hi there
i just built a barebones board with the above processor im just before i start im just wondering if this chip has the bootlader installed at the factory? ive tryed to load a sketch to it using the nano 328 which didnt work is that the correct one to use ?
thank you
Chips do not have bootloader installed by the factory.
Got a schematic of the complete "system"?
Nano would be a good choice for 5V/16MHz.
Or a Promini. Select 3.3V/8MHz or 5V/16MHz
Or an Uno if you weren't using A6/A7 (analog inputs only) and 5V/16MHz.
All require external crystal.
jonwhite:
hi robert
thanks for having a look, i think i have spotted my error i think my mosi, and miso were connected wrong going to give it a go in a min
thanks
I assume you have an SPI programmer? Perhaps an UNO running ArduinoISP?
Bootloaders are "optional" ... Using ISP programmer, no boot loader is required, but fuse settings are always a must! Burn bootloader from the Arduino GUI will install boot loader and set fuses if you select UNO as your board type.
hi there
UNO running ArduinoISP, im not having much luck, just had a look at nicks bootloader explanation it looka a bit out of date? as i cant see the nano anywhere the chip im trying to bootload ATMEGA328P-AU, cheers
jonwhite:
hi there
Both the Nano and MiniPro have -AU chips. The boards.txt & pins_arduino.h files complete the profile. Grab from Sparkfun if you must.
Ray
Do not cross MISO to MOSI during programming.
All header pins connect 1-1, with Reset broken out and connected to master's D10.
thanks for the help, not having much luck running ArduinoISP checked setup many time, ive just ordered a USBISP AVR Programmer, hopefully have more luck with that,
thank you
