is my setup:
Here is how I have it connected currently:
  • Feather pin 10 > DM542T - PUL+
  • Feather pin 11 > DM542T - DIR+
  • Feather pin GND > DM542T - PUL-/DIR-
  • DM542T GND > 24V -
  • DM542T +Vdc > 24V +
  • DM542T - A+ - Stepper Red
  • DM542T - A- - Stepper Yellow
  • DM542T - B+ - Stepper Orange
  • DM542T - B- - Stepper Brown
    ** Keep in mind on the stepper connections I just matched up what works with the stepper driver I tested with first that I know works with the same power supply and motor
Here is the basic code I am trying to just get it to turn:
// Stepper Pump Motor PHR-6
// A+ = Red Wire (PIN 6)
// A- = Yellow Wire (PIN 4)
// B+ = Orange Wire (PIN 3)
// B- = Brown Wire (PIN 1)
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper clstepper(AccelStepper::DRIVER, 10, 11);
  // Change these to suit your stepper if you want
  clstepper.setMaxSpeed(2000);
  clstepper.setSpeed(1000);
  clstepper.run();
No surprice. Did the controller survive? No code on earth would make it work.
Any datasheet link for the stepper?
Please post a pic of a hand drawn wiring diagram, with all parts, pins and connections clearly labeled.
Sorry drawing is rough but should give you the idea how it’s connected
Thanks, drawing is fine.
Sorry, I don't see a problem, although I suggest to set the current limit appropriately, and reduce the speed by 100X for testing.
The PUL/DIR pins are designed for 5volt-logic. They need at least 4.5volt (10mA).
A 3.3volt-logic Feather can't provide that.
Leo..
Well I started a lot lower, found I got AC voltage from the stepper drive at high speed so was just seeing if i’d get that output from the driver and didn’t.
Thanks! That helps a LOT! Happened to have a few logic converters and it worked perfect. Funny how one thing like that I did not notice anywhere could cause that. Thanks for the time to answer this!!!
