there are analogue sensors to measure an 230V 50Hz AC current, such as the ACS712.
Suppose you just want to know if a device(laptop, router, etc.) is ON or OFF, suppose when it's on it's 45W, when in standby 30mA(6.9W), OFF of course 0W.
I wish to know, if there is a simple/easy digital sensor (or an easy diy one) to only indicate whether or not an AC device is actually powered, I presume(wrongly?) with some resistor(s) one can change the threshold of the detection, namely 10mA(2.3W), 30mA(6.9W), etc.
It seems to be doable with reed switch, but with a 50Hz I presume the internal metal blades will open/close at 50Hz rate and henceforth I presume the durability will be very limited.
(100'000 / 50hz = 20'000 ~ 6hours, I haven't found durability data on reed switch, but ball switch are in the range of 100K)
Sub question.
Are they digital current meters, just as there a digital temperature sensors(ds18b20), because I solely found analogue ones.
Use for at most 12A 230V AC, expected normal measure 30W to 300W with a precision of at worst 1% at measured current.
Thanks
P.S. Obviously, you can't use a relay to detect the actual ON/OFF,
as the relay would switch on/off the device but won't allow to stay in standby mode, (example laptop from hybernation to on, TV from standby to on, etc.)
