Hello I am new, to esp32 and microcontrollers as a whole. I am making a noise notification system with esp32-cam, ftdi converter, sound detector sensor, and blynk IoT application.
I have connected the esp32-cam with my ide and now it displays video. However, I tried to connect the sound detector sensor and it is not receiving or reading any audio. How do I connect the sound sensor to the esp32-cam, if i can? These are my components below:
#include "esp_camera.h"
#include <WiFi.h>
// Sound sensor pin
const int soundSensorPin = 2;
// Select camera model
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#include "camera_pins.h"
// Enter your WiFi credentials
const char *ssid = "MCM DOMAIN";
const char *password = "VivaMCM!";
void startCameraServer();
void setupLedFlash(int pin);
void setupSoundSensor(int pin);
Serial.println("ESP32 initialized");
// Setup sound sensor
setupSoundSensor(soundSensorPin);
// Camera configuration
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sccb_sda = SIOD_GPIO_NUM;
config.pin_sccb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.frame_size = FRAMESIZE_UXGA;
config.pixel_format = PIXFORMAT_JPEG; // for streaming
config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
config.fb_location = CAMERA_FB_IN_PSRAM;
config.jpeg_quality = 12;
config.fb_count = 1;
// Camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t *s = esp_camera_sensor_get();
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1);
s->set_brightness(s, 1);
s->set_saturation(s, -2);
if (config.pixel_format == PIXFORMAT_JPEG) {
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
#if defined(CAMERA_MODEL_ESP32S3_EYE)
s->set_vflip(s, 1);
#endif
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
setupLedFlash(LED_GPIO_NUM);
#endif
// WiFi connection
WiFi.begin(ssid, password);
WiFi.setSleep(false);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
// Read from sound sensor
int soundValue = analogRead(soundSensorPin);
Serial.print("Sound sensor value: ");
Serial.println(soundValue);
if (soundValue > 0) {
Serial.println("Sound detected!");
delay(1000); // Adjust delay as needed
// Function to setup sound sensor pin
void setupSoundSensor(int pin) {
pinMode(soundSensorPin, INPUT);
Feel free to ask me for information regarding this if I have any information missing, Thank you ![]()
