Hi. I'm using an old Anet A8 main boardto run 1 possibly 2 motors for a project.
I'm trying to use as many old components of the printer as I can.
I aim to use the old end stops as switches. One will start the motor (nema17) and the other switch to stop. I need this to repeat untill the machine is turned off.
I'm great with the mechanical stuff but code is over my head.
Welcome to the Arduino forum. Interesting project, but can you please show us where your Arduino fits into the project?
While you are at it, can you explain how the old end stop switch will start the motor?
It's not mechanical, but, surely, you can show a block diagram of the project and identify all the pieces and how they are connected. And the power supplies for the project.
Hi. Appoligies. Yes I'm looking for some help developing the code. Il post a few pictures of the components.
At the moment it's
1x nema17 motor
2 x limit switches - mechanical
Currently a Anet A8 main board but if I can't recycle this then il order an Arduino.
This will be used to control a spool winder. As it hits the filament hits the top switch it will stop and when it hits the bottom it would start. And continue like this.
