I managed to get the code from this Instructable to run on my DIY ATtiny85 board.
However, the author is using a 64x32 display. As you can see in my image below, the top 16 pixels are empty on my 64x48 pixel display.
I'd like to slide the text up to the top and make use of the rest of the display. Perhaps add the date, etc. I just can't figure out how to modify the SSD1306 library to support the display. Since SparkFun's MicroOLED library is for a 64x48 display, I thought that I'd be able to use that as a reference, but no luck.
Here's what I have:
SSD1306.h
* Ref.:
* DigisparkOLED: https://github.com/digistump/DigistumpArduino/tree/master/digistump-avr/libraries/DigisparkOLED
* SSD1306 data sheet: https://www.adafruit.com/datasheets/SSD1306.pdf
#include <TinyWireM.h>
// custom I2C address by define SSD1306_I2C_ADDR
#ifndef SSD1306_I2C_ADDR
#define SSD1306_I2C_ADDR 0x3C
#endif
// custom screen resolution by define SCREEN128X64, SCREEN128X32 or SCREED64X32 (default)
#ifdef SCREEN128X64
#define WIDTH 0x0100
#define XOFFSET 0x00
#define PAGES 0x8
#elif SCREEN128X32
#define PAGES 0x04
#else //SCREED64X32
#define WIDTH 0x40
#define XOFFSET 0x20
#define PAGES 0x04
#endif
class SSD1306 {
public:
SSD1306(void);
void begin(void);
void ssd1306_send_command_start(void);
void ssd1306_send_command_stop(void);
void ssd1306_send_command(uint8_t command);
void ssd1306_send_data_start(void);
void ssd1306_send_data_stop(void);
void ssd1306_send_data_byte(uint8_t byte);
void set_area(uint8_t col, uint8_t page, uint8_t col_range_minus_1, uint8_t page_range_minus_1);
void fill(uint8_t fill);
void v_line(uint8_t col, uint8_t fill);
void draw_pattern(uint8_t col, uint8_t page, uint8_t width, uint8_t pattern);
void draw_digit(uint8_t col, uint8_t page, uint8_t digit, bool invert_color);
void draw_3x_digit(uint8_t col, uint8_t page, uint8_t digit, bool invert_color);
void print_digits(uint8_t col, uint8_t page, uint8_t font_size, uint32_t factor, uint32_t digits, bool invert_color);
void off();
void on();
SSD1306.cpp
* Ref.:
#include "ssd1306.h"
#include "watchdigit.h"
#include <avr/pgmspace.h>
* Software Configuration, data sheet page 64
static const uint8_t ssd1306_configuration[] PROGMEM = {
#ifdef SCREEN128X64
0xA8, 0x3F, // Set MUX Ratio, 0F-3F
#else // SCREEN128X32 / SCREED64X32
0xA8, 0x1F, // Set MUX Ratio, 0F-3F
#endif
0xD3, 0x00, // Set Display Offset
0x40, // Set Display Start line
0xA1, // Set Segment re-map, mirror, A0/A1
0xC8, // Set COM Output Scan Direction, flip, C0/C8
#ifdef SCREEN128X64
0xDA, 0x02, // Set COM Pins hardware configuration, Sequential
0xDA, 0x12, // Set Com Pins hardware configuration, Alternative
#endif
0x81, 0x01, // Set Contrast Control, 01-FF
0xA4, // Disable Entire Display On, 0xA4=Output follows RAM content; 0xA5,Output ignores RAM content
0xA6, // Set Display Mode. A6=Normal; A7=Inverse
0xD5, 0x80, // Set Osc Frequency
0x8D, 0x14, // Enable charge pump regulator
0xAF // Display ON in normal mode
SSD1306::SSD1306(void) {}
void SSD1306::begin(void)
for (uint8_t i = 0; i < sizeof (ssd1306_configuration); i++) {
ssd1306_send_command(pgm_read_byte_near(&ssd1306_configuration[i]));
void SSD1306::ssd1306_send_command_start(void) {
TinyWireM.beginTransmission(SSD1306_I2C_ADDR);
TinyWireM.send(0x00); //command
void SSD1306::ssd1306_send_command_stop(void) {
TinyWireM.endTransmission();
void SSD1306::ssd1306_send_command(uint8_t command)
ssd1306_send_command_start();
TinyWireM.send(command);
ssd1306_send_command_stop();
void SSD1306::ssd1306_send_data_start(void)
TinyWireM.send(0x40); //data
void SSD1306::ssd1306_send_data_stop(void)
void SSD1306::ssd1306_send_data_byte(uint8_t data)
if (TinyWireM.write(data) == 0) {
// push data if detect buffer used up
ssd1306_send_data_stop();
ssd1306_send_data_start();
TinyWireM.write(data);
void SSD1306::set_area(uint8_t col, uint8_t page, uint8_t col_range_minus_1, uint8_t page_range_minus_1)
TinyWireM.send(0x20);
TinyWireM.send(0x01);
TinyWireM.send(0x21);
TinyWireM.send(XOFFSET + col);
TinyWireM.send(XOFFSET + col + col_range_minus_1);
TinyWireM.send(0x22);
TinyWireM.send(page);
TinyWireM.send(page + page_range_minus_1);
void SSD1306::fill(uint8_t data)
set_area(0, 0, WIDTH - 1, PAGES - 1);
uint16_t data_size = (WIDTH) * (PAGES);
for (uint16_t i = 0; i < data_size; i++)
ssd1306_send_data_byte(data);
void SSD1306::v_line(uint8_t col, uint8_t data)
set_area(col, 0, 0, PAGES);
for (uint8_t i = 0; i <= PAGES; i++)
void SSD1306::draw_pattern(uint8_t col, uint8_t page, uint8_t width, uint8_t pattern) {
set_area(col, page, width, 0);
for (uint8_t i = 0; i < width; i++) {
ssd1306_send_data_byte(pattern);
void SSD1306::draw_digit(uint8_t col, uint8_t page, uint8_t digit, bool invert_color)
set_area(col, page, FONTWIDTH - 1, 1 - 1);
uint16_t offset = digit * FONTWIDTH;
uint8_t data;
for (uint8_t i = 0; i < FONTWIDTH; i++) // 8x7 font size data: (8 / 8) * 7 = 7
data = pgm_read_byte_near(&watch_digit[offset++]);
if (invert_color) data = ~ data; // invert
void SSD1306::draw_3x_digit(uint8_t col, uint8_t page, uint8_t digit, bool invert_color)
set_area(col, page, FONT3XWIDTH - 1, 3 - 1);
uint16_t offset = digit * 3 * FONT3XWIDTH; // 24x15 font size data: (24 / 8) * 15 = 45
uint8_t data;
for (uint8_t j = 0; j < 3 * FONT3XWIDTH; j++)
data = pgm_read_word_near(&watch_3x_digit[offset++]);
void SSD1306::print_digits(uint8_t col, uint8_t page, uint8_t font_size, uint32_t factor, uint32_t digits, bool invert_color) {
uint16_t cur_digit = digits / factor;
if (font_size == 1) {
draw_digit(col, page, cur_digit, invert_color);
draw_3x_digit(col, page, cur_digit, invert_color);
if (factor > 1) {
print_digits(col + FONTWIDTH, page, font_size, factor / 10, digits - (cur_digit * factor), invert_color);
print_digits(col + FONT3XWIDTH, page, font_size, factor / 10, digits - (cur_digit * factor), invert_color);
void SSD1306::off(void)
ssd1306_send_command(0xAE);
void SSD1306::on(void)
ssd1306_send_command(0xAF);
