hello all,
ive been bashing my head on this for a while [also busy doing other projects], i dont know why im not getting it, but think im just burnt out from all these projects ive accepted.
but all that im trying to do is have an LED fade in when i press say, the enter key.
the LED strips im using are addressable LEDs
http://www.coolcomponents.co.uk/catalog/strip-ledm-addressable-p-706.html
but im just... stuck to be honest.
i have been using the pre-made example, and have been building from that, but im just having a hard time with it
Nathan Seidle
SparkFun Electronics 2011
This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
Controlling an LED strip with individually controllable RGB LEDs. This stuff is awesome.
The SparkFun (individually controllable) RGB strip contains a bunch of WS2801 ICs. These
are controlled over a simple data and clock setup. The WS2801 is really cool! Each IC has its
own internal clock so that it can do all the PWM for that specific LED for you. Each IC
requires 24 bits of 'greyscale' data. This means you can have 256 levels of red, 256 of blue,
and 256 levels of green for each RGB LED. REALLY granular.
To control the strip, you clock in data continually. Each IC automatically passes the data onto
the next IC. Once you pause for more than 500us, each IC 'posts' or begins to output the color data
you just clocked in. So, clock in (24bits * 32LEDs = ) 768 bits, then pause for 500us. Then
repeat if you wish to display something new.
This example code will display bright red, green, and blue, then 'trickle' random colors down
the LED strip.
You will need to connect 5V/Gnd from the Arduino (USB power seems to be sufficient).
For the data pins, please pay attention to the arrow printed on the strip. You will need to connect to
the end that is the begining of the arrows (data connection)--->
If you have a 4-pin connection:
Blue = 5V
Red = SDI
Green = CKI
Black = GND
If you have a split 5-pin connection:
2-pin Red+Black = 5V/GND
Green = CKI
Red = SDI
int SDI = 2; //Red wire (not the red 5V wire!)
int CKI = 3; //Green wire
int ledPin = 13; //On board LED
#define STRIP_LENGTH 128 //32 LEDs on this strip
long strip_colors[STRIP_LENGTH];
void fade (int steps, int d) {
float start[] = {0.0, 0.0, 0.0};
float end[] = {0.0, 0.0, 0.0};
float interval[] = {0.0, 0.0, 0.0};
int i, j;
for (i = 0; i < 3; i++) {
start [i] = (float) fg_color[i];
interval[i] = ((float) bg_color[i] - start[i]) / (float) steps;
bg = Color (bg_color[0], bg_color[1], bg_color[2]);
for (j = 1; j < steps; j++) {
fg = Color ((uint8_t)start[0], (uint8_t)start[1], (uint8_t)start[2]);
for (int i = 0; i < DATA_LENGTH; i++) {
if (datums[i]) strip.setPixelColor(i, fg);
strip.show ();
start[0] += interval[0];
start[1] += interval[1];
start[2] += interval[2];
delay (d);
if (datums[i]) strip.setPixelColor(i, bg);
strip.show ();
pinMode(SDI, OUTPUT);
pinMode(CKI, OUTPUT);
pinMode(ledPin, OUTPUT);
//Clear out the array
for(int x = 0 ; x < STRIP_LENGTH ; x++)
strip_colors[x] = 0;
randomSeed(analogRead(0));
//Serial.begin(9600);
//Serial.println("Hello!");
//Pre-fill the color array with known values
// strip_colors[0] = 0xFF0000; //Bright Red
// strip_colors[1] = 0x00FF00; //Bright Green
strip_colors[2] = 0x0000FF; //Bright Blue
// strip_colors[3] = 0x010000; //Faint red
// strip_colors[4] = 0x800000; //1/2 red (0x80 = 128 out of 256)
post_frame(); //Push the current color frame to the strip
delay(100);
while(1){ //Do nothing
addRandom();
digitalWrite(ledPin, HIGH); // set the LED on
delay(50); // wait for a second
digitalWrite(ledPin, LOW); // set the LED off
//Throws random colors down the strip array
void addRandom(void) {
int x;
//First, shuffle all the current colors down one spot on the strip
for(x = (STRIP_LENGTH - 1) ; x > 0 ; x--)
strip_colors[x] = strip_colors[x - 1];
//Now form a new RGB color
long new_color = 0;
for(x = 0 ; x < 3 ; x++){
new_color <<= 8;
new_color |= random(0xFF); //Give me a number from 0 to 0xFF
//new_color &= 0xFFFFF0; //Force the random number to just the upper brightness levels. It sort of works.
strip_colors[0] = new_color; //Add the new random color to the strip
//Takes the current strip color array and pushes it out
void post_frame (void) {
//Each LED requires 24 bits of data
//MSB: R7, R6, R5..., G7, G6..., B7, B6... B0
//Once the 24 bits have been delivered, the IC immediately relays these bits to its neighbor
//Pulling the clock low for 500us or more causes the IC to post the data.
for(int LED_number = 0 ; LED_number < STRIP_LENGTH ; LED_number++) {
long this_led_color = strip_colors[LED_number]; //24 bits of color data
for(byte color_bit = 23 ; color_bit != 255 ; color_bit--) {
//Feed color bit 23 first (red data MSB)
digitalWrite(CKI, LOW); //Only change data when clock is low
long mask = 1L << color_bit;
//The 1'L' forces the 1 to start as a 32 bit number, otherwise it defaults to 16-bit.
if(this_led_color & mask)
digitalWrite(SDI, HIGH);
digitalWrite(SDI, LOW);
digitalWrite(CKI, HIGH); //Data is latched when clock goes high
//Pull clock low to put strip into reset/post mode
//digitalWrite(CKI, LOW);
delayMicroseconds(50); //Wait for 500us to go into reset
