How do I manually (NOT using IDE) upload the program to DUE processor?
I have implemented a JAVA based make tool for use with Arduino DUE.
I have successfully reverse engineered up to the construction of the xyz.cpp.bin file using the arm-none-eabi-object utility.
However, I now need to upload the xyz.cpp.bin file to the DUE and launch same on the DUE.
I can see where a "reset" is performed.
Looking in the hardware\tools\g++arm_none_eabi\bin directory, the following tools are available:
04/17/2010 13:20 380,928 arm-none-eabi-abiactel.dll
04/17/2010 13:20 569,856 arm-none-eabi-addr2line.exe
04/17/2010 13:20 589,312 arm-none-eabi-ar.exe
04/17/2010 13:20 1,010,688 arm-none-eabi-as.exe
04/17/2010 13:20 215,040 arm-none-eabi-c++.exe
04/17/2010 13:20 569,856 arm-none-eabi-c++filt.exe
04/17/2010 13:20 214,016 arm-none-eabi-cpp.exe
04/17/2010 13:20 215,040 arm-none-eabi-g++.exe
04/17/2010 13:20 212,480 arm-none-eabi-gcc-4.4.1.exe
04/17/2010 13:20 212,480 arm-none-eabi-gcc.exe
04/17/2010 13:20 44,051 arm-none-eabi-gcov.exe
04/17/2010 13:20 4,098,560 arm-none-eabi-gdb.exe
04/17/2010 13:20 633,344 arm-none-eabi-gprof.exe
04/17/2010 13:20 843,264 arm-none-eabi-ld.exe
04/17/2010 13:20 579,584 arm-none-eabi-nm.exe
04/17/2010 13:20 722,432 arm-none-eabi-objcopy.exe
04/17/2010 13:20 856,064 arm-none-eabi-objdump.exe
04/17/2010 13:20 589,312 arm-none-eabi-ranlib.exe
04/17/2010 13:20 341,504 arm-none-eabi-readelf.exe
04/17/2010 13:20 784,384 arm-none-eabi-run.exe
04/17/2010 13:20 571,904 arm-none-eabi-size.exe
04/17/2010 13:20 571,392 arm-none-eabi-strings.exe
04/17/2010 13:20 722,432 arm-none-eabi-strip.exe
04/17/2010 13:20 166,400 cs-make.exe
04/17/2010 13:20 38,912 cs-rm.exe
What is needed to upload the bin file to the DUE and start it executing?
Is there more than more step to the upload? If so, what might they be?
Does the IDE working with DUE make use of the bossac.exe program?
Why not enable verbose mode during compile and upload steps, and see for yourself?
Even simpler, why not use the IDE?
...R
