How do i fix this error compiling for arduino nano problem?
greetings, i'm currently working on a school project and i encountered this problem
here's my error problem
Arduino: 1.8.12 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp: In member function 'void Adafruit_CircuitPlayground::playTone(uint16_t, uint16_t, bool)':
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:215:3: error: 'PLLFRQ' was not declared in this scope
PLLFRQ = (PLLFRQ & 0xCF) | 0x30; // Route PLL to async clk
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:215:3: note: suggested alternative: 'PCIFR'
PCIFR
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:3: error: 'TCCR4A' was not declared in this scope
TCCR4A = _BV(COM4A0) | _BV(PWM4A); // Clear on match, PWMA on
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:3: note: suggested alternative: 'TCCR0A'
TCCR0A
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
             from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\pgmspace.h:90,
             from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28,
             from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:20,
             from C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:30:
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:17: error: 'COM4A0' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:17: note: suggested alternative: 'COM0A0'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:31: error: 'PWM4A' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:216:31: note: suggested alternative: 'PWM'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:3: error: 'TCCR4B' was not declared in this scope
TCCR4B = _BV(PWM4X) | scalebits; // PWM invert
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:3: note: suggested alternative: 'TCCR0B'
TCCR0B
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:17: error: 'PWM4X' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:217:17: note: suggested alternative: 'PWM'
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:218:3: error: 'TCCR4D' was not declared in this scope
TCCR4D = 0; // Fast PWM mode
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:218:3: note: suggested alternative: 'TCCR0A'
TCCR0A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:219:3: error: 'TCCR4E' was not declared in this scope
TCCR4E = 0; // Not enhanced mode
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:219:3: note: suggested alternative: 'TCCR0A'
TCCR0A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:220:3: error: 'DT4' was not declared in this scope
DT4 = 0; // No dead time
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:220:3: note: suggested alternative: 'DD4'
DD4
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:226:3: error: 'TC4H' was not declared in this scope
TC4H = hi1;
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:226:3: note: suggested alternative: 'PC4'
TC4H = hi1;
PC4
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:227:3: error: 'OCR4C' was not declared in this scope
OCR4C = lo1; // TOP
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:227:3: note: suggested alternative: 'OCR2A'
OCR4C = lo1; // TOP
OCR2A
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:229:3: error: 'OCR4A' was not declared in this scope
OCR4A = lo2; // 50% duty
C:\Program Files (x86)\Arduino\libraries\Adafruit_Circuit_Playground\Adafruit_CircuitPlayground.cpp:229:3: note: suggested alternative: 'OCR2A'
OCR2A
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
The code you tried to compile is incompatible with atmega328 controller
i've also tried with the 168 but it still shows the same message
from the README file of the library:
This is a library for the Adafruit CircuitPlayground boards
link:
i've also installed this
library is not enough, you need compatible boards
"This is a library for the Adafruit CircuitPalyground board only!"
@acexd_ch
Why do you open two threads about the same subject?
Cross-posting is violation of the forum rules.
Flagged to moderator
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
