Hi guys, I'm currently working on a parallel parking system project for my final semester. To make things short, i need a constant 8v DC supply to my motor driver so that i'm able to monitor the delay when i have a constant speed.
Anyways, before trying the voltage regulator with it's capacitors and diode connected, my robot was able to move forward and brake(reverse DC motor for 50ms at max speed) and proceed with the code. However when i implement the 7808CT regulator, it would work up till forward and resets my Arduino every single time.
My suspicion is that, the current limiter in 7808CT causes the 8V regulator to shutdown since the current draw would be much higher to reverse the DC motor at full speed, therefore shutting down the 8V regulator and turning it back on.
I've spent hours on this and i'm just clueless. Not sure if my 7808CT is broken or do i need to add BD536 for higher current output preventing it from rebooting my arduino?
All help is appreciated! thanks!
-Matthew
Update:
- Hand-drawn 8V L7808CT connected to L298N Motor Driver leading to right/left motors in separated parallel connections. [/i][/b]
