How to Use ESP32 SD_MMC in 1-bit mode
I am planning to use an SD card in SD_MMC 1-bit mode, but there is little on the Internet on this subject. Does anyone here know how to achieve this? Thank you.
I read via a somewhat unrelated topic on ESP32-CAM (motion detection -> take photo -> save to SD) that somebody asked how to disable the LED flash. I thought that the solution was to put the SD card SPI interface into 1-bit mode.
If I recall correctly, it was in the SD_MMC.begin() function call and I think it was changed to something like:
SD_MMC.begin("/sdcard", true);
EDIT: the "true" parameter is setting mode1bit in begin().
Thanks. What about the pin connections?
Pin connections mentioned here;
Thats for an ESP32CAM, but the pins are fixed in any case.
