How to interpret analog sensor output
Hi, I have an analog triaxial accelerometer ( 830M1 ) on a vibration rig connected to a "labjack", which is as I understand, functionally the same as an Arduino.
I have successfully been able to gather data in the form of a voltage output, meaning that when the sensor experiences vibration, the voltage increases in the xyz-axes. However I am not sure how to translate this voltage into an amplitude.
The datasheet does not provide a scaling equation that allows me to find the amplitude as far as I can tell.
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+Sheet830M1_Triaxial_AccelerometerA3pdfEnglishENG_DS_830M1_Triaxial_Accelerometer_A3.pdfCAT-EAC0023
An example output is: 1.510429, 1.071990, 1.098840 (volt) (one output for each axis)
I hope that made sense, any input would be appreciated, thank you.
Can it be programmed with the Arduino IDE. If not, then it is not equivalent to an Arduino.
What was the measurement range to acquire those readings?
Use the sensitivity for that range to calculate the answer.
Never heard of that. Can you post a link to the specs?
You could calibrate it by placing it on a stationary, horizontal surface. Whatever it's voltage readings are, they must represent 9.81m/s² or 1g.
By orientating the sensor with its x, y & z axes pointing normally to the surface and making a note of the readings, you can calibrate it to give the correct readings.
Ahh so if the the sens is 50 mV/g then a 1 volt signal equals 20g amplitude. Makes sense, thanks. However I am confused about the base values. Why does the sensor output 1 volt when it is subject to 0 forces except gravity?
I must mention that electronics is not really my field
When stationary, the signals usually fluctuate around 1.1 for 2 of the axes, though one of the axes sits around 1.5 instead. When undergoing vibration, the values start to flutuate +-0.2 . Assuming then that 1G = 1.1V then this is a little strange I believe the vibrations to be significant enough to provide more of an impact than just around .2G
The zero reading must be offset so that the sensor can measure and output for negative Gs, but keep the output signal positive. So, for instance, a plus-minus 25 g sensor with a 5V full scale output will output 2.5V at 0g, 5V at +25 g and 0V at -25g.
One axis will always have 1g due to gravity, the other 2 are at 0g. Most sensors will have an inherent output offset at 0. You can calibrate for that like @PaulRB describes.
Such disagreement is typical for an uncalibrated accelerometer. The min/max calibration method described in the link below is usually good enough: Calibration and Programming | Adafruit Analog Accelerometer Breakouts | Adafruit Learning System
NOTE: the accelerometer data sheet indicates that the output is bipolar, and swings from -1.25V to 1.25V. An Arduino cannot measure negative voltages and the analog input may be destroyed if you try. What does Labjack do with negative voltages?
Not an Arduino!
Good question, when I ran the sensor it never got anywhere close to negative values so I couldn't tell you. It does seem to support bipolar outputs though.
True, but my question was more about the sensor itself and how to read the data and this is the only forum I know with a section dedicated to sensors.
Does Labjack even support bipolar outputs, and negative voltages?
Get out your multimeter and verify that the sensor is working as the datasheet indicates. Any vertical axis should read positive 1 g when pointing up, and negative 1 g when that axis is pointing down.
Until you completely understand how the sensor works, and how to read the output, there is not much sense in going further.
