@david_prentice
I'm wondering if I can turn the backlight of one of these displays backlights off either in the software or using a transistor?
I am using the MCUFRIEND library.
Here is a routine I use to blank the screen.
void fScreenBlanking( void *pvParameters )
int TimeOfPause = 10000 * 1000;
uint64_t PauseStartTime = esp_timer_get_time();
bool Pause = false;
const int brightness = 250;
int countUpDown = brightness;
for ( ;; )
if (!Pause )
//if motion detect then show display otherwise blank display
if ( !(gpio_get_level( GPIO_NUM_27)) )
for ( countUpDown; countUpDown-- > 0; )
ledcWrite( 4, countUpDown ); // write to channel number 4, dim backlight
vTaskDelay( 7 );
Pause = true;
ledcWrite( 4, brightness );
// still detecting movement reset blanking pause time
if ( gpio_get_level( GPIO_NUM_27) )
PauseStartTime = esp_timer_get_time(); // extend pause blanking time
if ( (esp_timer_get_time() - PauseStartTime) >= TimeOfPause )
Pause = false;
vTaskDelay( 250 );
vTaskDelete( NULL );
} //void fScreenBlanking( void *pvParameters )
A Microwave Motion Detector is used to wake the screen up and after a time, the screen automatically goes back to sleep. Hope the code gives a few clues.
@Idahowalker
What kind of screen are you using?
I am using a display that has a backlight that can use PWM to brighten and dim the screen.
Is it a ILI9488?
Look at the pinout printed on the pcb.
There is no pin for controlling the backlight.
If you want to control the backlight on a TFT buy a shield with the specific hardware.
Waveshare make 240x320 Shields with software control of the backlight.
Waveshare makes a Blue 320x480 abortion e.g. https://www.waveshare.com/3.5inch-tft-touch-shield.htm but I don't support it.
There are several 3.3V SPI boards with Touch, SD and backlight control.
But this means that you have to use level-shifters with your 5V Mega2560.
Be realistic. If you are using a TFT you will probably power via USB.
It is not practical to use batteries.
David.
@david_prentice
If I unplug the 5v pins from my screen, it turns the backlight off, but the display itself is still on and displaying things. Can I not just turn power off to the 5v pins using digitalWrite or a transistor?
A Adafruit_ST7789.
I don't think mine works like yours does, but thanks anyway mate.
No, this is not a good idea. The ILI9488 controller spec is seriously violated.
I am fairly certain that the 5V powers the AMS1117-33 regulator chip. The electronics are powered from the AMS1117-33.
It would be ok if the 5V only powered the backlight. And the controller is powered by permanent 3.3V from the Arduino.
@david_prentice
Oh, okay. That's a shame.
Can you give me a link for a good 4 inch super high res screen for arduino that I CAN turn off via software, and is easy to use with your MCUFRIEND library?
@david_prentice
So what screen will work on a mega (as in not a uno shield)??
