Hi All !
I want to make antenna tracker to track UAV using Arduino. Calculating pan and tilt degree on antenna tracking needs GPS location of UAV. My UAV is set autopilot using APM-Mission Planner. I have a plan to take GPS location data of my UAV from mission planner and then give it to my arduino. How to do that? Have anybody here tried this project (or simmiliar project) ? I have searched but haven't found. Thanks for sharing All..
Yes Robin. Mission planner-APM in PC. Let's say, APM to PC using RF on COMP10. So, data sreaming from APM to mission planner (in PC) uses COMP10. So, how to get the same streaming data parallel to arduino? If I have used COMP10 in mission planner, I couldn't use COMP10 in arduino in the same time. Or, is there another way ? Many thanks.
Sorry being late to respon. Yeah, I meant COM10 (without P). Still finding the way to take those values Robin. Because, if we can take those values from Mission Planner, we don't need an additional RF Antenna.,
I assume that your UAV communicates with the ground station using MAVlink protocol. I would run the MAVproxy so as to split the incomming packets both to the Mission planner and to the other serial port that the arduino is connected. You will have to take a look at the MAVproxy documentation so that you can filter which data you want to be directed to where....
Can not help any further as I have not touched the thing for the last 5 or so years so can't remember a thing....
