How to Transmit/Receive Multiple Data with RA-02 LoRa SOLVED
Hi all!
I am trying to send/receive 4 integers with ra-02 and Arduino or ESP8266. The integers are latitude, longitude, speed, and course. I was thinking I need to parse the incoming stream somehow, but don't know how to. Answers would be great!
Thanks!
Pack them together as a struct or an array and send all at once.
Hi
Thanks for your response. How would I parse that on the receiver side? Like, distinguish between the different data?
That's the benefit of using a struct / array on both sides and transmitting the raw binary ... you don't have to "parse" anything.
You send bytes from the struct's memory address on the TX side and store them in the corresponding struct's memory address on the RX side.
Just send and receive an array of binary values. No need to parse anything.
That was my first thought, to do a struct, but using the LoRa library, I don't think that is possible. When I try to transmit the data that way, this is the response:
"no matching function for call to 'LoRaClass::print(Data_Package&)'"
Here is the code:
#include <SPI.h>
#include <LoRa.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#define ss 5
#define rst 0
#define dio0 4
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
int counter = 0;
TinyGPSPlus gps;
SoftwareSerial gpsSerial(RXPin, TXPin);
struct Data_Package {
  byte Latitude;
  byte Longitude;
  byte Speed;
  byte Course;
Data_Package data;
  gpsSerial.begin(GPSBaud);
  Serial.println("LoRa Sender");
  LoRa.setPins(ss, rst, dio0);
  if (!LoRa.begin(915E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  LoRa.setSyncWord(0xF3);
  Serial.println("LoRa Initializing OK!");
  Serial.print("Sending packet: ");
  Serial.println(counter);
  data.Latitude = gps.location.lat();
  data.Longitude = gps.location.lng();
  data.Course = gps.course.deg();
  data.Speed = gps.speed.mph();
  // send packet
  LoRa.beginPacket();
  LoRa.print(data);
  LoRa.endPacket();
  counter++;
  delay(5000);
kgray9:
You need to be more specific about "the LoRa library". There's more than one. Which one are you using? Post the GitHub link.
First, note the maximum packet size of 255 byte which should be more than enough for your struct.
You need to reference LoRa.h for the available methods. The LoRaClass class inherits from Stream. So, you have:
virtual size_t write(const uint8_t *buffer, size_t size);
for sending your packet.
On the RX side, use parsePacket() and make sure the length is correct. The, read() each byte and copy it into successive locations of the receiving struct. Or, read() it all into a separate buffer the memcpy it into the struct.
Note that RadioHead is a more capable library. See the Reliable Datagram examples.
kgray9:
Hi all!
Be careful using structures.
If your Arduino is one such as an Arduino UNO, Pro Mini or Mega, then 32 bit microcontrollers such as ESP32 and DUE, wont decode the structure correctly.
I can point you at a library that allows you to build the LoRa packet to send like this;
LoRa.startWriteSXBuffer(0);
LoRa.writeUint16(voltage);
LoRa.writeUint16(temperature);
LoRa.endWriteSXBuffer();
The receiver then uses this to decode the received buffer;
LoRa.startReadSXBuffer(0);
voltage = LoRa.readUint16();
temperature = LoRa.readUint16();
LoRa.endReadSXBuffer();
If you want to send a strucrure then the library allows you to send an array\buffer directly like this;
LoRa.transmit(array, sizeof(array), ...............
The array can be a structure, character array or and array that you fill yourself with integers, floats etc.
srnet:
I usually first look to see how each side allocates the struct then adjust data types and packing accordingly.
Sorry. Any short code examples @gfvalvo? I'm still kind of new to C++.
gfvalvo:
How would I use this in my code? Is that instead of LoRa.print();?
Would I use it almost like I do with the Radiohead library? Like:
radio.write(&data, sizeof(Data_Package));
But instead:
LoRa.write(&data, sizeof(Data_Package));
:confused: ?
I just found the LoRaDuplex LoRa library example. :slight_smile: It is exactly what I need. Thanks for all the responses everyone!
SOLVED
kgray9:
Which if I recall correctly uses Strings ?
Its generally considered not to be a good idea to uses Strings with Arduinos.
It sends multiple integers for msg ID, message length, local address, and recipient address, as well as a message that is a string. I sent my 4 pieces of data without even using the message payload (which is a string).
Here is my working sender code for for anyone who might find it useful:
#include <SPI.h>
#include <LoRa.h>
#define ss 5
#define rst 0
#define dio0 4
int counter = 0;
TinyGPSPlus gps;
byte msgCount = 0;
byte Latitude;
byte Longitude;
byte Speed;
byte Course;
byte localAddress = 0xBB;
byte destination = 0xFF;
    while (1);
  Serial.println(msgCount);
  String outgoing = String(Latitude) + String(Longitude) + String(Course) + String(Speed);
  // send packet
  LoRa.beginPacket();
  LoRa.write(destination);
  LoRa.write(localAddress);
  LoRa.write(msgCount);
  LoRa.write(outgoing.length());
  LoRa.write(Latitude);
  LoRa.write(Longitude);
  LoRa.write(Course);
  LoRa.write(Speed);
  LoRa.endPacket();
  msgCount++;
  delay(4000);
Here is the receiver code:
#include <SPI.h>
#include <LoRa.h>
#define ss 5
#define rst 0
#define dio0 4
byte localAddress = 0xFF;
int recipient;
String incoming;
byte sender;
byte incomingMsgId;
byte incomingLength;
byte Latitude;
byte Longitude;
byte Course;
byte Speed;
  Serial.println("LoRa Receiver");
    while (1);
  int packetSize = LoRa.parsePacket();
  if (packetSize == 0) return;
  recipient = LoRa.read();
  sender = LoRa.read();
  incomingMsgId = LoRa.read();
  incomingLength = LoRa.read();
  Latitude = LoRa.read();
  Longitude = LoRa.read();
  Course = LoRa.read();
  Speed = LoRa.read();
  incoming = String(Latitude) + String(Longitude) + String(Course) + String(Speed);
  if (incomingLength != incoming.length()) {
    Serial.println("error: message length does not match length");
    return;
  if (recipient != localAddress) {
    Serial.println("This message is not for me.");
    return;
  Serial.println("********************************************");
  Serial.println("Received from: 0x" + String(sender, HEX));
  Serial.println("Sent to: 0x" + String(recipient, HEX));
  Serial.println("Message ID: " + String(incomingMsgId));
  Serial.println("Message length: " + String(incomingLength));
  Serial.println("Latitude: " + String(Latitude));
  Serial.println("Longitude: " + String(Longitude));
  Serial.println("Course: " + String(Course));
  Serial.println("Speed: " + String(Speed));
  Serial.println("RSSI: " + String(LoRa.packetRssi()));
  Serial.println("Snr: " + String(LoRa.packetSnr()));
  Serial.println("");
Here is the serial monitor output of the receiver:
Received from: 0xbb
Sent to: 0xff
Message ID: 48
Message length: 4
Latitude: 0
Longitude: 0
Course: 0
Speed: 0
RSSI: -120
Snr: -3.50
I don't have the GPS hooked up yet so all its data is showing up as 0.
My new tutorial: RA-02(LoRa) with ESP8266 - Hackster.io
Hope this helps!
