I am using an HM10 Bluetooth module and am trying to follow this tutorial to use AT commands. Unfortunately, none of my AT commands get any response when I use the serial monitor. I followed the tutorial's exact wiring and copy-pasted the code. I have all the same serial monitor settings (Both NL & CR, 9600 Baud, etc...), but still don't get a response when I send AT through the serial monitor. I don't know if this is relevant, but I am using a genuine Arduino Micro and have Arduino 1.8.15 installed on macOS Big Sur.
Omg I just had the same problem with my board a week ago and here is how I fixed it.
// Sketch: HM-10_Example_04A_RemoteLightSensor
// Master HM-10
// Pins
// BT VCC to Arduino 5V out.
// BT GND to GND
// Arduino D8 (ASS RX) - BT TX no need voltage divider
// Arduino D9 (ASS TX) - BT RX through a voltage divider
// Remote HM-10
// HM-10 vcc to +5V
// HM-10 GND to GND
// HM-10 PIOB to LDR/CDS
#include <AltSoftSerial.h>
AltSoftSerial BTSerial;
char c=' ';
char reply[30];
int pos = 0;
Serial.print("Sketch: "); Serial.println(__FILE__);
Serial.print("Uploaded: "); Serial.println(__DATE__);
Serial.println(" ");
Serial.println("The HM-10s should be set for auto connect");
Serial.println("The remote HM-10 should be set for MODE1");
BTSerial.begin(9600);
Serial.println("BTserial started at 9600");
BTSerial.print("AT+ADCB?");
pos = 0;
while ( BTSerial.available() )
c = BTSerial.read();
reply[pos] = c;
pos++;
reply[pos] = '\0';
Serial.print("Reply = "); Serial.println(reply);
delay (3000);
Upload the code above (install the altSoftSerial library), and when in the serial monitor, click the last option (nr and cl). Send AT and you should get OK.
Here is a link that will save you tons of time and stress, it’s what helped me the most.
http://www.martyncurrey.com/hm-10-bluetooth-4ble-modules/
Nope, still not working. This is what I see in my serial monitor:
23:03:12.766 -> Reply =
23:03:16.257 -> Reply =
23:03:19.744 -> Reply =
23:03:23.260 -> Reply =
23:03:26.761 -> Reply =
23:03:30.260 -> Reply =
23:03:33.768 -> Reply =
23:03:37.263 -> Reply =
23:03:40.739 -> Reply =
23:03:44.256 -> Reply =
23:03:47.747 -> Reply =
23:03:51.266 -> Reply =
23:03:54.764 -> Reply =
@a43nigam, your topic has been moved to a more suitable location on the forum. At the moment that you can upload a sketch, it's not a topic for Installation and Troubleshooting
See About the Installation & Troubleshooting category.
Have you figured it out yet?
