I wanna stary off by saying that I would say that Im relatively new to Arduino, ive done a couple of projects using the basic sensors and some coding. Now im suddenly doing a project outside of my range and Im really seeking any help I can get. My project involves me using an MFRC 522 reader to read a card tag and determine if it is authorized or not and Im using Arduino Uno which everything is working fine. Its goal is to scan the card for a book and determine if it is in the right shelf(the scanner is planned to be installed in a bookshelf) or not.
What I need to do is to have a confirmation database where in an Mysql is connected through arduino only using USb cable, I have heard of etherner and wifi shields however I do not have any router nor internet connection(no provider, literally has no isp) I am using windows10. I have also read some articles regarding posting data and reading etc, but in my case I want the database as a sort of just getting data and confirmation
for example we have book 1 and book 2 both with their respective tags, if I scan book 1, it will confirm and display the data columns like title, author and proper location from the row from the database table
will appreciate any help , sorry for my bad wording. Thank you
If you have NO internet connection... where is this MySQL database located?
Locally?
LAN?
WAN?
I'm also not aware of HOW you plan on communicating with this MySQL DB (wherever it is located)
I have several posts around here using MySQL/PHP to communicate (some even using a finger print scanner in the equation... which is the same as RFID [in my mind.... more or less] as far as code structure goes)
Maybe it will help give you some background on this sort of things is done.
Sorry, yes im not entirely sure I grasp my needs and how to do it.
I am using xampp, phpmyadmin as my database so I would guess locally? sorry i dont have much experience and background on these and just rely on tutorials and example and codes. I have created some basic php websites before and has some experience connecting it to the database. One of my big problems is first how to connect my arduino to the phpmyadmin, and second the code and communication for the rfid reader and database.
I will definetely check your posts, thank you very much for helping.
xl97:
I dont think you are grasping your needs here.
Locally?
LAN?
WAN?
Thanks for the help
My project is now at the point where it needs to connect the ethernet shield to my laptop using ethernet cable, i am unable to use use router and we do not have internet access as well(home internet/wifi).
I am using
Local Apache / XAMPP / phpmyadmin
What im trying to see is whether is it possible to connect the ethernet shield locally through the rj45 port of my laptop and start from there. If not, can a mobile hotspot work as a "router" if not possible. Thank you for assisting this newbie.
nat2xtreme21:
You should be able to connect your laptop & ethernet shield. You'll need a crossover cable though - a normal ethernet cable will not work.
wildbill:
Definitely will check it out thanks, my concern is will it be able to work with a mobile hotspot(as I dont have a router nor wifi).
An update is I tried to connect it via normal ethernet cable and yes I think it has some errors, im not getting and Dhcp ip from it (im connected through my mobile hotspot). Sometimes it prints out an IP sometimes it doesn't, and in some instances when it does print out it changes from time to time(I refresh re click the serial monitor)
Apperently not consistently as im using my mobile hotspot(thinking it can work the same as a wifi connection?)
I get the IP adress from the ethernet adapter Ethernet (comes from the connection from the rj45 slot of shield to laptop). This one I use for the codes where IP of computer is needed.
And for the DHCP for the codes that require IP of arduino which I cannot generate consistently, due to me test using my mobile hotspot(thinking it can be an alternative for a wifi generated by a router?)
Im just still testing the waters on the posts I saw and testing out their codes but none specifically cater to my situation. Yes I use "localhost" or the "127.0.0.1" when needed to, but its still not clear to me for the other parts.
What are my options on connecting my project without the router? Im seeking more of a LAN connection locally. I tried searching for similar project but none cater to my situation(no router no wifi, just plain connectivity over xampp).Any ideas would be much appreciated.
Thank you for the ideas. How do I assign this static IP over the arduino?
Also what options can be opened up to me (including the posts and tutorials I have searched) If I were to get my hands on a router module. My friend can lend me his "Linksys WRT54GH -Wireless-G Home Router with SpeedBurstRouter", which he is not using, and can it help me accomplish my target goal? Thank you a lot.
So I managed to get my hands on the cisco router(it was wireless capabilities),no internet and now Im exploring the two options Im seeing:
Connect Ethernet shield directly to laptop's rj45 and share "wifi"(since the router still generates I can connect to it while not having internet connection);
Problems
-Identifying the IP addresses, I get the default 192.168.137.1 IP for the ethernet adapter ethernet, and an autogenerated dhcp from the router. What im having trouble is the IP address shield is constantly changing everytime I do a serial monitor, and sometimes it remains static until I reset or disconnect from the connection.
2.Connect ethernet shield to the router and laptop connects to the router
Problems.
I get a reliable static IP address for the Ethernet shield and set manually a static IP adress for the router connection however I cant still manage to get a connection. And it still connects even though the IP address for arduino is incorrect as long as its not the same with the laptop ip. My guess is that the router-db connection is through but not the arduino?
ex.
IPAddress ip(192,168,1,103); //IP address for your arduino. this one is inconsistent in the shield to laptop connection, and for the router connection still connects even though ip is incorrect as long not the same as laptop ip
char server[] = ("192.168.1.109"); //IP address of your computer.
