do{
PORTB = PORTB | 0xF; // Writes PORTB high - Bin 0000 1111
// using an OR mask so other pins are
// unaffected
Serial.println("You pushed button one");
Serial.println(0xF, BIN);
Serial.println("All LEDS are on");
delay(5000);
PORTB = PORTB & 0xF0; // Writes PORTB low - Bin 1111 0000
// using an AND mask so other pins are
// unaffected
Serial.println("All LEDS are off");
delay(5000);
have a read of how-to-get-the-best-out-of-this-forum
what arduino board are you using?
I assume you wish to print leading 0's?
Thank you. I'm using a simulated arduino uno, yeah that's what i'm after
There must be several ways to do it, this is one of them.
Test this code and see if it meets your needs.
delay(10);
int value = 0x1F;
for(int i = 7; i>= 0; i--)
Serial.print(bitRead(value,i));
Serial.println(" ");
Install and #include LibPrintf from the IDE library manager.
#include <LibPrintf.h>
delay(300);
printf("%s\n", "--------------------------------");
byte someNumber = 0b00100011; // a binary formatted number
printf("%08b\n", someNumber); // print with formatting
someNumber = 0b01;
printf("%08b\n", 0xA3); // print with formatting
uint8_t arbval = 0xf; // arbitrary value
uint8_t bitmask = B10000000; // 8 bits, MSB set. Could be written 0x80 or 128
for (/*uint8_t bitmask = B10000000 */; bitmask /* > 0 */; bitmask >>= 1) { // bitmask shift right until bitmask is zero
Serial.print(bitmask & arbval ? '1' : '0'); // AND each bit in arbval with the shifting bitmask to print character 1 or 0
void loop() {}
TLDR;
for (; bitmask; bitmask >>= 1) {Serial.print(bitmask & arbval ? '1' : '0');
void loop() {}
