How do I get a buzzer to work with this?
Hi, I'm making a small program to make a LED transmit the SOS signal (I'm new to this) and I was wondering how I could add a buzzer? Every tutorial I've seen wants me to put the ground cable somewhere else, but if I move it, the LED won't work. I haven't experimented yet because I worried I'll break something or set the board on fire if I use the wrong resistor...
Wiring:
Arduino GND- Negative rail
Arduino 12- Breadboard e15
220 ohms resistor: Negative rail- e13
LED short leg: d13
LED long leg: d15
Sorry, I don't know how to make those diagrams so a description is gonna have to do.
Luxbris:
Do you lack a pencil and paper?
Why would you move the ground somewhere else as opposed to adding ANOTHER ground from the ground rail to the component? Ground is a common circuit, where all the circuits must end. The current in each circuit is different, and must be dealt with separately.
Well, I took a picture. My camera's super bad quality, but hopefully you can make it out.
Luxbris:
A photograph taken from above the Arduino Clone and the breadboard would have been more helpful.
A link to the tutorials that you are looking at would have been helpful.
A link to the description of the buzzer that you want to use would be helpful.
As someone has all ready mentioned a scan of a pencil and paper drawing would have been more helpful.
Even a photograph of a pencil drawn diagram would have been more helpful.
I did figure it out from your word description.
Without knowing more about the buzzer it is impossible to provide any further insight into how to proceed.
artisticforge:
It's just an ordinary buzzer. I got it with a kit that describes the buzzer as "BUZZER: It just buzzes".
It doesn't say anything more than that.
No such thing in electronics, you have to be more specific. Does it buzz when you connect it up to a battery? Or does it need to be connected to an Arduino pin to sound?
Grumpy_Mike:
Looks to me like it slots into the breadboard.
Sorry not good enough that does not answer my question. Try connecting it to a battery and tell us if you don’t know.
Grumpy_Mike:
It doesn't connect to a battery.
Luxbris:
Could you at least take a picture of the buzzer?
How many pins are on the buzzer?
What kit did it come from?
You need to show that you are helping yourself.
artisticforge:
Sorry, buzzers way to small to take a picture that you'd actually be able to see the pins.
2 pins
Utronix Beginners Arduino Projects Series 2
Luxbris:
Yes it does everything can be connected together. You are not showing much, of what I would say, gumption.
Luxbris:
i would guess that if you were to use wires with alligator clips on both ends and connect one end to the buzzer and the other and to the + or - of a AAA or AA battery it would either buzz or not.
artisticforge:
I don't have any alligator clips.
Grumpy_Mike:
I've only just got this kit as a christmas present. Jeez, gimme a break.
Luxbris:
2 pins
Is this the kit that you have?
Arduino Starter Kit + Projects
artisticforge:
Yeah.
Luxbris:
Okay, think outside the box.
Replace the LED with the buzzer. I know novel idea.
Does the buzzer buzz?
You can wire the buzzer in parallel or serial to the LED.
Luxbris:
Yeah.
I know it is not the modern vogue thing to do but can you at least use "Yes" and "No".
gimme a break.
Give us a break, we are not mind readers.
So have you done the projects in this kit? Have you done the one with a buzzer? If so how did they wire it up in the project?
When it was made to buzz was it with the PWM signals or the tone libiary, or was it just a level change in a pin?
You know this because you have the project book.
