How to connect and use mini joystick FJR06k ?
I got several of this joystick/potentiometer, but didn't found a datasheet for connecting it.
Someone can help me ?
Where are you stuck ?
Connect one end of each potentiometer to VCC on the Arduino and the other end to GND. Connect the wiper from each potentiometer to a separate analogue pin on the Arduino and use analogRead() to read the value on each of the pins that you used
I googled FJR06K and found one in less .168 seconds
very helpfull comment, thank you. The datasheet only contains physical mesurment, not explaining how it works.
This one does
FJR06K Series Drawing.pdf (1.4 MB)
What are you connecting the joystick to?
