Help with running the GM12864-59N VER:2.0 128x64 I2C LCD MODULE
Patient: GM128-59N VER:2.0 128x64pixels i2c lcd module
Diagnosis: The backlight turns on when connected to power however would not display anything. When using the i2c scanner demo from the arduino ide it also only says "No i2c devices found" which might be the main problem.
Current Hardware: I have removed the D1, R2, R1, and D2 from the back of the board as per advice of someone from an aliexpress post, of course such efforts only gave nothing but false hope.
This are the current codes that I have been trying to run
// 128X64 I2C ST7567S COG Graphic Display ARDUINO
// https://www.youtube.com/c/LeventeDaradici/videos
// the display was bought from here: https://www.aliexpress.com/item/1005004617618178.html
// short review: https://satelit-info.com/phpBB3/viewtopic.php?f=172&t=3338
#include <U8g2lib.h>
#include <Wire.h>
U8G2_ST7567_ENH_DG128064I_F_SW_I2C u8g2(U8G2_R0, SCL, SDA, U8X8_PIN_NONE);
void setup(void)
        u8g2.setI2CAddress(0x3F * 2);
        u8g2.begin();
        u8g2.clearBuffer(); // clear the internal memory
        u8g2.setFont(u8g2_font_ncenB08_tr);
        //u8g2.setFont(u8g2_font_cu12_tr);
        u8g2.drawStr(0, 10, "Hello World!"); // write something to the internal memory
        u8g2.sendBuffer(); // transfer internal memory to the display
void loop(void)
and also this one
#include <Wire.h>
U8G2_ST7567_ENH_DG128064I_1_HW_I2C u8g2(U8G2_R0, SCL, SDA, U8X8_PIN_NONE);  // LCD GRANDE
int x = 0;
  u8g2.setBusClock(400000);
  u8g2.begin();
u8g2.firstPage();
  do {
    u8g2.clearBuffer();
      u8g2.setFont(u8g2_font_ncenB14_tr);
      u8g2.setCursor(25, 23);
      u8g2.print(x);
  } while ( u8g2.nextPage() );
  Serial.println(x);
  x = x +1;
  if (x > 500)
    x=0;
I myself have only slight knowledge when it comes to coding in arduino (though I do have a basic sense for syntax and whatnot) but nothing much when it comes to the u8g2 library, these codes are taken from the internet and have only been slightly modified for personal testing. And yes my wiring is correct (I think...) and I'll just upload an image of it just to be sure. SDA (yellow) connects to A4, SCL (green) to A5, GND to GND and VCC to 3.3v (I have also tried switching it to 5v)
I hope this may provide enough intel to gather any ideas of what might be the problem and any possible solutions, thank you and have a good day to you all.
If possible, check SDA and SCL with a logic analyzer or scope. Are there any signals during I2C scan? If it's just flat lines, no communication , likely no pull-ups or bad wiring.
Unfortunately I don't have any logic analyzer or oscilloscope since those are quite expensive. However I do have a multimeter (tho I don't know how useful) I did get a bunch of voltage readings from the SDA and SCL pins while running the i2c scan on the arduino, the SCL had a 4.89v reading and the SDA 3.75v. This was done by placing the positive of the multimeter to one of the SDA and SCL pins and the negative to the ground of the arduino. I suppose this means that theres at least a reading during the i2c scan ?
An 8 channel USB logic analyzer can be had from Amazon for as little as $10 USD.
DSO type digital scopes start at about $34 USD.
Neither will break the bank. And the logic analyzer will pay for itself the first time it solves a problem for you.
Then we need to know what exactly you have removed: these R1 and R2 may be pull-up resistors.
That's true, but I have pretty much no way of knowing what they are at this point since they're long gone (way to small for me to keep so I kinda just lost them). A bit strange tho is that when I tried to look at the same parts at the back of the module on images of it at the website I bought it from, it didn't have any D1, D2, R1, and R2 either so maybe they never really mattered ??.
I appreciate the recommendation however let's just say I lack the "funding" to really buy a lot of stuff even for things that are just around 20usd like some oscilloscopes online. As for the usb logic analyzers I'll try to take a look into it.
Inexpensive USB units can be gotten for less then a pack of cigarettes in the US.
